I’m trying to build my first Web3 iOS app that connects to a blockchain wallet and interacts with smart contracts, but I’m getting lost on the best tools, SDKs, and security practices to use. Can anyone walk me through a modern, secure Web3 iOS app development setup or share a detailed guide or example project so I don’t miss critical steps?
Short version so you do not get lost:
Pick the chain and wallet setup
- EVM chain is easiest for iOS: Ethereum, Polygon, Arbitrum, etc.
- For wallet connection on iOS, look at:
• WalletConnect v2 (recommended)
• RainbowKit iOS is still new, so stick to WalletConnect SDK.
Tech stack for the iOS app
- Swift + SwiftUI.
- Use:
• web3.swift (https://github.com/skywinder/web3swift)
Good for calling contracts and signing txs.
• Or WalletConnect’s Swift SDK (GitHub - WalletConnect/WalletConnectSwiftV2: WalletConnect Swift SDK v2). - You offload signing to external wallets like MetaMask, Rainbow, Trust.
Basic flow to connect a wallet
- Integrate WalletConnect SDK.
- Generate pairing URI in your app.
- Show QR / deep link to open MetaMask mobile.
- User approves session.
- You store session info securely.
- Then you send JSON RPC requests through WalletConnect.
Interacting with smart contracts
- Get the ABI of your contract.
- With web3.swift:
• Create a Web3 instance with RPC URL (Infura/Alchemy/Ankr).
• Create contract object with address + ABI.
• Call read methods as.read(...).
• For write methods, use:- external wallet signing via WalletConnect
- or your own in-app key (riskier).
Simple example flow for an ERC20 read:
- Function:
balanceOf(address) - Encode params with ABI.
- Send
eth_callvia web3.swift or WalletConnect. - Decode response into BigUInt, then display.
Security basics you must respect
- If you store private keys on device:
• Use Keychain.
• Use Secure Enclave where supported.
• Protect with Face ID / Touch ID. - Do not log private keys, mnemonics, raw txs with sensitive data.
- Validate all user input before sending to RPC.
- Never hardcode mnemonics in source or test builds.
- Use separate RPC keys for dev vs prod.
- Monitor for API key leakage.
UX and safety patterns
- Always show clear info before asking user to sign:
• Network
• Contract address
• Function
• Token amounts and symbols - For contract addresses, hardcode allowlist where possible.
- For generic signing, show the raw message preview.
Dev workflow that helps
- Use a local node or testnet:
• Hardhat or Foundry for local.
• Testnets like Sepolia, Mumbai, etc. - Write unit tests for contracts first.
- Then integrate iOS to hit those contracts on testnet.
- Use Charles Proxy or Proxyman to inspect RPC calls from the app.
Minimum POC you can target
- One button: “Connect wallet” via WalletConnect.
- Show connected address and chain.
- Call a
viewfunction on your contract likegetUserScore(address). - Display result.
- Then add a “Write” action, like sending a small testnet token or calling
setScore.
Libraries and links worth reading
- WalletConnect v2 docs: Page Not Found
- web3.swift: https://github.com/skywinder/web3swift
- Ethers.js docs for ABI ideas: https://docs.ethers.org
- Solidity docs: https://docs.soliditylang.org
If you share which chain and what contract actions you want, people can throw more concrete code samples.
@nachtdromer already laid out a solid path, so I’ll try to fill in the gaps and give you some alternative angles + “gotchas” people usually hit on their first Web3 iOS app.
1. Don’t pick tools first, pick the app shape first
Before arguing WalletConnect vs web3.swift vs whatever, decide:
- Do you want:
- A pure dApp browser style app (like a vertical slice of MetaMask browser)?
- A single‑purpose app that only talks to your contracts?
- A wallet-like app that may later hold keys on-device?
That choice matters more than the exact SDK:
- If it’s single‑purpose, you can:
- Hardcode network(s)
- Hardcode contract addresses
- Aggressively restrict what can be signed
- Simplify your UI and security model a ton
For a first app, I’d strongly suggest “single‑purpose” instead of trying to be a generic wallet/dApp browser.
2. Alternative to web3.swift: thin client + backend
Slightly disagree with going all in on web3.swift on day one.
If your app is not a wallet itself and you want more control / easier debugging:
- Put the “Web3 brain” on a small backend service:
- Node with
ethers.jsor Python withweb3.py - Your iOS app only:
- Calls your backend for reads
- Uses WalletConnect for writes / signing
- Node with
Pattern:
- iOS:
GET /userScore?address=0x...→ backend doescontract.getUserScore(address)- For writes:
- iOS constructs the call data (or even just picks from a few allowed actions)
- User signs tx via WalletConnect and sends to RPC
Why this helps:
- You avoid stuffing ABI encoding/decoding logic into Swift early on.
- Easier to hotfix behavior without shipping a new iOS build.
