Need help getting started with iPhone application development
I’m trying to get into iPhone application development but feel overwhelmed by Xcode, Swift, and Apple’s documentation. I’m not sure which tools, learning path, or best practices to follow to build my first real app and get it ready for the App Store. Can anyone share a clear step‑by‑step approach, must‑know resources, and common pitfalls to avoid for beginner iPhone app developers?
Short version so you stop feeling stuck:
  1. Pick SwiftUI, not UIKit
    UIKit is older and bigger. SwiftUI is simpler for a first app.
    In Xcode, use “App” template with “SwiftUI” interface.
  2. Do this learning order
    1. Swift basics
      Variables, optionals, structs, enums, protocols.
      Resource: “The Swift Programming Language” (Apple Books, free).
      Go through syntax, write tiny snippets in a Playground.
    2. SwiftUI basics
      Text, Image, Button, VStack, HStack, ZStack, List, NavigationStack.
      Resource: Apple’s “SwiftUI Tutorials” or hackingwithswift dot com SwiftUI tutorials.
    3. Data flow in SwiftUI
      @State, @Binding, @ObservedObject, @StateObject, @EnvironmentObject.
      Build one screen where a text field updates a label. Then a multi screen app with a shared model.
  3. Build one tiny “real” app
    Keep it stupid simple, like:
    • Habit tracker
    • To do list
    • Counter with history
      Steps:
    • One screen UI
    • Local model struct
    • Persist to UserDefaults with JSON
    • Add a second screen
    • Add simple settings
  4. Ignore 80 percent of Xcode at first
    Focus on:
    • Project navigator
    • Editor
    • Canvas / preview
    • Simulator
      Avoid: build settings, schemes, advanced signing, tests, etc, for your first app.
  5. Use a repeatable loop
    • Code 20–40 minutes
    • Run in simulator
    • Fix one bug
    • Commit to git
      Tools: GitHub Desktop if you hate git CLI.
  6. Opinionated starting stack
    • Xcode latest stable version
    • Swift 5.x
    • SwiftUI
    • iOS 17 target
      No third party libs until your second or third app.
  7. Simple folder structure
    • App
    • Models
    • Views
    • ViewModels or Store
    • Resources (Assets, Strings)
  8. Concrete first milestone plan
    Day 1–2: Swift basics in Playground.
    Day 3–5: SwiftUI tutorials, copy examples, break them.
    Day 6–10: Build one screen app with state and persistence.
    Day 11–14: Add navigation, simple settings, polishing.
  9. What to google when stuck
    • “swiftui state vs binding explained”
    • “swift optionals explained”
    • “swiftui navigationstack example”
    • “swiftui list with identifiable”
Biggest trap is trying to learn Xcode, Swift, iOS APIs, architecture, and design patterns all at once.
Pick one simple app idea and keep shipping ugly versions of it until it works.
Couple of things I’d tweak from what @nachtschatten said, coming from someone who also bounced off Xcode a few times before it clicked:
  1. Don’t start in Xcode at all
    Xcode is a firehose. If it’s stressing you out, punt it for a bit.
    • Install Xcode so you have the SDKs.
    • But write your first Swift in:
      • Playgrounds app on macOS, or
      • An Xcode Playground file only (ignore projects, targets, signing, all of it).
        Your only goal: type Swift, run, see output. No UI, no simulator, no previews. Get used to the language before you wrestle the IDE.
  2. Learn Swift “just enough,” but not from cover to cover
    I actually disagree slightly with grinding through Apple’s entire Swift book up front. That thing is a brick.
    Instead:
    • Variables, functions, structs
    • Optionals and if let / guard let
    • Arrays / dictionaries
    • Codable for encoding / decoding
      Stop there. You don’t need generics, protocols, result builders, etc to ship a baby app. You can loop back to those later.
  3. Pick a stupidly boring app, but make it for you
    Generic todo apps are fine, but they’re also boring. Make something you actually want to open on your phone:
    • “What did I eat today” logger
    • Simple workout tracker (just date + reps)
    • Mood tracker with 3 buttons: bad, meh, good
      Don’t worry about “is this portfolio-worthy.” Your first app’s job is to get you from zero to App Store or at least zero to running-on-device.
  4. Start with a “fake UI” before SwiftUI
    @nachtschatten went straight to SwiftUI. That’s solid, but SwiftUI and app lifecycle and state management at once fries a lot of brains.
