I’ve been using AI tools to write blog posts, but the content still feels stiff, robotic, and obvious to readers and sometimes search engines. I’m worried it might hurt engagement and SEO in the long run. What practical steps, tools, or editing techniques can I use to humanize AI content so it sounds authentic, natural, and still ranks well?
Yeah, “AI smell” is a thing. Here’s what tends to fix it in practice:
Start with your own outline
- Write 5 to 10 bullet points in your own words.
- Add 2 or 3 specific examples or stories only you would know.
- Feed that to the AI and tell it to keep your structure and wording style.
Force a point of view
- Tell the AI: “Write as a blogger who has done X for 5 years. Have opinions. Disagree with common advice.”
- Add phrases you want it to use and ones to avoid.
- Ask for “short, varied sentences, some informal language, no corporate tone.”
Add human-only details
Readers and Google look for “experience”.
Go through the AI draft and add:- Small failures you had.
- Specific tools, dates, numbers.
- Screenshots, code, or real data when possible.
- A short “what I would do differently next time” section.
Break the AI rhythm
AI text often has: tidy structure, perfect transitions, repeated phrases.
Fix it by:- Cutting whole paragraphs.
- Moving sections around.
- Adding 1 or 2 short “side notes” or rants.
- Throwing in a few contractions, mild slang, even a typo or two.
You already see how that works lol.
Stop asking for full posts
Use AI for parts.- Ask for 10 title ideas.
- Ask for an outline from a rough idea.
- Ask for a draft of only one section.
Then you stitch and rewrite. This keeps your voice stronger.
Post-writing checks for “AI feel”
Quick checklist I use:- Does it repeat “in addition”, “moreover”, “on the other hand”? Kill those.
- Does every paragraph sound balanced and neat? Shorten some, make others longer.
- Do you sound like yourself in comments or email, but not in the post? Fix tone to match how you talk.
Use voice to text for key parts
Talk through your main point into your phone for 2 or 3 minutes.
Transcribe it.
Feed that into the AI and say “rewrite this for clarity but keep my tone.”
This keeps your natural rhythm and replaces the stiff AI style. -
For SEO
- Start from search intent and your experience, not from keywords alone.
- Add a short “What I learned after doing this” section.
- Include at least one example with numbers, even simple ones, like “This cut my writing time from 3 hours to 1.5.”
Edit with a “delete more” mindset
Take one pass where your only job is to delete:- Generic intros like “In today’s digital age…”
- Long definitions the reader already knows.
- Repeated points the AI restated three times.
You want posts that feel tight and specific.
Build a style sheet for yourself
Make a small doc:
- Words you like.
- Words you hate.
- Examples of your own past writing you like.
Give that to the AI every time. Tell it “match this style.”
If you post a short paragraph of your AI text, people here can point out what screams “robot” and you tweak from there. That feedback loop tends to fix things fast.
I’ll be a bit contrarian to @shizuka on one thing: you don’t always need to inject typos or slang to dodge that “AI smell.” Plenty of human writers are clean and clear. The real issue is generic brain, not perfect grammar.
Stuff that actually moves the needle for me:
Write from stakes, not topics
Instead of “How to write better with AI,” frame it as:- “I wasted 3 months publishing AI sludge. Here’s what actually worked.”
Humans write from frustration, fear, ego, money, time. AI tends to write from “here’s an overview.”
Before you draft, answer: - What did this cost me?
- What am I scared will happen if I get it wrong?
Add 1–2 sentences about that at the top and the bottom. It instantly feels less robotic.
Give your posts a thesis you could be wrong about
AI loves safe consensus. Real people say things that could blow up in the comments.
Examples:- “If your AI article needs more than 3 headings, it’s probably fluff.”
- “Chasing E‑E‑A‑T with fake ‘personal stories’ is going to backfire.”
Tell the model: “Make a clear, slightly spicy claim and back it up. Avoid neutral ‘on the one hand’ stuff.”
