I’m planning to build a new iPhone app for my small business but I’m overwhelmed by how many iPhone application development companies are out there. I’m worried about picking the wrong partner, wasting money, and ending up with a low‑quality app that doesn’t get approved or used. What should I look for in a reliable iPhone app development company, and are there any red flags or must‑ask questions before signing a contract?
Here is a simple way to filter iPhone app dev companies so you do not burn cash.
Start with business fit
• Ask what they know about your industry and your type of customers.
• Ask for 2 or 3 examples of apps for small businesses, not giant brands.
• If they talk only about features and not outcomes like leads, sales, repeat use, move on. -
Check real experience, not hype
• Ask for links to live apps in the App Store. Download them. Test speed, bugs, ease of use.
• Ask what in those apps they were responsible for, design, backend, iOS only.
• Ask how many iOS apps they shipped in the last 12 months. Under 3 is a yellow flag. -
Process and communication
• Ask how they handle requirements. Do they write simple user stories, user flows, wireframes.
• Ask how often you get updates. Weekly demo calls are ideal for small projects.
• Ask what tools they use for tracking work. Jira, Trello, ClickUp, anything is ok, silence is not. -
Scope and budget clarity
• Force them to break the quote into milestones. For example- Discovery and wireframes
- Design
- Development for v1
- Testing and App Store submission
• Each milestone should have a fixed cost and clear deliverables.
• Ask what is out of scope. This is where many agencies hide extra costs.
Code ownership and IP
• The contract should say you own the source code, designs, and accounts.
• The Apple Developer account must be in your name or your company name.
• Ask where the code is stored. You should have access to GitHub or GitLab.
• No access to repo until the end is a bad sign. -
Maintenance plan
• Ask what happens after launch. Bug fixes for how long and on what terms.
• Ask what they do when iOS versions change and break things.
• Get a simple support package in writing, even 5 to 10 hours per month. -
Tech checklist
• Confirm they use Swift and not only old Objective C, unless you have a special case.
• Ask how they handle analytics. At minimum, Firebase or similar.
• Ask about crash reporting. If they shrug, that is a no.
• Ask how they handle security for logins, payments, and data storage. -
Red flags
• “We can do anything, no problem” with no tradeoffs or questions.
• Huge range quote like 10k to 80k. Shows they did not think it through.
• No written scope, only a one page “we build your app” document.
• They push you to add features instead of trimming for a first version. -
How to compare 3 vendors fast
• Send all of them the same 1 to 2 page brief. Problem, target users, core features, budget range.
• Ask each for- Rough timeline
- High level feature breakdown
- Estimated cost for v1 only
• Toss the lowest and highest if they are way off from the middle, then compare the two left by how they communicate.
Budget sanity for small business apps
Rough ballparks from what I have seen
• Simple app with login, few screens, basic API: 8k to 20k with a small agency or strong freelancer team.
• More complex, payments, third party APIs, admin panel: 20k to 60k.
If they want 80k plus for a very simple MVP, you need to walk. -
Do a small paid test first
• Before you hand over full project, pay for a short discovery phase. For example, 1 to 2k for- Wireframes
- Basic user flows
- Tech approach
• Use this to see how they think and how they communicate. If they are slow or messy here, the full build will hurt.
Personal trick that saved me
When I picked a dev partner, I added one small but clear “trap” requirement in the brief, for example “offline mode with partial sync” or “role based permissions in admin”.
• Good teams asked questions and flagged risks.
• Weak ones said sure and gave no detail.
The ones that pushed back with specifics turned out better.
If you want to feel less overwhelmed, pick three vendors, run the same short brief and list of questions with all three, then pick based on
- Clarity of scope
- How they explain tradeoffs
- How they plan to keep you in the loop
Fancy portfolio is nice. Structured process and honest pushback protect your wallet.
Couple of extra angles to what @vrijheidsvogel already said (solid checklist btw), without repeating the same “ask for apps, ask for milestones” script.
Start from YOUR constraints, not their pitch
Before talking to anyone, write down:- Max budget you’re honestly willing to lose if it goes bad
- Latest acceptable launch date
- 3 must-have features and everything else as “nice to have”
Then see who respects those constraints instead of trying to upsell you into a monster app. If they won’t help you cut scope to hit your budget/time, they’re not a partner, they’re a vendor hungry for billable hours.
Look at how they say no
A team that never pushes back is actually more dangerous than one that argues a little.- Ask for something obviously scope-creepy (like “I want something like Uber but for my bakery”)
- Good company: “Here’s what’s realistic for v1, here’s what we’d postpone.”
- Bad company: “Sure, no problem, we can do that too” with no mention of extra time/cost.
A controlled “no” or “not now” is a green flag.
Test their product thinking, not just coding
Most small business apps die because they’re built as feature lists instead of solving a real problem.
In your first call, ask:- “How would you measure if my app is successful in the first 3 months?”
- “If you had to remove 30% of my features, what would you cut first and why?”
If they can’t talk about metrics (conversion, retention, repeat orders, etc.) and tradeoffs, they’re just order-takers.
Don’t over-focus on “number of apps shipped”
I slightly disagree with the “under 3 in last 12 months is a yellow flag” part. Sometimes a very small, senior team ships fewer but higher quality apps and spends months on one project.
What matters more:- Depth of one or two similar projects
- Clients willing to get on a call and say “yeah, they actually delivered and still pick up the phone”
Actually talk to past clients
Not just “references on a slide.” Ask to speak to:- One happy client
- One where things were rough or delayed
Questions to ask them: - “When something went wrong, how did they react?”
- “Did the final invoice match what you expected at the start?”
- “Do you still work with them or did you move on?”
The vibe in those answers tells you more than any proposal.
Align incentives with a simple structure
If you can, structure payment like:- Small discovery fee up front
- 40% on dev kickoff
- 40% on testable version in your hands
- 20% on App Store submission
And tie each to something you can touch: clickable prototype, working build, etc. Not just “50% when we’re halfway.” “Halfway” is where budgets go to die.
Think long term: who will touch this code next
Even if they’re great, you might switch partners later. Ask for:- Clean documentation in a shared place (Notion, Confluence, even Google Docs)
- Clear instructions to set up the app from scratch
- Basic architecture diagram
This is boring, but it avoids the “hostage app” situation where no one else can maintain it without rewriting half of it.
Keep business risk low with a tiny pre-project
I’m 100% aligned with the “do a small paid test first,” but take it one step more practical:- 1 to 2 week engagement
- Deliverables: clickable prototype in Figma + rough tech plan + rough roadmap for v1 / v2
- Cap the price and time strictly
You’re basically buying a “first date” instead of a wedding. If communication is slow or messy here, it won’t magically improve later.
Reality check your own expectations
To avoid disappointment:- You won’t get a world-class, pixel-perfect, “top 10 in the store” app for a shoestring budget and a one-month deadline.
- You can get a lean, useful MVP that actually helps your business if you focus on one or two strong use cases.
Walk into calls saying: “I want the smallest version of this that still moves the needle for my business.” See who actually honors that.
If you post a short version of your idea (industry, 3 core features, rough budget range), folks here can give you more targeted feedback like “this sounds like a 10–20k thing” or “you’re in 40k+ territory.” That rough sanity check helps filter out quotes that are clearly ridiculous before you get emotionally attached to any one agency.
