I just switched from Windows to a Mac and I really miss the Snipping Tool for quick screenshots. I’m confused about what the Mac equivalent is, how to capture just part of the screen, and where those screenshots get saved. Can someone walk me through the best way to do this on macOS, including any built-in shortcuts or simple apps I should use?
On macOS the Snipping Tool “equivalent” is built in. You use keyboard shortcuts, not an app icon.
Quick map:
Full screen
Press: Shift + Command + 3
Result: Screenshot of all screens.
File goes on your Desktop by default, named like “Screenshot 2026-02-17 at 10.32.15.png”. -
Selected area (closest to Snipping Tool)
Press: Shift + Command + 4
Your cursor turns into a crosshair.
Click and drag to select the region.
Release mouse to capture.
Press Esc to cancel if you mess up. -
Single window
Press: Shift + Command + 4, then tap Space.
Cursor turns into a camera icon.
Hover over a window.
Click to capture that window with a neat shadow. -
Screenshot toolbar (like a mini snipping control)
Press: Shift + Command + 5
You get a toolbar at the bottom:
- Capture entire screen
- Capture selected window
- Capture selected portion
- Record screen (video)
Click “Options” on that toolbar to pick: - Save to Desktop, Documents, Clipboard, Mail, Messages, Preview, or a custom folder
- Include mouse pointer
- Timer (5 or 10 seconds)
- Save to clipboard instead of file
Hold Control with the combos above.
Examples:
- Shift + Control + Command + 3 = full screen to clipboard
- Shift + Control + Command + 4 = selected area to clipboard
Then hit Command + V in apps like Word, Slack, Outlook, etc.
Change default save location
Press Shift + Command + 5.
Click Options.
Choose a folder under “Save to”.
If you want a special folder, pick “Other Location…” and make one like “Screenshots” in Documents. -
Quick annotation (like Snipping Tool’s editor)
After you take a screenshot, a small thumbnail shows in the bottom right.
Click it fast. It opens in Markup.
There you can:
- Draw
- Add text
- Highlight
- Crop
Then hit Done and it saves.
- Where to find missed screenshots
- Default: Desktop
- If you changed it, check the folder you set in Options
- Use Spotlight: Command + Space, type “Screenshot” and sort by Date
- If nothing works
- Check System Settings > Keyboard > Keyboard Shortcuts > Screenshots, make sure they are enabled
- Third party screen capture apps can sometimes steal shortcuts
If you want an app icon like Snipping Tool, try:
- “Screenshot” app in Applications > Utilities (same as Shift + Command + 5)
Drag it to Dock for quick mouse access.
On macOS, think of screenshots as a “service” more than an “app.” @sterrenkijker already nailed the shortcuts, so I’ll skip rehashing those key combos and focus on the stuff people usually trip over after that.
1. Where the heck did my screenshot go?
By default, macOS dumps them on your Desktop as PNGs. If your Desktop is a war zone already, that gets messy fast. Two tricks you might not realize:
- If you drag a screenshot thumbnail (that little popup in the corner) into a Finder window or onto a folder icon, it saves there instead of Desktop.
- If you change the save location in the Shift + Command + 5 “Options” menu, macOS remembers it forever (or until you change it again). So if you set it to, say,
Documents/Screenshots, and then later “lose” screenshots, that’s the first place to look.
2. Using screenshots like Snipping Tool “Copy” instead of saving files
On Windows, a lot of people used Snipping Tool just to copy an image into email/chat. On Mac, the closest equivalent is using the clipboard:
- Add Control to any screenshot shortcut and it goes to the clipboard instead of a file.
- Then just Command + V into Teams, Slack, Word, etc.
This is actually where I’ll slightly disagree with the “keyboard shortcuts are everything” vibe: if you’re coming from Windows, it can feel awkward. In that case you might find it easier to:
- Open the Screenshot app from Applications > Utilities
- Keep it in the Dock
- Use it like a little “snip bar” you click first, then choose area / window / full screen, with the mouse.
It’s the same tool as Shift + Command + 5, just in icon form.
3. How to capture part of the screen in a more “Windowsy” way
Yes, Shift + Command + 4 is the main thing, but a couple of less obvious tweaks:
- While dragging the selection, hold Space to move the whole rectangle around without changing its size. Great when your box is right but slightly off position.
- While dragging, hold Option to resize from the center, not the corner.
- You can adjust the borders after selecting: drag the edges before releasing the mouse or trackpad.
That makes it feel much closer to the control you’re used to from Snipping Tool.
4. Quick “edit & send” workflow (closest to Snipping Tool editor)
Windows habit is: open Snipping Tool, snip, mark it up, save or send. On Mac, do this:
- Take a screenshot normally.