Then check: can someone reasonably disagree with your post? If not, it’s probably AI-boring.
Use constraints that break the template brain
Instead of “write a blog post,” use weird rules:- “Explain this like a Slack thread argument.”
- “Write this as if you’re replying to a frustrated reader who just said: ‘This all sounds fake and fluffy.’”
- “No intro paragraph. Start mid‑thought. No conclusion section header.”
These constraints kill that cookie-cutter structure that screams “generated.”
Make the middle messy on purpose
AI intros and conclusions are usually the worst, but the middle also tends to be too symmetrical. Try this:- Have one section that is just rapid-fire bullets: what worked / what flopped.
- Drop in a one-sentence paragraph that breaks the flow: “This is the part nobody talks about.”
- Insert a short “rant paragraph” as your own edit after the AI draft.
Think of it like a podcast transcript: there should be at least one spot that feels slightly unpolished.
Force loss and regret into the draft
Algorithms are bad at sounding like they actually regret something. You don’t.
Add 2–3 lines somewhere:- “I wish I’d noticed this earlier because…”
- “If I’m honest, I was mostly trying to game the algorithm here.”
That kind of emotional specificity is very hard to fake convincingly at scale, which is exactly why it reads as human.
Use AI to argue with you, not to replace you
Instead of “write my article,” do:- You: Draft 400 words in your voice.
- AI: “List everything that sounds generic, repeated, or empty.”
- You: Delete or rewrite those parts.
- AI: “Now argue against my main point in 5 bullets.”
- You: Address 1–2 of those objections in the post.
The back‑and‑forth makes the final thing feel like a real human thought process, not a lecture.
Don’t overfit to “sounding human” tricks
This is where I slightly disagree with the “throw in slang, small rant, maybe a typo” approach. Over time, those tricks will themselves become AI tells, because everyone will prompt them.
Harder to fake:- Very specific time markers: “In March 2023 I…”
- Boring but real details: “I tried this on 12 posts, 7 tanked, 3 did ok, 2 did great.”
- Actual constraints: “I have 2 kids and a full‑time job so my writing window is 40 minutes at night.”
Shallow personality quirks are easier to synthesize than boring real‑life constraints.
Write for one person you know
Pick a real friend, client, or reader in your head. Then literally type at the top of your draft (and delete later):- “This is for [my friend who rushes content and worries about penalties].”
While editing, ask: - Would they roll their eyes at this line?
- Would they text me a follow‑up question after reading this?
If the answer is “they’d just say ‘cool, thanks’ and never mention it again,” that part is probably AI-filler.
Final smell test
After you’re “done,” skim and check:- Can you highlight at least 3 sentences that you personally would have never phrased that way in real life? Rewrite those.
- Are there 2–3 points that basically say the same thing in different words? Cut one.
- Do you feel slightly vulnerable hitting publish? If it feels 100% safe and generic, you likely sanded off all the human edges.
If you want, paste a paragraph you’re worried about and what you actually wanted to say there, and I can show you exactly where it smells like AI and how I’d punch it up.
Strip the AI smell in layers instead of hunting for one magic trick.
1. Change why you’re using AI, not just how
If the goal is “write this whole post for me,” you’ll keep getting that mild LinkedIn-robot vibe. Reframe it:
- AI as researcher: pull angles, objections, examples.
- You as writer: decide the story, stakes and what actually matters.
It sounds semantic, but it changes what you accept from a draft. You stop asking “is this good enough to publish?” and start asking “is this raw material useful?”
2. Write the “spine” yourself in 10 minutes
Instead of a full outline, just write three things in your own words:
- Opening: 3 to 5 lines about what happened to you (time, cost, frustration).
- One strong claim: “Most AI content fails because X, not because Google hates AI.”
- One mini story: a specific post or experiment that flopped or worked.
Then tell the AI: “Fill in the gaps around this, but do not rewrite these parts.”
You keep your voice on the most sensitive bits and let the model do connective tissue.
