I accidentally lost files from my USB flash drive, and it’s formatted as exFAT. I need reliable USB drive recovery software that actually works with exFAT flash drives because the documents and photos on it are important. Looking for recommendations on safe data recovery tools that can restore deleted files from an exFAT USB drive.
I’ve gone through more USB recovery apps than I want to count. Some I tried out of habit. Most came from messing up a flash drive at the worst time. I’ve dealt with deleted folders, drives I formatted by mistake, broken file systems, and USB sticks that still showed up in Windows but looked empty. Every time, I ended up installing another tool and checking whether it could recover anything real, or whether it was all screenshots and no substance.
After enough trial and error, one pattern stood out. A lot of these tools do fine when the job is easy. Delete a few files, scan, restore, done. Things change fast once the USB drive has been formatted, the partition table is damaged, or the file system turns RAW. That’s where the gap shows up.
If you want one pick for most people, I’d go with Disk Drill.
What kept pushing it to the top for me was range. I used it on plain deletion cases, on formatted flash drives, on lost partitions, and on drives with corrupted file systems. It held up better than most across all of those. It also recognizes a long list of file types, and the preview feature saves time. If you scan a USB stick and preview opens the files you care about, you already know the scan found something useful. No guessing.
One part I kept coming back to was the byte-for-byte backup option. USB sticks fail in messy ways. I’ve had some disconnect in the middle of a scan. Others got slower every time I plugged them in. Making an image first gave me breathing room. You work from the copy, not the unstable drive. If your flash drive is acting weird, do this first. It matters.
If you want a free option, Recuva still earns a mention. I’ve used it on healthy USB drives where files were deleted recently, and in those cases it did the job. The layout is simple. The scans are quick. You won’t spend half an hour figuring out where the buttons are.
Still, I wouldn’t lean on Recuva once things get ugly. If the drive was formatted, if partitions got messed up, if the volume shows as RAW, or if corruption is deeper than a normal delete, it starts to fall off. In those cases, Disk Drill usually did better for me.
A few things I learned the hard way before running recovery software:
Stop writing to the USB drive right away. Deleted files often stay there until new data lands on top of them. If you keep copying stuff over, your odds drop fast. Also check Disk Management. If the drive appears there with about the right capacity, software recovery still makes sense. If Windows shows the wrong size, or doesn’t detect it at all, you might be dealing with hardware trouble instead.
Save recovered files somewhere else. Don’t put them back onto the same flash drive. I did this once years ago. Bad move. You risk overwriting the exact data you’re trying to save.
Recovery software has limits. I’ve seen people burn hours testing five different apps and get nowhere, then admit they had no backup. The 3-2-1 backup rule still beats every recovery tool I’ve touched. Keep three copies of your data, store them on two kinds of media, and keep one copy off-site. Boring rule, yep. Still the one thing that saves you when the drive is toast.
If your USB is still detected and shows the right size, exFAT recovery is usually worth trying. For exFAT flash drives, Disk Drill is one of the safer picks because it handles deleted files, quick format cases, and damaged exFAT volumes better than a lot of the old free tools. I don’t fully agree with @mikeappsreviewer on Recuva getting a mention first, becuase on exFAT sticks I’ve seen it miss file trees and lose filenames more often than people expect.
What I’d do.
- Stop using the USB now.
- Plug it in once, confirm it appears in Disk Management.
- Scan it with Disk Drill.
- Recover files to your PC, not back to the USB.
If the scan shows previews for your photos and docs, your odds are decent. If the drive drops out, freezes, or asks to format, I’d skip repeated rescans.
If you want a quick look at how it works, this Disk Drill review for USB and exFAT recovery is decent, watch this Disk Drill recovery walkthrough.
For free-only options, PhotoRec sometimes pulls files from exFAT, but the file names and folders are often a mess. It’s more of a last resort tbh.
If it’s specifically an exFAT USB flash drive, I’d look at tools that actually understand exFAT metadata decently, not just generic “deleted file” recovery. That’s where I slightly part ways with @mikeappsreviewer and @sonhadordobosque. They’re not wrong about Disk Drill, but for exFAT I’d also put R-Studio and UFS Explorer on the short list if the folder structure matters and not just raw file carving.
Disk Drill is still probly the easiest recommendation because it handles exFAT USB recovery well, previews files, and doesn’t feel like it was designed in 2009. If you want something simpler than the more forensic stuff, it’s a solid pick for deleted files, accidental format, and corrupted exFAT volumes.
R-Studio is stronger when the flash drive has nastier logical damage, but it’s less beginner-friendly. UFS Explorer too, kinda powerful, kinda nerdy.
One thing I disagree on a bit: PhotoRec is not my “last resort” only because it’s bad. It’s a last resort because it ignores filenames/folders a lot, but for photos on exFAT it can sometimes yank out stuff other apps miss.
Also, if the USB is physically flaky, don’t keep plugging it in over and over. That’s how a recoverable problem becomes a dead stick.
For a real-world thread on Disk Drill for USB recovery, check Reddit discussion about Disk Drill for important USB file recovery.
Short version:
- Easy/best balance: Disk Drill
- More advanced: R-Studio
- Raw photo salvage: PhotoRec
- Avoid junk “free recovery” apps with fake scan results, tons of them are sketchy as hell
If the USB still mounts normally and exFAT isn’t showing total nonsense capacity, I’d focus less on “which app is most famous” and more on whether it can preserve exFAT metadata decently.
I partly agree with @sonhadordobosque, @sognonotturno, and @mikeappsreviewer, but I’m a little less enthusiastic about jumping straight to raw-carving tools unless the normal scan clearly fails. On exFAT, once you lose names and folders, sorting the recovery can become its own nightmare.
My take:
Disk Drill
- Good exFAT support in normal real-world cases
- Clean preview system, useful for checking docs/photos before recovery
- Handles deleted files, quick format cases, and some corrupted volumes better than basic freebies
- Can create a byte-level backup, which matters if the flash drive is unstable
- Not the cheapest route if you need full recovery
- Deep scans can return lots of file fragments and duplicates
- If the USB has serious controller failure, software won’t save you
I’d put it in the “best balance” category for most people.
If folder structure matters a lot, I’d also consider R-Studio before wasting time with weaker tools. If you only care about getting photos back no matter how messy the result is, PhotoRec still has a place. I disagree slightly with people who dismiss it too fast. It’s ugly, but sometimes ugly works.
One more thing people skip: check the SMART-like behavior of the stick by watching for slow reads, disconnects, or Windows hanging when you open it. If that happens, don’t keep rescanning. Image the drive first if possible, then recover from the image.
So yeah, for an exFAT flash drive specifically, Disk Drill is a solid first choice, not because it’s magic, but because it usually hits the sweet spot between usable, capable, and not overly forensic.
