I’m planning my first iOS app and I’m struggling to estimate a realistic development budget. I’ve talked to a few freelancers and agencies, but the quotes are all over the place, from very cheap to surprisingly expensive. The app is fairly simple, but I don’t want to underestimate ongoing costs like updates, maintenance, and App Store fees. Can anyone break down typical iOS app development costs, what factors affect the price the most, and what I should budget for beyond the initial build?
Short version. For a small iOS app, realistic dev cost is usually somewhere between 5k and 40k, depending on scope and who you hire. The 500 dollar quotes are almost always trouble.
More useful breakdown:
Define “small project” first
Think in features, not vibes. For example:- Email / Apple login
- Simple onboarding
- 3 to 5 main screens
- Basic CRUD with a backend
- Push notifications
- Simple settings screen
That is a typical “small but real” v1.
Hourly rates you will see
- Solo dev in lower cost regions: 15 to 40 per hour
- Solo decent iOS dev in US / EU: 60 to 150 per hour
- Small agency: 80 to 180 per hour
- Fancy agency: 150 to 250 per hour
Rough hour ranges for a small but real app
This assumes native Swift, not some half broken template.- Wireframing, basic product thinking: 10 to 20h
- UI implementation: 40 to 80h
- Core logic and networking: 40 to 80h
- Auth, analytics, push, basic settings: 30 to 60h
- Backend setup if simple (Firebase or similar): 20 to 40h
- Testing, bugfix, App Store prep: 20 to 40h
Total: 160 to 320h for a clean v1 that you are not ashamed to ship.
Convert hours to cost
Example 1, decent solo dev at 60 per hour- 160h: ~9.6k
- 320h: ~19k
Example 2, small agency at 120 per hour
- 160h: ~19k
- 320h: ~38k
So for a normal “small startup app” first version
- 8k to 20k with a freelancer
- 18k to 40k with an agency
What “super cheap” often means
- No real architecture, hard to extend later
- Bugs you pay more to fix later
- Copy pasted template with small edits
- Poor UX and no analytics or logging
You save up front, then pay later when you need new features or a rewrite. I learned that the hard way, paid 3k for an app, later spent ~15k fixing and rebuilding half of it.
Things that blow up cost fast
- Custom complex UI and animations
- Offline sync, complex caching
- In app purchases and subscriptions
- Realtime chat or live updates
- Deep integrations with weird APIs
- Multiple environments, staging, feature flags
Each of those can add 20 to 80 extra hours.
How to get sane quotes
- Write a 1 to 2 page spec
- Target users
- Key flows: sign up, main action, settings
- List of screens
- API or backend choice
- Ask devs for an estimate in hours, not only a flat price
- Ask what is included: design, testing, App Store support, 1 to 3 months of bugfix after launch
If someone refuses to talk about hours and only throws a fixed number, I’d be cautious.
Budget ranges that make sense for you
- 1k to 5k
- Simple prototype, clickable Figma, or low code MVP
- 5k to 15k
- Small but real v1 with a freelancer, limited features
- 15k to 40k
- More polished v1 with better architecture, some room for changes
- 1k to 5k
Non dev costs people forget
- Apple dev account: 99 per year
- Design work if not included: 500 to 5k
- Backend hosting: usually 20 to 200 per month at the start
- Legal stuff: privacy policy, ToS
How I would approach your first app
- Cap your v1 scope to 4 to 6 core screens
- Decide a hard budget range, for example “under 15k”
- Find 3 freelancers, ask for hour breakdown and milestones
- Start with a paid discovery phase, 5 to 10 hours, to refine scope and then lock the dev budget
If you share your rough feature list and target users, people here can give a more specific range like “this looks like 120h” instead of generic price guesses.
The reason your quotes are all over the place is that you’re actually getting prices for different things, even if everyone is “building the same app.”
@voyageurdubois already laid out a solid hour & rate breakdown. I agree with their 5k–40k band for a “small but real” app. I’d frame it slightly differently, focusing on what corners are being cut at each price level.
Here’s how I’d interpret quotes you’re probably seeing:
1) Sub‑1k to 3k quotes
Red flags most of the time. Typical patterns:
- Template app with your logo slapped on
- No real state management or clean architecture
- No meaningful testing
- No long term support, they vanish when Apple changes something
Might be ok if you only want a throwaway prototype and you fully expect to bin it later.