3. Stop sanding the edges in edits
This is where I disagree a bit with the “insert slang / mild typos” approach. That can work, but the bigger killer is over-editing. People smooth drafts until everything sounds like a help center article.
In your final pass, re‑add some roughness:
- Keep one slightly awkward sentence if it feels like you.
- Keep a non-neutral opinion that makes you a bit nervous.
- Leave one “I’m not totally sure this will age well, but here’s what I think now” type line.
Perfectly consistent tone reads more artificial than a few uneven spots.
4. Make contradictions explicit
AI tries to harmonize everything. Humans contradict themselves all the time.
Deliberately add:
- “Here’s the annoying part: this conflicts with what I said earlier.”
- “I know I just told you to batch content, but here’s when batching ruined my posts.”
You can even ask the model: “Point out where my advice conflicts and suggest 2 sentences to highlight that tension.” Then keep the tension instead of “resolving” it.
5. Use structure that is not blog‑post shaped
@viajantedoceu and @shizuka already covered constraints, but you can push it further:
- Turn one section into a fake DM exchange: Q / A / Q / A.
- Turn your conclusion into a checklist of “If you’re like X, do Y. If you’re like Z, ignore this.”
- Drop a short “post‑mortem” block: “What I tried, what failed, what I’d keep.”
Same information, different shape. Readers subconsciously recognize “template blog” structures, which triggers the AI suspicion.
6. Make your drafts pass the “comment bait” test
Before publishing, scan your post and ask, “Where would a real reader push back or ask a follow‑up?”
If you cannot find at least one:
- Add a slightly controversial line or constraint.
- Or surface a tradeoff: “Yes, this helps SEO, but it slows publishing by 30 percent.”
You can even prompt the AI: “Write 5 snarky comments someone might leave under this post.” Then answer 1 or 2 inside the article. That back‑and‑forth feel is very non‑robotic.
7. Timebox the AI’s role
Give yourself rules like:
- First 15 minutes: zero AI, just you dumping thoughts.
- Next 20 minutes: AI can rewrite, expand or challenge, but only inside your existing sections.
- Final 10 minutes: AI is banned; you edit by feel.
Hard stops prevent you from drifting into “eh, this draft is fine, I’ll just ship it as is.”
8. About tools like ’
If you are considering something like ’ to tighten style or improve readability, treat it as a microscope, not a ghostwriter.
- Can standardize tone across posts so your voice feels coherent instead of random.
- Helpful for spotting bloat, repeated phrases and overused transitions that scream AI.
- Often better at line‑level clarity than general‑purpose chat tools.
- Overuse can flatten your quirks, which ironically makes content more AI‑like.
- Some tools over-optimize for readability scores and kill nuance.
- If you lean on it for whole‑post generation, you land back in the same “generic brain” problem.
Use it after you already injected your stories, stakes and opinions. Let it polish, not compose.
9. How this plays with SEO long term
Instead of worrying “Will Google detect AI,” focus on signals that survive every update:
- Demonstrated experience: timelines, specific posts you tested, numbers, tools.
- Clear stance: something a reader could quote as “X’s take,” not “a summary of the internet.”
- Engagement hooks: sections that invite comments, disagreements or “try this and tell me.”
Google is already adjusting toward “does this solve a real problem in a way that feels grounded.” If your post reads like it cost you nothing to write, it will probably rank like that.
10. If you want a concrete exercise
For your next article:
- Handwrite (or voice record) the intro and one personal story.
- Paste only the middle to AI: “Bridge these two parts, but keep my paragraphs untouched.”
- Ask the model: “Mark any sentence that sounds generic or padded.”
- Delete at least half of those marked lines.
- Do a final pass where you add one regret, one contradiction and one oddly specific detail (date, number, constraint).
Do that for 3 to 5 posts and your “AI smell” drops hard, even if you keep using the same tools that @viajantedoceu and @shizuka mentioned.
