I’m helping a small remote team move from messy spreadsheets and email threads to something more Agile, but our budget is basically zero. We need a free Scrum tool that supports backlogs, sprints, simple reports, and is easy for non‑technical folks to learn. What free Scrum tools have actually worked well for you, and what should we avoid
Short version. Use Jira Software Free or ClickUp Free. Skip Trello for Scrum.
Here is a breakdown from helping a few small remote teams in the same spot.
- Jira Software Free
Best if your team wants “textbook” Scrum.
- True product backlog, sprints, and Scrum boards
- Simple reports for free: burndown, velocity chart, cumulative flow
- Estimation with story points or time
- Custom workflows once you grow a bit
- Integrations with Slack, GitHub, etc
Limits
- 10 users max on free
- Some config feels heavy at first
- Needs someone to spend 1 to 2 hours setting it up cleanly
How to set it up fast
- Create one project with template “Scrum”
- Create one board tied to that project only
- Columns: To Do, In Progress, In Review, Done
- Issue types: Epic, Story, Task, Bug
- Fields to keep: Summary, Description, Story points, Assignee, Status
- Turn on estimation with Story points
- Sprint length: 1 or 2 weeks, pick one and do not change for 2 to 3 months
- Use quick filters: “Only my issues”, “Bugs”, “Unassigned”
Low effort workflow for your team
- Backlog grooming once a week, refine and estimate
- Sprint planning: pull from top of backlog, check total story points vs last 2 or 3 sprints
- Daily standup: filter “In Progress” and “Unassigned” on the board, walk ticket by ticket
- Sprint review: open burndown and velocity charts, talk about what blocked you
- Retro: three columns in Confluence or Miro or Google Doc, then create Jira tasks from insights
- ClickUp Free
Better if your team wants one tool for “tasks + docs + simple Scrum”.
- Lists as backlogs, Sprints as folders or views
- Subtasks, checklists, custom fields
- Docs for definition of done, sprint goals, etc
- Time tracking built in
- Unlimited users on free tier, but with some usage caps
- Scrum reports weaker than Jira
- More flexible, so people sometimes create messy setups
- Some features locked behind paid plan
Minimum ClickUp setup
- Space: Product
- Folder: “Scrum”
- List: “Product Backlog” for all future work
- List: “Sprint 01”, “Sprint 02”, etc
- Views: Board view per list filtered by Status
- Statuses: Backlog, Ready, In Progress, In Review, Done
- Custom fields: Story Points (number), Type (Epic, Story, Bug, Task)
- Why I usually skip Trello for Scrum
- No native sprints
- Weak reporting on burndowns and velocity
- Needs power-ups that often hit limits on free
- Works for kanban or simple todo, less for full Scrum
- If you pick Jira, here is a starter “ruleset”
- One project, one board, one backlog
- One product owner owns ordering of backlog
- No subtasks until team is stable with basic issues
- All work in sprints, no random “off board” tasks
- Each user updates tickets before daily standup
- Definition of Done written as a Jira “global” description or Confluence page and linked
- If your team hates Jira UI
- Start with ClickUp Free
- Use Board view and a simple status flow
- Add Sprint number as a custom field
- Use a separate list per sprint until you feel pain, then switch structure
If your team size is under 10 and wants more serious Scrum, pick Jira.
If you expect to invite a lot of collaborators and mix docs, tasks, and light Scrum, pick ClickUp.
+1 to what @viaggiatoresolare said on Jira Free vs ClickUp Free. I’ll throw in a slightly different angle so you can pick based on how your team actually behaves, not on “pure Scrum” checklists.
For a small remote team with zero budget, I’d think about:
1. Structure vs friction
Jira Free is great if:
- You have (or can appoint) a de‑facto product owner who will live in the tool.
- The team is ok with a bit of ceremony and can tolerate a clunky UI.
- You really care about burndown, velocity, and “real Scrum.”
ClickUp Free is better if:
- People currently hate tools and live in Slack/Docs.
- You want “tasks + docs + comments” more than perfect sprint reports.
- You expect a bunch of occasional collaborators.
Where I slightly disagree with @viaggiatoresolare: for a brand‑new Agile team that’s already overwhelmed, Jira can be too heavy. They say “1–2 hours to set it up”; in practice I’ve watched non‑tool‑nerds burn a whole day clicking around, confused, then quietly go back to spreadsheets. If there’s no one on the team who likes admin work and config, I’d bias toward ClickUp or even something simpler at first.
2. A couple of other options that actually work for Scrum on free plans
Not as famous as Jira/ClickUp, but worth a look:
a) Zenhub Free (if you already use GitHub)
- Works inside GitHub issues.
- True backlog, sprints, epics, basic burndown.
- Devs don’t have to context switch into a separate tool.
- Great when the “board” is basically the engineering team.
- Bad if non‑dev stakeholders need a friendly UI or don’t live in GitHub.
For a very dev‑heavy remote team, Zenhub + GitHub issues often beats Jira because people actually keep it updated.
b) GitHub Projects (new version)
- You can simulate Scrum with:
- One project per product.
- Milestones as sprints.
- Views for board, table, etc.
- Reports are weaker, but you get basics if you track story points in a custom field.
- Perfect if you already use GitHub and don’t need textbook charts.
3. Don’t overfit the tool to “Scrum purity”
Some hard‑earned lessons from watching small teams fail at this:
- If your people won’t touch the tool daily, the “best Scrum tool” is useless.
- For the first 2–3 months, consistency matters more than feature depth.
- It is better to have:
- A simple board
- A single ordered backlog
- Timeboxed sprints
- One place for discussion
…than every Scrum artifact and report.
4. Practical recommendation by scenario
Team ≤ 7, mostly devs, already in GitHub:
Use Zenhub Free or GitHub Projects. Lightweight, low friction, enough Scrum. -
Team ≤ 10, at least one person likes process & config, you want “real” Scrum charts:
Go with Jira Software Free. Accept that it will feel annoying for a week, then stabilizes. -
Mixed team (PMs, marketing, design), everyone hates complex tools, you need docs + tasks:
Choose ClickUp Free. Keep it dead simple:- One backlog list
- One list per sprint
- Board view + a “Sprint” field
You can tighten the process later.
5. One trap to avoid regardless of tool
Biggest failure mode I see: people treat the tool as “just a tracker” and keep all real discussion in email/DMs. Then the board rots.
Whatever you pick, set a tiny rule like:
“If it is not on the board, it does not exist.”
And:
“Decisions live as comments in the ticket, not only in chat.”
Given what you described (remote, messy spreadsheets, zero budget), I’d start with ClickUp or Zenhub if you’re dev‑heavy, then graduate to Jira only if you feel you’ve outgrown the lighter setup rather than jumping straight to max‑ceremony.