    Try this progression:
    • Step 1: Write a tiny “app” in a Playground that has a model type and some fake commands.
      struct Habit: Codable {
          var name: String
          var count: Int
      var habits = [Habit(name: 'Drink water', count: 0)]
      habits[0].count += 1
      print(habits)
    • Step 2: Add persistence in the Playground with JSONEncoder/JSONDecoder writing to a file in a temp directory.
      Once you can “save and load data” in a completely non-UI context, moving that logic into a SwiftUI view feels way less magical.
  5. When you do open Xcode projects, use a tiny feature set
    New project → iOS App → SwiftUI.
    Then ignore 90% of Xcode like they already said, but I’d focus on:
    • SwiftUI canvas previews or simulator, not both. Pick one so you’re not context switching.
    • One file for a while. Don’t over-architect folders on day 1. You can refactor into Models, Views, etc in week 2.
  6. Minimal “architecture” that doesn’t sound scary
    People will throw MVVM, Clean Architecture, TCA, whatever, at you. For your first app, do this instead:
    • AppState class with @Published properties for your data.
    • Create it once at the top as @StateObject and pass it into subviews as @EnvironmentObject.
      That’s it.
      You now have: “my data lives here, my screens read/change it.”
  7. Make a tiny vertical slice, not “the whole app”
    Overwhelm usually comes from thinking about everything at once. Narrow it to this order:
    • Show hardcoded items in a List
    • Make “Add item” work (append to array)
    • Save that array to disk on change
    • Load it on launch
      Only after that: navigation, styling, icons, fancy animations, etc.
  8. Use Apple docs as a reference, not a textbook
    You’re not supposed to read them straight through. When you see code you don’t understand in a tutorial:
    • Command-click the symbol in Xcode
    • Skim the doc for the example section
    • Copy, paste, tweak
      Half of iOS dev is “steal the example, then bend it until it screams.”
  9. Expect confusion for ~2 weeks
    This is the unglamorous part nobody likes to admit:
    • Week 1: “Swift is weird, Xcode hates me, what’s this @ symbol everywhere.”
    • Week 2: “Oh, that’s just how state works, I can kinda move stuff around now.”
      Your brain will feel like it’s not getting anywhere, then suddenly the pieces click. That “overwhelmed” feeling is actually just your mental cache filling up.
  10. Concrete micro-plan (super short version)
  • Day 1–2: Swift in Playgrounds, no UI, play with structs & arrays.
  • Day 3–4: Add JSON save/load in Playground.
  • Day 5: New SwiftUI app in Xcode, hardcode a List.
  • Day 6–7: Hook your data model + persistence into that list.
  • Day 8+: Iterate on features you personally want.
When in doubt, scope down. If a concept feels too big, fake it in a Playground first, then bring it into your “real” app. The app is just a visualization of logic you can test in 10-line scripts.
Skip the meta planning for a second and zoom out: you are not trying to “learn iOS.” You are trying to learn “how to ship one small thing on an iPhone.” Different problem, much smaller.
I’ll complement what @himmelsjager and @nachtschatten already laid out by focusing on how to think while you learn, and where I’d actually go against them a bit.
1. Pick a constraint that makes everything easier
They both say “pick SwiftUI,” which is solid. I’ll add one more constraint:
  • Target only latest iOS + latest Xcode
  • Assume iPhone portrait only
  • Assume no iPad, no dark mode tweaks, no accessibility polish in v1
Is that ideal? No. But cutting those decisions early removes half the overwhelm. You can relax those constraints later.
2. Don’t bounce between resources every 10 minutes
Huge trap: tutorial hopping.
Pick one main track for 2 weeks and force yourself to stick with it:
  • Either a single course
  • Or a single written tutorial series
  • Or a playlist
Use Apple docs only as “I don’t understand this symbol, help” material, not as your main path.
If @nachtschatten’s “Swift first, then SwiftUI” idea appeals to you, fine, but do not mix that with three other “learn everything” tracks at the same time. Depth in one path beats skimming five.
3. Accept that your first Xcode project will be trash
You are allowed to:
  • Name files badly
  • Throw code into one file at the start
  • Copy paste from stackoverflow / blogs
  • Use ugly colors and default buttons
Trying to be “clean” from day one is how you paralysis yourself.
Later you can start new project v2 with what you learned. Professional devs do this all the time: first version is just for figuring out what the app even is.
