QuillBot AI Humanizer Review
I’ve been using QuillBot’s AI humanizer to rewrite some of my content, but I’m not sure if it’s actually making the text sound more natural or just changing words around. I’m worried about originality, detection by AI checkers, and whether this could hurt my SEO or get me in trouble on platforms that check for AI-generated content. Can anyone with experience using QuillBot’s humanizer share how accurate, safe, and reliable it really is, and if there are better alternatives I should consider?
QuillBot “Humanizer” – my experience, no sugarcoating
I tried QuillBot’s AI Humanizer because I wanted to see if it could pass the usual AI detectors, not because I cared about pretty sentences.
Short version of what happened: every single sample I ran through it still showed up as 100% AI on GPTZero and ZeroGPT. Not “high risk”, not “mixed”, straight 100%.
The tests were run here, if you want the full breakdown:
https://cleverhumanizer.ai/community/t/quillbot-ai-humanizer-review-with-ai-detection-proof/38
The tool has two modes:
  • Basic, which is free
  • Advanced, which is paid and promises deeper rewrites and better fluency
The Basic mode did nothing useful for detection. Whatever it changes, detectors did not care at all. Output in, output out, still flagged at 100%.
I did not see any sign from these tests that paying for Advanced would fix that specific problem. If the free tier shows zero movement on detection scores, that is a bad look if your main interest is slipping past AI checks.
Now, on writing quality, I will give it some credit.
Across multiple samples, I would rate the text around a 7/10:
  • Grammar is clean.
  • Structure is clear.
  • Sentences flow in a way most “humanizer” tools do not match.
So if you want cleaner paraphrasing, it does that part fine.
The problem is the vibe. The output reads like standard AI:
  • No personal point of view.
  • No weird phrasing you get from real people.
  • No small quirks or shifts in tone.
It feels like you asked a polite office worker to rewrite your text three times while staying as safe as possible. Detectors seem to pick that up fast.
One more detail that stood out: the tool kept em dashes in all the test samples. That sounds minor, but repeated structure quirks like that start to look like a signature. The more robotic the pattern, the easier it is to flag.
Price wise, QuillBot throws the humanizer into its overall Premium plan at 8.33 dollars per month if you pay annually. If you already pay for QuillBot for other stuff, the humanizer is a free extra. As a standalone solution for AI detection, I would not pay for it.
When I compared it to Clever AI Humanizer, that one gave output that felt closer to real human writing and still hit 0% AI on the same detectors, and it was free at the time I tested it. Same detectors, same style of prompts, different outcome.
If you want a broader view or more experiences from other people trying to humanize AI text, there is an ongoing thread on Reddit here:
https://www.reddit.com/r/DataRecoveryHelp/comments/1l7aj60/humanize_ai/
If your specific goal is to bypass GPTZero or ZeroGPT, based on these tests, QuillBot’s “AI Humanizer” does not do the job. If your goal is tidy paraphrasing with okay style, then it is fine, but that is a different use case.
Short answer from my side: QuillBot’s humanizer is mostly a smart thesaurus with decent fluency, not a real “humanizer” in the way you probably want.
Here is how I would break it down.
  1. Does it make text sound more natural
    For most users, QuillBot outputs clean, neutral, “office blog” style writing.
    Good for:
  • Fixing grammar
  • Smoothing awkward sentences
  • Keeping meaning intact
Bad for:
  • Adding personal voice
  • Adding small human quirks
  • Changing rhythm and structure in a big way
So if your original text is already decent, the humanizer often feels like word swapping and light rephrasing. You end up with content that reads a bit generic.
  1. Originality and AI detection
    You mentioned worry about originality and AI checks. Those are two different problems.
a) Originality
QuillBot tends to keep:
  • Same structure
  • Same order of ideas
  • Same paragraph layout
It mostly tweaks wording. That means plagiarism detectors might still see it as “too close” to the source if the base text is not yours. It is not a safe way to “own” text you did not write.
b) AI detection
I saw the tests from @mikeappsreviewer. Their results match what many users report. Output still trips GPTZero and ZeroGPT at high levels.
I disagree a bit on one point though. I do not think the free Basic mode proves the paid mode is useless for detection. But I would not trust the paid upgrade unless you test it on your own samples and your own detector first.