- You can centralize rate limiting, API key protection, and logging on your backend.
This is especially nice when you’re still learning both iOS and Web3 and don’t want to fight the tooling on two fronts.
3. Contract design to make your iOS life easier
Most mobile dev friction comes from badly shaped contracts.
When you write or choose the smart contract:
- Prefer:
viewfunctions returning simple structs or tuples with few fields.- Functions like
getUserState(address)instead of 10 different getters.
- Avoid:
- Functions returning giant arrays or nested structs that blow up decoding.
- Overly generic “execute” patterns that make UX impossible to explain.
For a first app, design the contract around these ideas:
Single “state” getter per user, e.g.:
function getProfile(address user) external view returns ( uint256 score, uint256 level, string memory nickname ); -
Simple write functions like:
function setNickname(string calldata nickname) external; function incrementScore(uint256 amount) external;
This keeps your iOS ABI calls very straightforward, no weird dynamic type juggling.
4. Wallet interaction UX: focus here way more than you think
Everyone focuses on “can I connect” and “can I read the contract” and then ends up with a terrible signing UX.
A few patterns that help:
- Show a clear preview before wallet opens:
- Network name (e.g. “Ethereum Sepolia testnet”)
- Contract name + last 4 of address
- Method name in human language: “Update Nickname” not
setNickname(string) - Exact token amount & symbol for transfers
- Add explicit constraints in code:
- If a function is supposed to send at most 0.01 ETH, enforce that in the app before creating call data.
- If user tries to send to an arbitrary address but your app is only for interacting with one contract, just block it.
- Cache & reuse the WalletConnect session:
- Don’t force the user to reconnect on every app open unless there’s a real reason.
This stuff matters more than which library you pick. People will forgive a slightly clunky flow, not mysterious signing prompts.
5. Security: what people actually mess up
Beyond what @nachtdromer wrote, these are the ones I see bite beginners:
Blindly trusting RPCs / APIs
- Never assume the RPC is honest.
- For critical flows:
- Confirm important data in multiple ways if possible (e.g. known contract state vs what user sees).
- Treat RPC like a data source, not a source of truth.
Mixing dev keys & prod keys
- Have separate Infura/Alchemy keys for:
- dev / staging
- prod
- Put them in separate projects, not just env flags.
Insecure feature flags
- Don’t rely on client-side flags to “hide” test features that can interact with real money.
- Anything in the client can and will be flipped by someone.
Push notifications & deep links
- If you use push or deep links to trigger actions, never encode sensitive info directly.
- Treat incoming deep links as untrusted input, validate everything.
6. Testing strategy that actually works
Concrete, non-fluffy setup:
- Contracts side:
- Use Foundry or Hardhat.
- Write tests first for:
- happy paths
- revert conditions
- Deploy to a testnet like Sepolia.
- Simulate real users early:
- Create a few test wallets.
- Seed them with testnet funds.
- Run through the entire flow as if you’re a user, including switching wallets.
On iOS side:
- Use dependency injection for your Web3-related components:
- So you can swap a “mock blockchain” in tests without hitting real RPC.
- For critical flows, snapshot / record RPC payloads in dev so you can compare them later when something breaks.
7. A realistic first milestone
To keep you from drowning, I’d structure your first version like this:
V0 (weekend level):
- Hardcode:
- Sepolia RPC URL
- One contract address
- Features:
- “Connect wallet” with WalletConnect
- Show connected address, current network name
- Call one read function like
getUserProfile(address)and display values
V1:
- Add one safe write function:
- Example: “Set nickname”
- Confirm:
- Limit nickname length in app
- Show a nice signing preview
- Handle pending → confirmed → failed states in UI
V2:
- Add network switching (still testnets only).
- Add basic error analytics (e.g. logging non-sensitive errors to a service).
If you try to jump to “complex DeFi dashboard dApp” in V0 you’re going to have a bad time.
8. Where you might want more specific help
If you share:
- Which chain you picked
- Whether you’re:
- Only talking to your own contract
- Or also integrating existing protocols (Uniswap, Aave, NFTs, etc.)
- One or two example contract functions you want to call
Then people can drop more targeted snippets, like “this is exactly how you encode and call getUserScore in Swift” or how to shape your JSON RPC payload with WalletConnect.
Skip the tooling debate for a second and design around constraints specific to iOS + Web3. That is where most first‑time projects blow up.
1. Decide your threat model first, not last
Before arguing SDKs:
- Who are you protecting against?
- Curious user poking around dev tools
- Malicious wallet / RPC
- Lost phone / stolen device
Concrete takeaways:
- If users connect external wallets only:
- Do not store anything sensitive except WalletConnect session data.
- Treat the app as “stateless” regarding funds.
- If you ever plan local keys, design now for:
- Key rotation
- Recovery flows
- Device change / restore behavior
Most people bolt this on later and regret it.
