Need recommendations for a reliable iOS application development company
I’m looking for a trustworthy iOS application development company to build a new app for my small business after a previous freelancer missed deadlines and delivered buggy code. What factors should I consider when choosing a company, and can anyone share real experiences or suggestions for teams that communicate well, stick to timelines, and provide ongoing support?
I’d stop looking for “the best company” and focus on a tight vetting process, especially after a bad freelancer exp.
Key things to check:
  1. Relevant portfolio
    Ask for 3 to 5 iOS apps similar to what you want.
    Check if they are live in the App Store, look at ratings, last update, crash complaints in reviews.
  2. Code quality
    Ask if they use:
  • Swift as primary language
  • MVVM or VIPER or Clean Architecture
  • Unit tests and UI tests
  • CI like GitHub Actions, Bitrise, CircleCI
    If they stare blankly at tests or CI, skip.
  1. Process and project management
    You want:
  • Weekly sprints
  • Weekly demo builds through TestFlight
  • Shared backlog in Jira, Trello, ClickUp, whatever
  • One clear product owner or PM on their side
    Insist on weekly calls with screen share and build review.
  1. Communication habits
    Ask how fast they respond on Slack or email.
    Set a rule in the contract, example: reply within one business day.
    If they are slow or vague before signing, it gets worse after.
  2. Clear scope and milestones
    Get a written scope that lists:
  • Features
  • Platforms and OS versions
  • Third party services, example Stripe, Firebase, Auth0
  • Non functional needs like load time, offline support
    Tie payments to milestones tied to working builds, not to dates only.
  1. QA and testing
    Ask who does testing. Devs alone is a red flag.
    You want a separate QA person.
    Ask for test plans or at least bug tracking screenshots.
    Set a bug acceptance rule, example: no open critical bugs at milestone sign off.
  2. Ownership and IP
    Contract must state:
  • You own source code and all assets once paid
  • Repo is on your GitHub or shared Git repo
  • You get code access from week one, not at the end.
  1. Post launch support
    Ask what happens after release.
    Typical is 1 to 3 months free bug fixing for defects in agreed scope.
    Get their hourly or monthly support rate in writing.
  2. Pricing model
    For small business app, either:
  • Fixed price with a detailed scope, good if scope is stable
  • Time and materials with a not to exceed cap, better if things might evolve
    Avoid super lowball offers, they usually cut corners, skip tests, reuse junk code.
  1. References and reviews
    Check Clutch, GoodFirms, Upwork Enterprise, local tech groups.
    Ask for 2 clients you can talk to on Zoom.
    Ask them if deadlines were met, how many bugs slipped to production, if they would rehire.
A few company types to look at:
  • Boutique 5 to 20 person iOS focused studios
  • Local agencies where you can meet the lead dev
    Avoid shops that do “iOS, Android, web, NFT, AI, blockchain, marketing” all in one page.
Last tip, start with a small paid discovery phase.
Example, 1 to 2 weeks to define user flows, technical doc, wireframes, and estimate.
If they nail that, odds go up for the full build.
+1 to a lot of what @ombrasilente said, especially about process and getting a real discovery phase in place. I’d tweak the focus a bit though, because “good company + bad fit” can still wreck your project.
A few extra angles to look at:
1. Match their scale to your budget and risk level
Big agencies look impressive, but for a small business app you can end up paying for overhead, not value.
Ask directly:
  • “What’s your typical project budget range?”
  • “Where would my project sit on your priority list?”
    If they mostly do 200k+ builds, your 30k app is going to get the intern squad. I’d lean toward small or mid-size teams where your project is not an afterthought.
2. Product thinking, not just coding
Your previous issue was code quality and deadlines, but another hidden risk is teams that just say “yes” and build whatever you describe.
On your calls, notice if they:
  • Question assumptions
  • Suggest cheaper/simpler alternatives
  • Talk about user flows, retention, onboarding, analytics
    If the conversation is only “features & price” with zero pushback, that’s not a partner, that’s a keyboard.
3. Design & UX maturity
A lot of “iOS shops” quietly outsource design or see it as a skin on top of code. That usually creates a crappy user experience that customers hate.
Ask:
  • “Do you have in-house designers?”
  • “Can I see 2 or 3 apps where you did both design and dev?”
  • “Do you prototype in Figma / Sketch and test before coding?”
    If they jump straight from idea to coding without clickable prototypes, expect rework and weird UX.
4. How they handle bad news
Everyone looks great when things go right. You want to know how they behave when stuff goes sideways.
Ask specific questions:
  • “Tell me about a project that went off track. What happened and what did you change?”
  • “What do you do when you realize you underestimated something mid-project?”
    If the answer is fluff like “that never happens” or “we always deliver on time,” that’s just marketing speak. Real teams have scars.
5. Technical ownership vs black box
I’d actually go a bit harder than @ombrasilente on transparency. You do not want a black box where you only see builds.
Insist on:
  • Your own accounts: Apple Developer, Firebase, Stripe, etc in your name
  • Access to designs, docs, repos and tickets in real time
  • A simple tech overview doc you can hand to someone else later
    If they resist and want everything on “their” accounts, that’s a hostage situation later when you want to switch vendors.