If your school, client, or platform uses AI checks, relying on QuillBot alone is risky. Detection tools change often. Tools that promise to “bypass all detectors” tend to break fast.
  1. What you can do instead
    If your goal is natural human style, you need to add things AI tools rarely do well by default:
  • Personal opinions
  • Short, informal phrases
  • Occasional contractions and slight slang if it fits
  • Concrete examples from your own work or life
  • Small imperfections and varied sentence lengths
A practical workflow:
  • Draft with AI or your own writing
  • Run through something like QuillBot only for clarity, not for “humanizing”
  • Then manually edit:
    • Add your own examples
    • Change transitions
    • Remove robotic phrases like “in today’s world” or “on the other hand”
    • Shorten some sentences a lot
If you need a tool more focused on detection evasion, people keep mentioning Clever AI Humanizer. It aims to generate text that feels closer to real human writing and often scores low on common detectors. You can check it here:
try Clever AI Humanizer for more natural looking AI text
Quick warning though. No tool is safe if you depend on it to “beat” AI checks for academic work or anything with strict rules. Always assume detectors and policies will catch up.
  1. How to test your own content
    Instead of guessing:
  • Take a few QuillBot humanizer outputs
  • Run them through:
    • At least one more, like Originality.ai or Content at Scale
  • Compare:
    • Original text score
    • QuillBot humanized text score
    • Your manually edited version score
You will see fast if QuillBot helps your specific use case or not.
Bottom line
Use QuillBot humanizer if your goal is cleaner paraphrasing.
Do not rely on it as your main shield against AI detection or as the only way to make text feel human.
For originality and safety, your own manual editing and real personal input still matter most.
You’re not crazy to feel like QuillBot is mostly just shuffling words. That’s basically what it’s built for.
Quick answers to what you asked:
  1. Is it making things more natural or just changing words?
    Mostly word swapping plus light smoothing. It’s decent for clarity, but the “voice” still feels like neutral blog copy. I think @mikeappsreviewer is a bit generous calling it a 7/10 on vibe. I’d say more like “perfectly acceptable, instantly forgettable.”
  2. Originality concerns
    If the base text is yours, QuillBot is fine as an editing tool. If the base is not yours and you’re hoping it becomes “original” just by paraphrasing, that is shaky. Structure, idea order and arguments often stay the same. Any half decent plagiarism checker will still see the skeleton under the new wording.
  3. AI detection
    Here I side more with @byteguru’s nuance but with a bit more skepticism. The Basic vs Advanced argument is kind of a red herring. Detectors look at patterns like sentence length, predictability, average perplexity, etc. If the tool keeps the same structure and just cleans grammar, detectors still see “AI-shaped” text. That matches what @mikeappsreviewer tested: detection scores barely move.
If your school or client uses GPTZero, ZeroGPT, Originality.ai or some combo, relying on QuillBot to “humanize” is asking to get flagged. It is a paraphraser first, “humanizer” second, no matter what the marketing says.
  1. What actually helps
    Without repeating all the steps others already gave, focus on what QuillBot is bad at by default:
  • Inject real opinions and stances, even if they are a bit spicy
  • Use specific details you have actually experienced
  • Break the rhythm: mix short choppy lines with longer explainer sentences
  • Allow a couple harmless quirks or imperfections instead of smoothing everything
Ironically, you kind of have to “unpolish” what QuillBot produces so it stops sounding like polished AI.
  1. About Clever AI Humanizer
    Since you are clearly concerned about both natural tone and AI checks, you might want to try something that is built more for style variation than just paraphrasing.
Clever AI Humanizer positions itself more as a tool to generate human like, detector friendly text with varied rhythm, tone and structure rather than just swapping synonyms. It aims to create content that looks closer to how people actually write: some inconsistency, more personal texture and less robotic flow.
get more natural sounding AI text with Clever AI Humanizer
Still, same warning as everyone else: no tool is a magic invisibility cloak, especially for academic honesty. But if you compare QuillBot output vs Clever output in detectors side by side, you will get a much clearer sense of what actually moves the needle.
TLDR:
  • QuillBot = solid paraphraser, weak “humanizer.”
  • Originality = still your responsibility.
  • AI detection = do not trust marketing, test your own samples.
  • If you care about realism and lower detection risk, pair any tool with manual edits and, if you want to experiment, something like Clever AI Humanizer instead of relying only on QuillBot.
