Free Tool Instead Of WriteHuman AI
I’ve been using WriteHuman AI for a while, but the cost is starting to add up and it’s no longer fitting my budget. I still need an AI writing assistant for blog posts, emails, and social media content. Can anyone recommend reliable free tools or platforms that work similarly to WriteHuman AI, ideally with good quality and no heavy limitations?
  1. Clever AI Humanizer – my take after messing with it for a week
Link: https://cleverhumanizer.ai
I stumbled into Clever AI Humanizer after getting sick of “your text is 100% AI” warnings on random detectors. I write with AI a lot for drafts, client docs, and boring internal stuff, and the pattern is always the same:
the content is fine, the tone feels off, and detectors scream at it.
So I took a weekend, pulled a bunch of my usual workflows, and ran everything through this thing to see how far it goes before it breaks.
Here is what I found, no fluff.
What you get for free
The short version: it is free, with limits that are bigger than what I expected.
Here is what the site gives you without paying:
• Up to 200,000 words each month, which is enough for heavy weekly use.
• Up to 7,000 words in one run, so full essays, long-form posts, or reports fit fine.
• Three styles to pick from:
• Casual
• Simple Academic
• Simple Formal
• An AI writer built in, tied directly into the humanizer.
• Grammar checker and paraphraser in the same place.
For a free tool, the limits did not get in my way. I hit them once on purpose, feeding it huge project docs to see if it would choke. It did not, it just slowed a bit on long runs.
How I tested it against AI detectors
I used one of the stricter detectors: ZeroGPT.
I took three different AI-generated samples, all made with a standard GPT-style model, pretty bland content:
• A blog-style article
• An academic-ish explanation
• A short “how to” guide
Process:
  1. Ran them raw through ZeroGPT.
    All flagged very high AI. No surprise.
  2. Ran the same texts through Clever AI Humanizer using the Casual style.
  3. Pasted the results back into ZeroGPT.
My outcome:
• ZeroGPT showed 0% AI detection for all three samples after humanization, using Casual each time.
• Text length increased a bit, usually around 10–25 percent.
So for this detector, in this setup, it went from “fully AI” to “looks human” on every sample I tried. That will not guarantee the same thing on every detector, but it was enough for me to keep using it.
Main module – Free AI Humanizer
This is where most of the value sits.
How I use it:
  1. Paste AI-generated text.
  2. Select style:
    • Casual for blogs, newsletters, social posts.
    • Simple Academic for school stuff or reports.
    • Simple Formal for emails, proposals, or anything with managers in copy.
  3. Hit run and wait a few seconds.
What it does:
• Removes the robotic, repetitive phrasing that AI tools often use.
• Breaks up patterns like “in addition” spam and generic openings.
• Tweaks the order and rhythm of sentences.
• Keeps the main meaning surprisingly close to the original.
I compared original versus humanized line by line. It did not wreck the arguments or structure. It changed phrasing, sentence length, and connective words. It also tends to expand simple lines into slightly more detailed ones, which is part of why the text gets longer.
When it fails, it fails mildly:
• Occasionally over-explains something simple.
• Sometimes adds a sentence that feels like filler.
Nothing catastrophic, but I still read everything before sending it.
Built-in AI Writer
This piece is more interesting if you start from zero.
Workflow I tried:
  1. Used the Free AI Writer to generate:
    • A 1,200-word blog post.
    • A basic “what is X” guide.
  2. Sent its output directly through the humanizer in the same interface.
Results:
• The raw AI Writer text sounded like every other generic AI article.
• After humanizing, the text:
• Passed ZeroGPT as 0%.
• Read closer to someone writing in a hurry, which is exactly what I want for quick content.
If you hate juggling tabs between “AI writer here” and “humanizer there”, this combo helps. You spin up a rough draft and clean it in one place.
I would not use the AI Writer for technical material that needs precise wording without editing, but for blog posts, filler email drafts, or outlines, it did the job.
