How To Crop A Screenshot On Mac
I keep taking full-screen screenshots on my Mac when I only need a small part of the image for work and school. I’m sure there’s a built-in way to crop or select just a portion of the screen, but I can’t figure it out from the shortcuts I know. Can someone explain the easiest methods to crop a screenshot on macOS, and whether I can do it right after taking the screenshot or only later in Preview or another app?
Easiest way is to stop taking full screen shots and switch to selection mode.
For a selected area:
  1. Press Shift + Command + 4
  2. Your cursor turns into a crosshair
  3. Click and drag to select the area you need
  4. Release to save the screenshot
That saves only the part you dragged. No extra cropping needed.
If you already have a full screenshot and want to crop it after:
Quick way with Preview:
  1. Double click the screenshot to open it in Preview
  2. Press Command + A to clear any selection if it has one
  3. Click and drag over the part you want to keep
  4. Go to Tools → Crop
  5. Press Command + S to overwrite, or Command + Shift + S for a new file
You can also use Shift + Command + 5 for the screenshot toolbar:
  1. Press Shift + Command + 5
  2. Pick “Selected Portion” from the options at the bottom
  3. Drag the box edges to adjust the region
  4. Hit “Capture”
If you take a lot of shots for school or work, that Shift + Command + 4 combo will save you a ton of time. I switched to it and stopped filling my desktop with useless full screen PNGs.
If you’re constantly ending up with full-screen shots, I’d actually tweak the behavior of screenshots instead of just learning another key combo.
@​sognonotturno covered the basic shortcuts nicely, but here are a few different angles:
1. Change where your screenshots go & how they work (less clutter, easier cropping)
Hit Shift + Command + 5 once, then:
  • Click “Options”
  • Choose a specific folder (like “Screenshots for Class”) so they don’t spam your Desktop
  • Also turn on “Show Floating Thumbnail” if it’s not already
That little thumbnail in the corner is the trick most people miss.
2. Use the Floating Thumbnail to crop instantly
After taking any screenshot (full or partial):
  1. Take the screenshot like normal
  2. A thumbnail appears at bottom-right
  3. Click it before it disappears (you have a few seconds)
  4. You get a mini editor: click the crop icon
  5. Drag the crop handles, hit Done
This way you don’t even have to open Preview manually. It is faster than the “open in Preview, Tools → Crop” route if you’re doing a lot of quick edits.
3. Turn a full-screen into a partial without “cropping”
If you actually just need one window, full-screen screenshots are kind of overkill. Instead of cropping:
  2. Press the spacebar once
  3. Now your cursor turns into a little camera
  4. Click the window you want
You get a perfectly framed shot of only that window, no manual cropping later. I personally prefer this over always dragging a selection rectangle like @​sognonotturno suggested. Less fiddly, especially on a laptop trackpad.
4. Use Photos for more “photo-like” cropping
If your screenshot is already in Photos (or you drag it in):
  1. Open it in Photos
  2. Click Edit
  3. Use the Crop tab
  4. You can even set aspect ratios if you’re putting stuff into slides or documents
Preview is fine, but Photos feels nicer for repeated or more visual work, especially for school projects where you care how it looks.
5. Bonus: copy instead of saving when you only need it once
If the screenshot is just going into a doc or chat and you don’t even need a file:
  • Press Control + Shift + Command + 4
  • Select the area
  • It goes to your clipboard only
  • Paste directly into Word / Google Docs / email / whatever
No file to manage, no cropping later, nothing cluttering your folders.
TL;DR:
  • Use the floating thumbnail editor to crop right after you shoot
  • Use the window-only screenshot with spacebar to avoid cropping in the first place
  • Use Control in the shortcut to skip files entirely when it is a one-off image
Once you get those into muscle memory, you’ll basically never need to manually crop a saved full-screen screenshot again.
If you’re tired of full-screen shots, I’d actually go one step beyond what @sognonotturno suggested and change how you work with screenshots altogether, not just where they go.
1. Use “stickier” selection areas
macOS does not advertise this, but you can reuse the same selection rectangle so you are not constantly redragging for the same region in a document or web page.
  1. Press Shift + Command + 4.
  2. Draw your selection once.
  3. Before releasing the trackpad/mouse, hold the Spacebar to move the whole box if it is slightly off.
  4. If you need to fine tune, use Shift or Option while dragging edges or corners.
The trick: for repeated shots of the same region, do not switch back to full-screen shortcuts. Just hit Shift + Command + 4 again and visually match the same area using the crosshair coordinates in the small label. It is not “locked,” but with coordinates visible, you can match exact size and position, which is useful for consistent class notes or tutorials.
I slightly disagree with relying too heavily on the window-only camera mode (Space after Shift + Command + 4) if your target app has big sidebars or toolbars. In that case, a tight manual region looks cleaner and more professional than a raw app window shot.
2. Use Preview’s “Markup Toolbar” as your crop hub
The floating thumbnail editor is nice, but it disappears fast. If you often realize “ugh, I should crop that” later:
  1. Right-click the screenshot in Finder.
  2. Open With → Preview.
  3. Click the Markup Toolbar button (tiny pencil icon).
  4. Drag to select your crop → Tools → Crop or just press Command + K.
Why this is useful:
  • Can stack crops, annotations, arrows, highlights in one place.
  • Good for building handout-style images for school.
  • No need to hunt through apps like Photos if you do not want your screenshots mixed with personal photos.
3. Batch-trim messy edges for many screenshots
If you take a ton of nearly identical screenshots (same app, same menu bar, same dock showing), cropping one by one is annoying.
A lightweight approach:
  1. Put all screenshots in one folder.
  2. Open them all in Preview (select all → right-click → Open).
  3. In the Preview sidebar, Command + A to select all pages.
  4. Draw a crop region once.
  5. Tools → Crop.
Preview applies the same crop to every opened image. Great if all your full-screen captures just need the top menu and dock chopped off. This is a big time saver that people usually overlook.
4. Keyboard-only management for speed
If you like to stay on the keyboard:
  • After taking a screenshot, hit Command + Space
  • Type part of its name (typically “Screenshot” + date)
  • Command + O to open in Preview
  • Command + A to select all, drag crop, Command + K to crop, Command + S to save
Not glamorous, but fast when you develop the muscle memory and do not want to rely on the floating thumbnail.
5. Pros & cons of the built-in “How To Crop A Screenshot On Mac” approach
You basically have an invisible product already in macOS: the built-in screenshot and cropping workflow. Think of it as the default “How To Crop A Screenshot On Mac” toolkit.
  • Free, already installed, no extra apps.
  • Consistent keyboard shortcuts across all Macs.
  • Good enough editing for 90% of work and school tasks.
  • Batch cropping in Preview is underrated and powerful.
  • No persistent crop presets or reusable selection zones.
  • Floating thumbnail editor is time-limited and easy to miss.
  • Lacks advanced export presets, compression tuning or automated renaming.
  • Can feel clunky compared to dedicated screenshot utilities if you do this all day.
6. Where this differs from @sognonotturno’s tips
Their breakdown of shortcuts and the floating thumbnail is solid, but if you often work with many screenshots in one sitting, Preview’s batch crop and coordinate-based selection are more efficient than cropping each shot right after capture. I also think Photos is overkill unless you truly care about photo-like editing; for pure documentation and homework, keeping things in dedicated screenshot folders plus Preview is simpler and less distracting.
If you wire in:
  • Shift + Command + 4 with modifiers for precise area control
  • Preview’s batch crop for cleanup
    you will barely ever need to stare at a messy full-screen capture again.