- Click the little thumbnail that appears in the corner before it disappears.
- Use Markup: draw, arrows, text, boxes, etc.
- Important bit: click the Share button (top right of that window) to send straight to Mail, Messages, Notes, etc, without hunting for the file.
- Only hit “Done” when you want the annotated version saved.
You don’t have to keep saving a million files just to send annotated screenshots.
5. If you’re on multiple monitors
macOS likes to screenshot every screen with Shift + Command + 3, which is overkill if you just want one display.
The workaround most people miss:
- Hit Shift + Command + 4
- Then tap Space
- Click the monitor itself (not a window) to capture just that screen.
It behaves more like “Snip this display only.”
6. If you truly hate the default behavior
If all this still feels clunky:
- Turn on “Show Floating Thumbnail” in the Shift + Command + 5 Options and treat that thumbnail as your “Snipping Tool window.”
- If you want ultra-Snipping-Tool vibes, you can even bind one of the screenshot commands to something like F13 or another unused key in System Settings > Keyboard > Keyboard Shortcuts, so it lives on a single, easy key.
Once you do this for a week, you’ll probably never miss Snipping Tool again, though you will complain the next time you sit at a Windows PC and mash Shift + Command + 4 at a dead keyboard.
If you really miss Snipping Tool as an app instead of a bunch of keyboard shortcuts, the closest Mac mindset shift is: treat Screenshot as a small utility you can “park” and drive, not just a hidden feature.
@sterrenkijker covered shortcuts and the floating thumbnail nicely, so I’ll lean into alternative workflows and a few gotchas they didn’t emphasize.
1. Turn Screenshot into a fake “Snipping Tool” app
Instead of memorizing shortcuts:
- Open Applications → Utilities → Screenshot.
- Right‑click its icon in the Dock → Options → Keep in Dock.
Now you can just click that Dock icon whenever you want a capture. Once it is open:
- Left icons: full screen, window, selected area.
- Right icons: screen recording options.
This feels very Snipping Tool‑ish: click tool, then pick the mode, then capture.
Pros of using Screenshot like this:
- Visual, mouse‑driven, friendly if you hate shortcuts.
- Easy to remember for new Mac users.
- One extra click vs a hotkey.
- Slower if you take screenshots all day.
2. Custom shortcuts so it behaves like Windows
If your fingers are wired to Windows keys, you can remap:
- System Settings → Keyboard → Keyboard Shortcuts → Screenshots.
- Change things like “Save picture of selected area” to something you prefer, for example F12 or another simple key.
I slightly disagree with the idea that you must “just learn” the stock combos. If you are switching platforms permanently, custom bindings are worth the five minutes of setup.
3. Make screenshots organized from day one
Instead of letting the Desktop turn into a PNG graveyard, build a simple structure:
- Create
~/Pictures/Screenshots/Workand~/Pictures/Screenshots/Personal. - In Shift + Command + 5 → Options, point the default save location to
~/Pictures/Screenshots.
Then, when the thumbnail appears, you can drag it into Work or Personal in the sidebar of a Finder window. That gives you some basic organization without touching Finder after the fact.
4. Power user combo: Clipboard + Markup without saving files
If you just want to send something fast and never keep a file:
- Press Control + Shift + Command + 4 and select the region.
- Open your chat/email, press Command + V.
To annotate without leaving junk files:
- Take the screenshot normally.
- When the thumbnail appears, right‑click it and choose Markup.
- After annotating, hit Share to send it.
- Then choose Delete instead of Save.
This is the closest to “open Snipping Tool, snip, draw, close without saving” from Windows.
5. What about third‑party tools?
If you find Screenshot still a bit clunky, plenty of Mac users move to dedicated screenshot utilities that behave almost exactly like Snipping Tool, with quick annotation and automatic uploads. Compared with what @sterrenkijker described, the built‑in Screenshot is more than enough for most people, but:
Pros of sticking with Screenshot (the built‑in “”)
- Free and already installed.
- Integrates with Markup and Share menu.
- Respectable control over region/window/full display and recording.
Cons of Screenshot
- No built‑in cloud history or links.
- Annotations are basic compared to some third‑party tools.
- Fewer automation options for power users.
If your needs are light to moderate, I would master Screenshot first, then decide if you really miss extras like auto‑upload or shortcut‑based editing.
In short:
- Pin Screenshot to the Dock and treat it like Snipping Tool.
- Customize shortcuts so your hands are happy.
- Use clipboard variants for quick “copy only” jobs.
- Use thumbnail + Markup + Share for the Snipping Tool‑style “snip, annotate, send” flow without cluttering your drive.