2) 3k to 8k quotes
This is “scrappy MVP” territory. Usually:
- Solo dev, probably cutting scope hard
- You’ll get core flows working, but limited polish
- Tech debt from day one is likely
- Things like analytics, error logging, edge cases often get skipped
This range can work if:
- Your v1 is tiny
- You’re ok with rework later
- You care more about testing the idea than building a long‑term codebase
3) 8k to 20k quotes
This is where a lot of serious small apps actually land with a freelancer. Typically:
- A real native iOS app, no shady template
- Clean enough architecture that future devs won’t hate you
- Reasonable UX, some testing, App Store submission handled
- A basic backend set up properly instead of hacked together
Here is where I slightly disagree with @voyageurdubois: that 160–320h range is fine for a fairly standard feature set, but if you want even one nontrivial thing (subscriptions, offline mode, or a polished custom design), realistic v1 for a single dev is closer to 220–400h. People chronically undercount integration headaches and revisions.
4) 20k to 40k+ quotes
You’re paying for:
- Agency overhead, multiple roles (PM, QA, designer, dev)
- More predictable process, nicer communication, often better documentation
- Less “single human got sick and your project stalled for 3 weeks” risk
Not magically higher quality, but higher probability of getting a solid v1 on a fixed timeline.
Instead of thinking “what’s a realistic cost,” think in these terms:
A. What quality level do you actually need for v1?
- Just need to show investors or test 100 users? You can tolerate more hacks.
- Expecting to go live on App Store and onboard strangers? Suddenly things like analytics, crash reporting, onboarding edge cases, and App Store guideline compliance matter a lot, and that pushes you upward in cost.
B. How much change do you expect after v1?
If you know you’ll iterate like crazy for 6–12 months, you don’t want a 2k “ball of mud” app. You’ll lose all your “savings” when the next dev says, “I need to rewrite this, it’s not maintainable.”
C. How defined is your scope?
Here’s where a lot of budget chaos comes from.
Two 10k quotes might be for totally different assumptions because your spec is fuzzy. If your requirements are hand‑wavey like “simple social feed,” devs are guessing, and some are guessing optimistically (or dishonestly).
You’ll get way more consistent numbers if you:
- List each screen and its main actions
- Specify login methods
- Call out any “special” stuff: payments, offline, video, maps, etc.
- Clarify if they’re responsible for backend or if it already exists
You don’t need a formal PRD, but a clean 1–2 page doc can shrink quote variance a lot.
Ballpark ranges I’d personally use for planning:
Tiny but real v1 with a freelancer
- Very narrow scope, no crazy features
- Roughly: 6k–12k
Comfortable, extensible v1 with a freelancer
- Decent architecture, basic analytics, app store prep, a couple of iterations
- Roughly: 12k–25k
Agency v1 with all the PM & QA trimmings
- You want more hand‑holding and less risk, polished launch
- Roughly: 25k–45k
If someone quotes:
- $500–$1500 for a “complete iOS app” with login, backend, push, etc, assume:
- It’s a template
- Or they’re drastically underestimating and you’ll eat the overrun later
- $60k+ for a genuinely small feature set, they either:
- Don’t want the project and are pricing you away
- Or are bundling tons of fluff (huge discovery, branding, etc) you may not need
Practical move you can do next week:
- Decide your maximum absolutely‑no‑more budget. Example: “I will not exceed 15k for v1.”
- Trim your feature list to what fits that. Anything questionable goes on a “v1.1” list.
- Ask each dev/agency two specific things:
- “How many hours is this, and what’s your assumed hourly rate behind this quote?”
- “What is not included in this price that I might assume is included?”
The second question is where you’ll discover stuff like, “Oh, we don’t include App Store submission” or “We don’t do backend” or “Only 2 weeks bugfix after launch.”
If you want, drop your rough feature list and intended v1 audience and I’ll give you a more brutal guess like, “That smells like 180–240h” rather than the soft 5k–40k range.
Numbers from @sternenwanderer and @voyageurdubois are solid, so I’ll focus on how to aim for the lower half of that 5k–40k range without nuking quality.
