How do I turn a photo into a PDF on my iPhone?
I need to convert a few pictures on my iPhone into a single PDF file to email for work, but I can’t figure out the right steps with the Photos or Files app. I’d really appreciate a simple, up-to-date method that doesn’t require buying a separate app, and if possible, a way to combine multiple images into one PDF.
Here is the simplest way with no extra apps, all on iOS, to turn multiple photos into one PDF.
Method 1. Using Files only
Good if your photos are already in Photos.
  1. Open Photos.
  2. Tap “Select” in the top right.
  3. Tap each photo you need in the PDF, in the order you want.
  4. Tap the Share icon.
  5. Scroll down and tap “Save to Files”.
  6. Choose a folder, for example “On My iPhone > Downloads”, then tap “Save”.
Now they are in Files.
  1. Open the Files app.
  2. Go to the folder where you saved the photos.
  3. Tap the three dots in the top right.
  4. Tap “Select”.
  5. Tap each photo, again in the order you want the pages.
    • If the order is wrong, tap the three dots again and use “Sort by Name” or “Sort by Date”.
  6. With the photos selected, tap the three dots in the bottom right.
  7. Tap “Create PDF”.
Files makes one PDF with each photo as a page.
You now see “YourFileName.pdf” in the same folder.
  1. Tap and hold the PDF.
  2. Tap “Share” and choose Mail, Gmail, etc.
Method 2. Using Print trick from Photos
This is quick if you do not want to mess with Files.
  1. Open Photos.
  2. Tap “Select”.
  3. Pick your images.
  5. Scroll down and tap “Print”.
  6. On the Print Options screen, do a two finger outward pinch on one of the photo previews.
    This opens a full screen preview of the “print”.
  7. Tap the Share icon in the top right again.
  8. Tap “Save to Files” or “Mail” or whatever you need.
That preview is a PDF.
If you save to Files, you get a normal PDF file you can attach later.
Small tips.
• If the PDF is huge, try using slightly lower resolution photos or fewer images.
• If the email fails to send, upload the PDF to iCloud Drive, Google Drive or OneDrive from Files, then share a link instead of an attachment.
Those steps work on iOS 15, 16, 17 and newer, so they should match what you see on a recent iPhone.
If Photos + Files are already confusing you, you’re not alone. @techchizkid covered the “official” Files / Print methods pretty well, but I actually find a slightly different built‑in trick easier, especially when you want one clean multi‑page PDF for work.
Here’s what I’d try instead:
Method 3: Use Notes to scan & auto‑PDF (super work‑friendly)
This is great if your “photos” are really documents (receipts, forms, contracts) or you can just re-snap them neatly.
  1. Open the Notes app.
  2. Tap the New Note button.
  3. Tap the camera icon above the keyboard.
  4. Choose Scan Documents.
  5. Point at your first document / paper. Let it auto-scan and capture.
  6. Tap Keep Scan.
  7. Scan the next page / document. Repeat until you’ve got all of them.
  8. Tap Save when you’re done.
Now you’ve got a multi‑page scan neatly in one note.
  1. In that note, tap the scan preview.
  2. Tap the Share icon.
  3. Pick Mail if you want to send it right away, or Save to Files if you want a PDF file you can reuse.
Notes automatically makes it a single PDF, in the correct order, cropped like a scanner. For work stuff this usually looks more professional than just photos slapped into a PDF.
Method 4: Quick “turn existing photos into PDF” inside Notes
If you already have the photos, but still want Notes to assemble them:
  1. Open Notes and create a new note.
  2. Tap the camera icon.
  3. Choose Photo Library.
  4. Select all the photos you want (in order, as much as possible).
  5. Tap Add. They’ll all appear inside the note.
  6. Tap one of the images, then tap the Share icon.
  7. Choose Markup if you want to sign or annotate.
  8. From the Markup screen, tap Done then the Share icon again.
  9. Select Print.
  10. On the print preview, use the two‑finger outward pinch gesture (same print trick @techchizkid mentioned, but inside Notes).
  11. You now see a PDF preview. Tap Share and then:
  • Mail to send it directly, or
  • Save to Files to keep the PDF.
I actually disagree slightly with shoving everything through Files first like they suggested. It works, but if you’re doing this often for work, Notes is nicer because:
  • You can reopen the note later and re‑export the PDF.
  • You can edit / reorder by long‑pressing images and cutting/pasting.
  • You can sign right there with Markup without juggling extra apps.
Couple tiny tips from painful experience:
  • If you’re emailing to someone picky (HR, accounting, etc.), use Scan Documents instead of camera photos. It flattens perspective and boosts contrast. Looks less like “I took this on my couch at 11 pm”.
  • If the PDF doesn’t send because it’s too big, save to Files then upload to iCloud / Google Drive and just email a link. Email size limits are still inexplicably stuck in 2008.
  • If pages look out of order, fix them in Notes first, then re‑export the PDF. Renaming files in Files does not change page order inside a PDF.
It sounds like a lot written out, but once you do it once or twice, it’s maybe 20–30 seconds per PDF. The UI is kinda clunky and Apple hides this stuff like it’s a state secret, but it works pretty reliably.
If Photos + Files + Notes still feel like too many hoops, there are two “slightly different” angles that might fit better, depending on how often you need this.
1. Use Shortcuts to make it one‑tap
Where I mildly disagree with @vrijheidsvogel and @techchizkid is that their methods are very manual every single time. If you do this weekly for work, automation helps.
Basic idea: create a Shortcut that takes selected photos and outputs a single PDF, ready to share.
Very high level (no step‑by‑step spam):
  • In Shortcuts, create a new personal shortcut.
  • Add actions:
    • “Select Photos” (allow multiple)
    • “Make PDF” from those images
    • “Save File” or “Share”
  • Add it to your Share Sheet.
Then, from Photos you just:
  • Select photos
  • Share
  • Run your shortcut
  • Get a PDF to email
  • Fast after first setup
  • No juggling Files or Notes every time
  • Keeps the order you pick in Photos
  • Initial setup is fiddly
  • If Apple changes Shortcuts behavior in an update, things can break quietly
Compared with @techchizkid’s pure Files route, Shortcuts cuts out a lot of taps once it is in place. Compared with @vrijheidsvogel’s Notes trick, it is less “document‑management” and more pure conversion.
2. When a dedicated app actually makes sense
You said “no extra apps,” which I agree with most of the time. Built‑in tools are enough for occasional use. But if this is for work, multiple times a week, a lightweight scanner/PDF app can be worth it.
Think in terms of something like a simple “all‑in‑one” PDF scanner app:
Pros of a dedicated photo to PDF app:
  • One workflow: open app, select images, reorder, export as PDF
  • Better compression, so email attachments stay under size limits
  • Often includes reordering, merging, splitting, watermarks, simple editing
  • Yet another app on your phone
  • Free versions may have ads or small watermarks
  • Slight learning curve vs. Apple’s built‑ins
For SEO‑style clarity: a typical “photo to PDF converter on iPhone” app is great for repeat office tasks, but overkill if you only convert a few images a month.
When to pick what
  • Rarely converting: stick with the Print trick that @techchizkid showed.
  • Need cleaner, document‑style output: go with Notes like @vrijheidsvogel suggested.
  • Doing this all the time for work:
    • Set up a Shortcuts workflow once, or
    • Use a small dedicated photo‑to‑PDF app for fewer taps and better compression.
That combination usually covers 99% of real‑world “turn my iPhone photos into one work‑ready PDF” situations without getting lost in menus every time.