6. Alignment with your launch & business plan
Most dev shops treat launch as “App Store submission and bye.”
Walk them through:
  • How you’ll acquire users
  • How revenue will work (subscriptions, in-app purchase, one-time, etc.)
  • Any seasonal or hard launch dates
    Watch if they bring up:
  • App review timelines
  • Analytics events
  • Feature flags / staged rollouts
    A team that talks only about shipping v1, and not about week 2, week 4, month 3, is not thinking in terms of your business.
7. Cultural / communication fit
Everyone says they communicate well. Ignore the words and test the behavior:
  • How long did they take to reply to your first email?
  • Did they actually read your brief or respond with generic boilerplate?
  • Did they give you a rough timeline for the proposal and meet it?
    Whatever you see before signing is the best version of them. It usually gets a bit worse later, not better.
8. Don’t chase “iOS only” at all costs
Here I slightly disagree with avoiding anyone who does more than iOS. For many small businesses, you’ll eventually want a simple admin web dashboard, marketing site, maybe Android later.
What I’d avoid is “we do everything on earth” with zero depth.
What I’d look for is:
  • Strong iOS portfolio first
  • Clear story on how they handle backend / web
  • Named tech stack they prefer, not random buzzwords
9. Run a cheap but real pilot
Instead of a vague discovery workshop only, give them something very tangible and small, like:
  • 1 main user flow prototype + basic API contract
  • Or a non-critical internal tool / admin screen
    Evaluate:
  • Did they hit their own mini deadline?
  • How many times did you have to repeat yourself?
  • Was the deliverable actually polished or “good enough”?
You’re not just buying code, you’re buying their habits. Your previous freelancer experience is basically an early, cheap lesson. Use it to be a bit ruthless now: anyone who feels “iffy” during the sales phase is almost always a nightmare mid-project.
If you narrow it down to 2 or 3 companies, send all of them the same short written brief and compare: clarity of questions, structure of proposal, and whether they surface risks on their own. That comparison tells you more than their marketing site ever will.
Quick angle that complements what @cazadordeestrellas and @ombrasilente already covered:
They focused a lot on how to vet. I’d zoom out to whether you even want a “company” at all this time.
1. Decide: company vs curated small team
After a bad solo freelancer, people jump straight to agencies. Not always the best move for a small business app.
  • Agency / company pros
    • Redundancy if one dev is sick or leaves
    • In‑house PM and QA so you are not babysitting
    • More structured delivery, especially around releases
  • Agency / company cons
    • Higher hourly rate, extra account management cost
    • Junior devs often do most of the work on smaller projects
    • You can become “client #27” and lose focus
A curated small team (e.g., 2 iOS devs + 1 designer + 1 part‑time backend/QA, all independent but used to working together) can sometimes give you the same quality and process as a firm, but cheaper and with more attention. The catch: you have to be a bit more hands‑on with coordination.
2. What to actually test in the first 2 weeks
Instead of just interviews and portfolios, design a tiny project “trap”:
  • Give them a very short written spec (one key flow of your real app).
  • Ask for:
    • A simple clickable design prototype
    • A small Swift demo app implementing that flow
    • A 30 minute walkthrough where they explain choices
You’re testing:
  • Do they overcomplicate or keep things pragmatic
  • How they explain tradeoffs to a non‑dev
  • Whether they hide rough edges or talk about them openly
This live behavior is more important than whether they say “we use MVVM and CI” on a slide. Here I partly disagree with the heavy checklist approach: a team can tick every buzzword and still suck at execution.
3. Look at how they estimate and push back
When you send your brief, pay attention to the estimate conversation:
Good sign:
  • They split work into versions (MVP, v1.1, v2)
  • They clearly say “X is expensive, Y is cheaper, here’s why”
  • They call out assumptions and technical risks
Red flag:
  • One single flat price with no breakdown
  • No questions, just “yes, can do, no problem”
  • They promise exact deadlines too early
If both your budget and timeline are fixed and tight, the honest companies will actually give you uncomfortable answers. That discomfort is healthy.
4. Think about maintenance from day 1
Your last experience was missed deadlines and buggy code. A company that only talks about “build & ship” is repeating the same trap.
Ask how they plan for:
  • iOS updates every year
  • Library upgrades (payment SDKs, analytics etc.)
  • Crash monitoring and analytics (Sentry, Firebase, etc.)
Get a concrete example:
“How would you handle a breaking iOS update 6 months after launch?”
You’re looking for a calm, procedural answer, not handwaving.
5. Non‑technical filter: how they talk about previous clients
On calls, listen for:
  • Do they blame “stupid clients” or “scope creeps” constantly
  • Or do they own mistakes and talk about what they changed
Both @cazadordeestrellas and @ombrasilente touched on asking about failed projects; I’d lean even harder on this. A team that speaks respectfully even about difficult clients is usually safer.
Bottom line
Instead of hunting for “the best iOS application development company,” design a short, real‑work audition and judge:
  • How they break scope
  • How they communicate when something is unclear
  • How they handle small pressure in 1–2 weeks
The ones that pass that test are usually a better bet than whoever has the fanciest website or biggest buzzword list.