Key idea: you are not buying “an app,” you are buying risk reduction and future flexibility. That is what really drives price, more than line items of screens and buttons.
1. Why quotes are all over the place
Even with the same feature list, devs are silently making different assumptions about:
- How robust the app must be (error handling, offline edge cases, accessibility, etc)
- How much iteration is included (design tweaks, UX changes after you try it)
- How “future proof” the architecture has to be
- Who owns product decisions (you vs them)
Cheap quotes often assume: “Happy path only, minimal QA, minimal iteration, no ownership after handoff.”
Expensive quotes usually assume: “We’ll babysit this from idea to App Store and a bit after.”
If you do nothing else, explicitly choose which of these you care about and tell every dev the same constraints. That alone narrows the range.
2. Where I slightly disagree with them
They both anchor on hours and features. That is useful, but it hides one thing:
For a first-time founder, “project management & product coaching” is often half the real value.
A 12k freelancer who pushes back on bad ideas, trims scope, and structures releases can be far more valuable than a 7k one who just executes your first draft spec. Agencies charge more partially because they bundle this thinking in.
So if this is literally your first app, I’d plan 20–30% of the budget for “being wrong”: scope changes, UX rethinks, and “oh, I forgot we need X.”
Under 10k, that margin tends to vanish, so change hurts.
3. How to choose between a 7k, 15k and 30k quote
Rather than only comparing checklists, probe these three things:
How will you validate we are building the right thing before all features are done?
- Good answer: talk about early builds, testable milestones, maybe TestFlight builds every 1–2 weeks.
- Weak answer: “We deliver everything after 6 weeks.”
What happens if my idea shifts mid‑build?
- Good: clear change‑request process, maybe hourly for extras.
- Bad: “Any change beyond spec is a new project.”
Who is responsible for app quality after launch?
- Good: some well defined post‑launch bugfix window and monitoring setup.
- Bad: handoff of a zip file and “good luck.”
Counterintuitively, a 15k quote that is clear on these three can be safer than a 7k “all in” quote with fuzzy boundaries.
4. Practical budget tiers for a first iOS app
Given everything above, if I had to put my own money on the table:
Under 5k
- Treat it as a prototype you might throw away.
- Use it to learn, not to scale.
- Expect rough edges and limited support.
8k–18k (sweet spot for many first‑time founders with a freelancer)
- Small but real v1, reasonable structure.
- Enough runway for 1–2 cycles of UX changes.
- Still need to be disciplined with scope.
20k–40k
- Good if you care more about polish and handholding than squeezing every dollar.
- Agencies live here: PM, designer, QA, dev, processes.
- You pay to reduce schedule and communication risk.
If a quote is way outside these bands for a “small but real” app, something about scope or expectations is mismatched.
5. How to shave cost without sabotaging the project
Instead of asking “Can you do it cheaper,” cut strategically:
Defer features that are expensive to do well:
- Real‑time anything (chat, live updates)
- Offline sync
- Subscriptions and in‑app purchases
- Deep custom animations
Keep the backend dead simple at first:
- Use a BaaS like Firebase or Supabase rather than a full custom backend unless you have a strong reason.
- This saves a lot of hours in that 20–40h backend bucket @voyageurdubois mentioned.
Constrain design:
- Stick close to native iOS components for v1.
- Custom design systems and fancy visuals usually cost more than the feature logic.
This way you stay in that 160–320h band for v1 even with modest polish.
6. What I’d do in your place this week
Decide if your goal is learning or launching.
- Learning: you can live in 3k–8k “scrappy MVP” land.
- Launching to real users: budget realistically 8k–20k with a freelancer or 20k–40k with an agency.
Write a very blunt, non‑fluffy 1–2 page spec:
- Who uses it
- 4–6 core screens
- Exactly what “success” for v1 means in user terms
Send the same doc to each candidate and explicitly ask:
- “Give me a min/likely/max hours estimate.”
- “What will not be included in this quote that people often assume is included?”
You’ll quickly see who has actually shipped production iOS apps and who is just selling a number.
If you want to paste a rough feature list and what “v1 success” means for you (e.g., “100 test users from my existing audience” vs “public launch”), it is possible to sanity check whether you’re closer to the ~120h, ~220h or “you’re dreaming, this is 400h+” category.