Grammar Checker
I tried the Free Grammar Checker against:
• A rough email full of typos
• A short article with mixed tenses
• Some ESL-style text from a friend
What it fixed:
• Spelling
• Commas that made sentences confusing
• Verb tense consistency
• Awkward fragments in longer paragraphs
It did not rewrite whole chunks of meaning. It stayed in lane and focused on clarity and surface-level correctness. Think of it as a faster Grammarly-lite inside the same site.
I ran some outputs through Word’s editor and Grammarly after, and most core issues were already fixed by Clever AI. There were still style suggestions from the other tools, but nothing too serious.
Paraphraser tool
The Free AI Paraphraser is different from the humanizer. It is more about alternative wording than detector evasion.
Use cases I tried:
• Rewriting a paragraph for SEO while keeping intent.
• Rewording a section from a report to reuse in a slide deck.
• Turning formal text into something closer to a neutral tone.
It kept the factual meaning mostly intact. It shifted sentence structure, swapped words, and rearranged ideas slightly.
What to watch:
• On niche or technical content, you still need to verify that it did not soften or distort the meaning.
• It sometimes simplifies language more than I wanted, so for expert audiences I had to push some terms back in.
How it fits as an all-in-one tool
Everything is in one interface:
• Humanizer
• AI Writer
• Grammar Checker
• Paraphraser
I used it like this for a few days:
  1. Generate a rough piece with another AI model or their AI Writer.
  2. Run it through the Humanizer on Casual or Simple Academic.
  3. Fix leftovers with Grammar Checker.
  4. Use the Paraphraser on any lines I needed to adjust for SEO or tone.
This cut out a lot of copy-paste across different websites and extensions. That matters more when you work on multiple pieces in a row.
Stuff I did not like
It is not perfect and you should not treat it like magic.
Here are the downsides I noticed:
• AI detectors
• ZeroGPT gave me 0% on all my tests.
• Other detectors might still flag content as AI.
• No humanizer can guarantee a pass everywhere, and some tools regularly mark human text as AI too.
• Length inflation
• After humanization, text often becomes longer.
• This is linked to how it removes patterns and adds slightly more varied structure.
• Not great if you need strict word counts for assignments or print layouts.
• Style quirks
• Casual mode sometimes slips into “bloggy” language, which might not fit reports.
• Simple Academic is safe but a bit dry. Good for school, less fun for web writing.
Because of that, I treat it as a helper. I do a final manual pass on anything important, especially client work, academic work, or anything tied to my name.
Who I think this helps
From my own use and what I tested, it fits these cases best:
• Students who use AI for drafts and need something closer to human writing before handing stuff in, with the warning that you still need to understand and edit what you submit.
• Freelancers writing lots of mid-level content for blogs or newsletters who want to avoid obvious AI tone.
• Non-native English speakers who want AI help but are tired of their drafts being flagged on platforms or in tools.
• People who hit word limits or “AI not allowed” filters in tools that check writing quality.
If you write high-stakes research, legal work, medical content, or anything where precision and originality truly matter, you should treat these outputs as drafts, not final text.
Links if you want to dig deeper
More detailed Clever AI Humanizer review, with AI detection screenshots and breakdowns:
YouTube review of Clever AI Humanizer:
Reddit thread collecting opinions on AI humanizers:
https://www.reddit.com/r/DataRecoveryHelp/comments/1oqwdib/best_ai_humanizer/
Another Reddit thread focused on “humanizing AI” in general:
https://www.reddit.com/r/DataRecoveryHelp/comments/1l7aj60/humanize_ai
If you rely on AI for writing, it is worth at least running a few of your usual pieces through Clever and checking both how it reads and how detectors react on your side. I kept it in my workflow because it solved the specific problem I had with robotic tone without charging me or forcing tight limits.
If WriteHuman AI is starting to hurt your wallet, you have a few solid options that fit what you want for blogs, emails, and socials.
I agree with a lot of what @mikeappsreviewer said about Clever Ai Humanizer, but I see it a bit differently for your use case. I see it less as a “detector evasion” thing and more as a free, all‑in‑one writing workflow.
Here is what I would do in your position.