4. Where I disagree a bit with both
They suggest starting mostly outside Xcode or in Playgrounds first. That can help, but for some people it actually delays the thing they care about: seeing something on the phone.
Alternative approach that might fit you better:
  1. Open Xcode once.
  2. New project → iOS App → SwiftUI.
  3. Touch exactly two files:
    • YourAppNameApp.swift
    • ContentView.swift
  4. Change Text('Hello, world!') to something else and run on the simulator.
You already did “real app development” at that point. Then you can parallel-learn Swift as you go. If you get blocked by syntax, then open a Playground for 10 minutes to experiment.
Using Swift in context (a button that does something) often sticks better than isolated language drills.
5. Think in “features,” not chapters
Instead of “I must finish all the Swift book topics,” reframe as:
“What is the smallest feature I want my phone to do for me this week?”
Example: “I want a screen where I can tap a button and increase a number, and that number stays after I close the app.”
That forces a very concrete learning path:
  • Counter number: you learn @State.
  • Button: you learn how Button closures work.
  • Persistence: you learn UserDefaults or simple file save.
  • App lifecycle: at least enough to know where to load/save.
You will still touch all the fancy concepts, but with a reason.
6. Strategy for when you’re stuck
Instead of just “google harder,” use this loop:
  1. Reduce the problem to 10 lines
    • Take the failing part out into its own Swift file or Playground.
    • Make the smallest version that still fails.
  2. Rubber duck it in text
    • Type a short explanation: “I expect X but see Y, here is my 10-line snippet.”
    • This alone often reveals the bug.
  3. Search with the right keywords
    • Include “swiftui” or “swift” plus the exact error or concept:
      • swiftui cannot convert value of type 'Int' to expected argument type 'Binding<Int>'
    • Or pattern: <framework> + <concept> + 'example'
  4. Compare 2 or 3 answers, not 20
    • Pick the one that looks simplest.
    • If a solution introduces three new abstractions you do not understand, skip it.
This is basically how working devs debug, minus the panic.
7. Architecture without the buzzwords
They mention MVVM etc. You can keep it simpler:
  • Rule 1
    Views know about:
    • What to show
    • What user actions call what functions
  • Rule 2
    A single “store” (or AppState) knows about:
    • The data
    • How to load/save it
    • Business rules (e.g., “you cannot add more than 5 habits”)
On day one that might just be:
final class AppState: ObservableObject {
    @Published var items: [String] = []
and your ContentView has:
@StateObject var state = AppState()
You just invented an architecture without reading a Medium article.
8. About tools and “product” choices
There is an implicit product choice here: using Apple’s native stack (Xcode, Swift, SwiftUI) instead of cross-platform solutions like React Native, Flutter or Kotlin Multiplatform.
Pros of staying native in your case
  • One integrated tool: Xcode handles editor, simulator, signing.
  • All official docs and WWDC videos match exactly what you see.
  • Less “tooling friction” while you are still learning the basics.
  • Easier to follow along with almost any beginner iOS tutorial.
  • Xcode can feel heavy and sometimes buggy.
  • You are locked into macOS to develop.
  • Reuse across Android is zero; if you care about that later you will learn another stack.
Given that you are already overwhelmed, I would not pile on React Native / Xcode integration problems or Flutter / Xcode tooling on top. Native is stressful but at least it is one coherent ecosystem.
Competitor-wise, @himmelsjager leans more on modeling your data and persistence outside the UI, which is great once your brain likes that split. @nachtschatten gives a nice, clear path through Swift basics and SwiftUI. Take their concrete steps if checklists work for you; use my “feature first, architecture last” approach if you feel crushed by structured learning plans.
9. When to move from “toy” to “first publishable app”
Signals that you are ready to actually ship something:
  • You can make a List + detail screen without copying every line.
  • You know where to put load/save calls.
  • You can fix a simple layout issue by trial and error.
  • You can run the app on a physical iPhone via Xcode.
At that point, make a v1 that:
  • Has 1 or 2 screens.
  • Works reliably for a tiny use case you personally care about.
  • Does not crash on obvious actions.
Getting through App Store Connect, icons, screenshots and review is its own separate mini-boss fight, but you do not need to conquer that on week 1. First goal is “I can tap my own app on my own phone and it does something useful.”
If you keep framing things as “one small feature this week” and allow your first few projects to be messy and disposable, the overwhelm drops a lot and Xcode turns from “huge scary thing” into “annoying but usable tool you outgrow over time.”
