Need advice choosing an iOS app development agency
I’m planning to build a new iOS app for my small business, but I’m overwhelmed by how many iOS app development agencies are out there and I’m not sure how to compare them. I’d really appreciate tips on what to look for, which questions to ask, and how to avoid hiring the wrong team so I don’t waste time and money.
I went through this last year for a small biz app. Stuff I wish I had known:
  1. Start with your goal and scope
    Write a one page brief.
    • What the app does.
    • Key screens.
    • Must‑have features.
    • Budget range.
    • Deadline.
    Agencies take you more serious when you show this.
  2. Check their iOS specific work
    A lot of agencies say “mobile” but outsource iOS or focus on web.
    Ask for:
    • 3 to 5 iOS apps in the App Store.
    • Links, not screenshots. Download them.
    • Look at speed, bugs, crashes, layout, how fast screens load.
    If the apps feel slow or clunky, skip.
  3. Look at tech choices
    For new iOS, you want:
    • Swift, not only Objective‑C for new code.
    • Modern iOS versions supported.
    • Use of Apple frameworks like SwiftUI or UIKit with Autolayout.
    Ask who does backend and API work. If they build backend, ask which stack. Node, .NET, Laravel, etc. You want something maintainable.
  4. Ask about team structure
    Ask who is on your project:
    • iOS dev(s).
    • Designer.
    • QA tester.
    • Project manager.
    Ask if they do daily or weekly standups and what tool they use. Jira, Trello, ClickUp, etc.
    If all communication goes through one “sales guy”, big red flag.
  5. Process and transparency
    Ask them to walk you through a typical project:
    • Discovery and specs.
    • Wireframes and design.
    • Development sprints.
    • Testing and bug fixing.
    • App Store submission.
    Ask how they share progress. Regular builds through TestFlight is good. If they say you see it at the end, run.
  6. Budget and pricing
    Common models:
    • Fixed price for a clear spec.
    • Time and materials per hour.
    For a small business app, expect a few thousand at the very low side for something tiny, five figures for anything more serious.
    Ask for:
    • Detailed estimate by feature.
    • What is included: design, QA, App Store upload, bugfix period.
    • What counts as “change” and what they charge for changes.
    Never go with a vague flat number and no breakdown.
  7. Ownership and code
    Make sure your contract says:
    • You own source code and IP when paid.
    • They hand over repo access, design files, API docs.
    Ask where they host code. GitHub, GitLab, Bitbucket.
    Ask to see a short sample of their code style, even if you are not technical, you can forward to a tech friend.
  8. Post launch support
    Ask:
    • How they handle urgent bugs after launch.
    • Response times.
    • Monthly support or maintenance options.
    iOS updates break stuff over time, you want someone ready to fix.
  9. References and reviews
    Ask for 2 or 3 clients you can message or call.
    Questions to ask them:
    • Did they hit deadlines.
    • How they handled problems.
    • Surprise costs.
    Also check Clutch, Google reviews, LinkedIn.
  10. Red flags I hit
    • “We do everything, iOS, Android, web, SEO, NFTs” but have no strong iOS portfolio.
    • No access to designers, only devs. UI looked like 2012.
    • No written scope, “we figure it out as we go”.
    • They refuse to share repo until you finish all payments.
  11. How to compare 3 agencies
    Make a simple table:
    Columns: Agency A, B, C.
    Rows:
    • Estimated cost.
    • Delivery time.
    • Seniority of devs.
    • Number of iOS apps shipped.
    • References checked.
    • Post launch support.
    Rank them on fit, not only price.
If you share rough budget and what the app should do, people here can tell you what seems realistic and what to push agencies on.
I’d add a few angles on top of what @chasseurdetoiles said, coming from the “been burned once, picked better the second time” camp.
1. Look for business thinking, not just coding
When you talk to them, notice what they ask you:
  • Do they ask about your business model, how the app makes / saves money, who your users are?
  • Or do they jump straight to “we’ll use SwiftUI and Firebase, cost is X”?
If they never challenge your assumptions or suggest simpler options, they’re probably just order takers. The best agencies will sometimes say “you don’t need that yet” or “MVP could be smaller like this” even if it lowers the quote.
Tiny hint: if they never say “no” to anything, you’re the product, not the client.
2. How they handle scope creep tells you everything
Everyone is relaxed at the start. The pain hits when you say “Can we add one more thing…?”
Ask very specific questions:
  • “If I want to change a feature after designs are done, how do you handle that?”
  • “If Apple rejects the first build, who pays for the extra work?”
  • “If I need a small feature after launch, minimum cost / process?”
You want a clear, boring answer. If they’re vague here, that’s where they’ll print money off you later.
3. Test their communication before you sign
Mini stress test:
  1. Send them a short email with 3 direct questions.
  2. See:
    • How fast they respond.
    • Whether they answer all 3 or just 1.
    • How clear they are.
If they can’t answer an email properly while trying to win your business, imagine month 3 when they’re juggling 5 clients.
I actually disagree slightly with relying too much on fancy tools like Jira / ClickUp as a good sign. I’ve had agencies with beautiful Jira boards and absolutely chaotic actual execution. Tools are meaningless if the PM is weak. Judge the person, not the software.