  1. Use Clever Ai Humanizer as your main “WriteHuman replacement”
For your use case, the free tier is enough in most cases:
  • Up to 200k words per month.
  • Up to 7k words per run, so a full blog post fits.
  • Three styles that map nicely to your work:
    • Casual for social and lighter blog posts.
    • Simple Formal for emails.
    • Simple Academic if you need slightly more serious posts.
Concrete workflow:
  • Draft your blog post or email with any free model, including ChatGPT free, Gemini free, etc.
  • Paste into Clever Ai Humanizer in Casual or Simple Formal.
  • Skim and trim any extra fluff, since it tends to expand text 10 to 20 percent.
For social content:
  • Draft 5 to 10 variations of a post.
  • Run the batch through Clever in Casual.
  • Pick the tightest ones and shorten them manually. It sometimes goes wordy, so you want to cut.
  1. Use the built‑in AI writer only as a “quick draft” tool
Here I slightly disagree with @mikeappsreviewer. For important blog posts, I would not rely on the built‑in writer for structure. It feels generic. I use it when:
  • I need a fast outline.
  • I need a “blank page breaker” to get some text up.
    Then I:
  • Rewrite headlines myself.
  • Add my own examples, stats, and screenshots.
  • Humanize the final version again at the end.
  1. Combine with one more free tool for topic and outline research
Clever Ai Humanizer is strong for tone and wording. It is weaker for “what should I write about” and “how to structure a series.”
For that part, I would:
  • Use ChatGPT free or Perplexity free to:
    • Get topic ideas for your niche.
    • Generate 5 to 10 headline ideas per topic.
    • Build an outline with H2 / H3 headings.
Then write the draft in your own words or with AI, and run the whole thing through Clever Ai Humanizer as the last step.
  1. For email writing
Simple setup:
  • Write a rough email in your natural voice.
  • Paste into Clever Ai Humanizer with Simple Formal.
  • Let it clean up phrasing and rhythm.
  • Use the Grammar Checker inside Clever to fix surface errors.
I would not overuse Casual for business email. It leans a bit “bloggy,” like @mikeappsreviewer mentioned. Simple Formal is safer.
  1. For social media content
You want short, punchy lines, so you need to fight Clever’s length inflation a bit.
Routine:
  • Generate captions or hooks with any free model.
  • Humanize in Casual.
  • Manually shorten to 1 to 2 sentences for each post.
  • Keep emojis and line breaks manual, since these tools can overdo both.
  1. Other free alternatives worth checking
If you want backups besides Clever Ai Humanizer:
  • QuillBot free
    • Useful for paraphrasing short chunks.
    • Has a character limit, so not great for long blogs, but fine for social posts or intros.
  • Grammarly free
    • Good for grammar and clarity, weaker for tone “humanization.”
  • Google Docs built‑in suggestions
    • Simple, but stable and private for basic editing.
My take:
  • Use Clever Ai Humanizer as your “WriteHuman AI replacement.”
  • Use a free LLM for ideas and outlines.
  • Use Grammarly free or Docs for a final light pass.
That stack keeps your cost at zero and still covers blogs, emails, and social posts without feeling like you are wrestling 5 different paid tools every day.
If WriteHuman AI is killing your budget, you’re not stuck, but I wouldn’t just 1:1 swap it with a single “magic” tool and call it a day.
I agree with parts of what @mikeappsreviewer and @codecrafter laid out about Clever Ai Humanizer, but I see it more as the engine in a small free stack, not the entire car.
Here’s how I’d handle your exact use case (blogs, email, socials) with minimal cost and minimal headache:
1. Make Clever Ai Humanizer your tone & polish layer
Where I slightly disagree with the others: I wouldn’t rely on Clever as the starting point for content. I’d treat it as the “final pass” that makes AI text sound less stiff and more natural.
Use it for:
  • Blog posts that already have structure and ideas
  • Emails that you’ve roughly drafted
  • Social captions that just need to feel less robotic
Instead of:
  • Asking it (or its built‑in writer) to do all the heavy lifting from scratch
Think of Clever Ai Humanizer as your “last 20%” tool that:
  • Smooths out that obvious “AI” rhythm
  • Tweaks phrasing
  • Adjusts formality (Casual vs Simple Formal)
You’ll keep more control over your voice this way.