2. Alternative flow: “transaction templates” instead of free‑form calls
@byteguru and @nachtdromer both assume you will be handcrafting JSON RPC or using generic ABI calls.
For a first iOS Web3 app, I’d strongly prefer a template model:
- Each supported action is a predefined “template”:
- Example:
UpdateNicknameTemplate,ClaimRewardTemplate,TransferPointsTemplate.
- Example:
- Each template:
- Knows the target contract
- Knows the method signature
- Validates inputs locally
- Produces the final calldata
Why this is nicer on iOS:
- You do not sprinkle ABI knowledge all over view models.
- You can unit test each template with fixtures.
- Easier to audit what your app is actually able to do.
You can combine this with WalletConnect or web3.swift, no conflict.
3. How to keep your codebase from turning into a Web3 spaghetti ball
Things I’d structure differently from what was suggested:
Avoid:
- Calling web3.swift or WalletConnect from SwiftUI views directly.
- Passing raw ABI strings around.
Instead:
Create thin layers:
BlockchainClient- Interface with methods like
fetchUserProfile(address) - No SwiftUI, no WalletConnect details inside.
WalletClient- Responsible for:
- Connecting
- Getting current address
- Requesting signatures / txs
- Behind the scenes uses WalletConnect SDK.
- Responsible for:
ContractAction/ templates from above.
Your SwiftUI layer then only talks in domain language:
viewModel.loadProfile()
viewModel.updateNickname('alice')
Not:
web3.eth.call('0xabc...', '0x123...', ...)
This is boring architectural stuff, but it prevents rework once your app grows.
4. Handling “real world” failures users will actually hit
The existing answers explain happy paths well. The ugly bits:
- Wallet app dies mid‑signature
- Network switching in wallet vs your app’s idea of “current network”
- Pending tx that hangs for minutes
Suggestions:
- Maintain a local transaction history:
- Store:
- nonce
- hash
- human readable label
- created time
- Poll status periodically, or when app foregrounds.
- Store:
- Detect chain mismatch:
- When session is active, always read
chainIdfrom WalletConnect state. - Block actions if your app expects chain X and the wallet is on chain Y.
- “Stuck tx” UX:
- Show a “Still pending” state with a refresh action.
- Do not let the user spam the same tx blindly; at least warn them.
This is the part that makes your app feel trustworthy.
5. Frontend‑only vs backend‑assisted: pick deliberately
I disagree slightly with going backend by default or frontend only by default. Use a simple matrix:
| Requirement | Good choice |
| Purely public reads, low logic | Frontend only |
| Complex aggregation / analytics | Backend with ethers/web3 |
| Need for caching / rate limiting | Backend |
| Ultra low latency reads | Mixed: cached backend + direct |
You can start frontend‑only, then later add a tiny backend for expensive reads while keeping writes strictly user‑signed via wallet.
6. Tooling & library pitfalls that bite on iOS
Some things that rarely get mentioned:
- ABI decoding with dynamic types in Swift can be painful:
- Favor simpler, fixed‑shape return types in your contracts.
- JSON RPC errors are extremely vague:
- Wrap responses in your own error enum with user‑friendly messages.
- Log the raw error only in dev builds.
Also, if you ever adopt a product like WalletConnect iOS bridge (placeholder title here, since you mentioned no specific product name):
- Handles multi‑wallet interoperability.
- Abstracts most of the transport details.
- Familiar UX pattern for Web3 users.
- Version churn; keeping up with protocol updates.
- Adds complexity compared to a single‑wallet deep link.
- Debugging session issues can be time‑consuming.
Competitors to that approach are essentially what @byteguru leaned into (direct web3.swift usage) and what @nachtdromer described (WalletConnect focused, more SDK‑centric). Both are valid paths, just different tradeoffs on complexity vs control.
7. Smart contract “API design” checklist for iOS clients
When you or your solidity dev writes the contracts, sanity check these:
- Avoid function overloading for anything you will call from mobile.
- Avoid big unbounded arrays in return values. Paginate or add offsets.
- Prefer
viewhelpers tailored for the app, not just generic getters. - Emit meaningful events so you can later:
- Index them
- Build history views via a backend indexer
Treat the contract as an API that must be pleasant for a mobile client to talk to.
8. What to actually ship as your first slice
If you want a concrete target that uses the ideas without rehashing what is already said:
- One contract with:
getProfile(address)returning a small tuplesetNickname(string)as only write
- In iOS:
- A
ProfileScreenthat:- Reads address from wallet
- Calls
getProfilethrough aBlockchainClient
- An “Edit nickname” flow:
- Validates nickname
- Creates a
SetNicknameActiontemplate - Sends via
WalletClient.requestTransaction(...)
- A
Ship that, live with it for a bit, then layer in more advanced things like multiple chains or NFTs.
If you share the chain + 1–2 actual function signatures you plan to use, it is straightforward to sketch the data models and transaction template structure around them.