4. Design quality is often the real differentiator
A lot of “dev shops” treat design as a quick step. That’s how you get something that works but looks like a 2014 banking app.
Specific things to look for:
  • Ask to see a Figma or Sketch file from a past iOS project, not just final screenshots.
  • Ask who owns UX decisions: is there a UX person or just “our dev does basic design”?
  • Ask if they do a clickable prototype before coding.
Quick gut check: if their own website looks cheap or messy, don’t expect your app to look better.
5. Time zone and availability reality check
If you’re working with a different country:
  • Ask for overlap hours in your local timezone every week.
  • Ask who you can message in an emergency and via what channel (email, Slack, WhatsApp).
A lot of agencies say “we’re very flexible” but what that means is “we’ll reply tomorrow”.
6. Don’t ignore smaller or niche studios
Big shiny agencies are great at sales decks and discovery workshops… and often assign your project to the most junior dev with 10% of a senior’s time.
Sometimes a smaller 3–5 person studio that only does iOS is a better match:
  • More direct access to the actual devs
  • Less handoff between “sales” and “delivery”
  • Often more honest about what they can and can’t do
Just make sure they have enough redundancy that one sick dev doesn’t kill your timeline.
7. Ask them to simplify your idea out loud
One of my favorite tests:
“Can you summarize my app idea back to me in under a minute, like you were pitching it to a friend?”
You’re looking for:
  • Do they understand the core user and problem?
  • Do they focus on outcomes, not just features?
If they can’t explain your own idea clearly, they’re not going to build the right thing.
8. Watch how they talk about risk
Every project has risk: new features, unknown APIs, 3rd‑party integrations.
Ask:
  • “What are the top 3 risks you see in this project?”
  • “What usually goes wrong in iOS projects at your agency?”
If they say “we don’t really have problems, we follow process”… that’s not confidence, that’s delusion. I actually trust the team that can tell me a horror story and what they changed afterward.
9. Don’t chase the absolute cheapest quote
Common trap:
  • Agency A: $9k
  • Agency B: $22k
  • Agency C: $26k
Most people jump to A. In my experience, A often becomes $18k and 3 months late, with you exhausted and still missing stuff.
If one quote is way lower, ask what you’re not getting:
  • Less design?
  • No proper QA?
  • Only junior devs?
  • No post‑launch support?
Pick the one that explains why they cost what they cost and can show how that maps to value for you.
If you’re comfortable sharing a rough idea of the app (like “simple booking app for local customers, login + bookings + notifications”) and a ballpark budget, you’ll probably get more targeted thoughts on what’s realistic and what you should prioritize when choosing.
Quick add-on to what @andarilhonoturno and @chasseurdetoiles already covered from experience, focusing on how you actually pick one when everyone’s sales pitch sounds the same.
1. Do a “paid test” instead of committing fully
Instead of choosing an iOS app development agency off proposals alone, pick 2 finalists and pay each for a tiny, clearly scoped test:
  • 1 or 2 key screens designed
  • A clickable prototype
    or
  • A small, non critical feature from your future app
You learn way more from 1 week of real collaboration than from endless decks. I trust behavior over promises. This is where I slightly disagree with heavy up front “discovery only” contracts; a lean paid test is often enough for a small business app.
What to compare during the test:
  • How quickly they unblock questions
  • How many assumptions they validate instead of guessing
  • Whether they push back on bad ideas politely
2. Compare risk, not just price and portfolio
Make a simple risk-focused sheet for each agency:
  • Bus factor: Is there exactly one iOS dev who knows everything?
  • Dependency risk: Do they rely on lots of third party services you will later pay for?
  • Process risk: Do they have backup if your PM leaves next month?
An agency with a slightly higher quote but much lower risk is usually the smarter pick long term.
3. Contract details that save future headaches
People rarely look at this carefully enough:
Must haves:
  • Clear acceptance criteria for features
    Not “booking works” but “customer can select date/time, see confirmation, receive email.”
  • Milestone based payments tied to demonstrable outcomes
    Not time passed, but features working in a TestFlight build.
  • Explicit support window after launch
    Example: “30 or 60 days of free bug fixes for issues not caused by scope changes.”
Where I mildly disagree with some advice: you do not always need a super detailed line by line spec at day 1, but you do need clarity on how changes are priced and approved.
4. Think about your next 12 to 24 months
Ask yourself:
  • If this goes well, do I need them for Android or web next?
  • Or will I probably switch to an in house dev later?
If you might bring in someone internal later, push harder on:
  • Clean handoff commitments
  • Developer documentation
  • Code structure that a new dev can understand
That future dev will either bless you or curse you based on the agency you pick.
5. How to use all this in practice
When you have 3 agencies on your shortlist:
  1. Run a tiny paid test with your top 2.
  2. Score them on:
    • Communication under minor stress
    • Quality of the initial implementation or designs
    • How well they understood your business goal
  3. Combine that with the comparison table idea from the other replies and you will usually see a clear winner.
If you share your rough app type (for example, booking, e commerce, internal tool) and a budget bracket, people can sanity check whether an iOS app development agency is pitching you something realistic or padded.