2. Use a free model to do the heavy drafting
Where I’d change the workflow from what’s already been suggested:
  1. Use any free LLM (ChatGPT free, Gemini free, etc.) to:
    • Brain dump outlines
    • Generate a first ugly draft of your blog post
    • List 5 to 10 variations for social hooks or subject lines
  2. Edit that draft a little in your own words:
    • Add your examples, opinions, and stories
    • Fix any obviously wrong info
    • Cut parts that sound like filler
  3. Then send that edited draft into Clever Ai Humanizer as a final tone pass.
Why this order:
  • If you humanize a totally generic AI draft without adding your own angle, you’ll just get a “generic but more human” article. It reads fine, but it won’t stand out or feel like you.
3. Blogs: treat Clever as a “voice matcher” not a detector cheat
You didn’t say you care about AI detectors, just cost. That’s a big difference.
So instead of obsessing over “0% AI,” I’d do this:
  • Pick a blog post you wrote fully by yourself that you like.
  • Paste a few paragraphs into a doc and look at:
    • Sentence length variety
    • How often you use contractions
    • How casual/serious your wording is
Then:
  • Run your new AI‑assisted post through Clever Ai Humanizer
  • Compare it with your original writing
  • If Clever is making you sound too “bloggy” or too bland, shorten and tweak
I actually disagree a bit with treating “Casual” as the default for every blog. If your niche is B2B or a bit more serious, test Simple Academic or Simple Formal, then loosen it manually.
4. Email: stay in control of intent, let tools fix clarity
For email, I wouldn’t outsource structure to any AI, including Clever’s built‑in writer.
Workflow that tends to work better:
  1. Write the email in your own words, fast and messy
  2. Run it through Clever Ai Humanizer in Simple Formal
  3. If it starts sounding like a blog post or gets too long:
    • Manually cut any sentence that doesn’t change the meaning
  4. Run a quick grammar pass
    • Either Clever’s grammar checker
    • Or something like Grammarly free for a second opinion
The key: you decide what you’re saying and how direct you want to be; the tools just help with clarity and tone.
5. Social media: fight the “word inflation”
Everyone mentioned Clever’s tendency to expand text, and I’m doubling down on that for socials: it’s a problem there.
What I’d do:
  1. Use a free LLM to generate a bunch of short hooks:
    • 1–2 sentence max
  2. Run them through Clever Ai Humanizer in Casual
  3. Then ruthlessly shorten:
    • Delete any extra qualifiers (“in today’s world,” “it’s important to note,” etc.)
    • Keep the punchy part only
  4. Add:
    • Your own hashtag style
    • Emojis / line breaks by hand, so it doesn’t start looking like a generic “AI social” post
If a caption doubles in length after humanizing, that’s a sign to kill half of it.
6. Backups & combo tools so you’re not stuck
If for any reason Clever Ai Humanizer is down or caps you:
  • QuillBot free
    • Handy for short rewrites, intros, or single paragraphs
    • Annoying for long posts because of limits
  • Grammarly free
    • Good as a safety net for emails and blog posts
    • Weak at “making it sound human,” strong at “don’t sound sloppy”
  • Google Docs + its suggestions
    • Surprisingly decent for catching clunky sentences
    • Zero learning curve if you already use Docs
I’d still keep Clever Ai Humanizer in the center though, especially if you want an AI writing assistant that is free, handles long text, and gives you multiple styles. As a WriteHuman AI replacement, it’s pretty much tailored for what you described, as long as you’re okay doing a quick final pass yourself.
So the short version:
  • Free LLM for ideas and raw drafts
  • You add the real perspective
  • Clever Ai Humanizer to smooth tone and flow
  • Light grammar tool as backup
You’ll get 90% of what WriteHuman was doing for you without the monthly bill, and you won’t be locked into a single tool doing “everything” in a black box.
