External Hard Drive Recovery After Files Disappeared, Any Ideas?
A large batch of files suddenly vanished from my external hard drive after I plugged it into my PC, and now I’m trying to figure out if they were deleted, hidden, or if the drive is starting to fail. These are important photos and work documents, so I really need advice on safe external hard drive data recovery steps before I make things worse.
I lost a folder like this once, and the first mistake people make is keeping the drive in use while they search for fixes. If your files vanished from a hard drive, stop writing anything to it now. No downloads, no installs, no random restarts if you can avoid them.
Deleted files usually are not gone at first. The system marks their old space as free, and your data sits there until something new lands on top of it. So every saved screenshot, browser cache file, update, or app install chips away at your odds.
If this happened on an external drive or second internal drive, unplug it and connect it to a different computer for recovery. If it is your boot drive, start from a USB system or attach the drive to another machine. The point is simple, keep the damaged drive from getting new writes.
What I would do first
Use Disk Drill, but install it somewhere else. I mean a different physical drive, not a new folder on the same disk. People miss this and wreck their own recovery attempt.
  1. Install Disk Drill on another drive. If you install recovery software onto the affected disk, you risk overwriting the files you want back.
  2. Make a full byte-for-byte image before scanning. Disk Drill supports this. I would do this step first if the drive matters to you. Working from an image is safer than poking the original disk over and over.
  3. Scan the image or the original drive once. Let it finish. Half-scans and repeated rescans waste time and add wear.
  4. Preview what it finds. This saves a lot of guesswork. If previews open cleanly, your recovery odds look better.
  5. Restore files onto a different drive. Do not recover back to the same disk. People do this in a rush, and it goes bad fast.
The free limit
The free edition gives you 100 MB of recovery. It is not much. Still enough to test whether your photos, docs, or project files open right before you spend money or move to another tool.
Stuff worth knowing before you start
  • Old-school HDDs usually give you a better shot than SSDs. Mechanical drives tend to leave deleted data sitting around longer. Some newer hard drives support TRIM, so waiting around is still a bad idea.
  • Clicking, grinding, or spin-up failures change the whole situation. If the drive sounds wrong, stop. Software is not your fix then. You need a recovery lab.
  • One careful pass beats five sloppy ones. Re-running scans does not magically pull out extra files in most cases. It mostly adds stress and eats time.
If Disk Drill does not get it done
I have seen people switch tools and get different results, so it is worth keeping a short list:
  • Recuva, easier to use, decent for simple deletes.
  • DiskGenius, messier interface, stronger for partition problems and file system damage.
  • Data Rescue, decent pick on Mac.
I’d still start with Disk Drill because it is easier to move from imaging to scan to preview without much fumbling. If it misses stuff, then try the others.
Move fast. Be careful. If the drive is still healthy and you keep writes off it, your chances are often better than they feel in the first ten minutes of panic.
First thing I’d check is whether the files are gone or only hidden. Windows likes to flip attributes after a bad unplug or file system error. Open Command Prompt and run this on the external drive:
attrib -h -r -s /s /d X:*.*
Replace X with your drive letter. I’ve seen whole folders pop back after this. Also check Disk Management. If the used space still looks high, your data might still be there and the file table got messed up.
I agree with @mikeappsreviewer on stopping writes. I’d add one thing before recovery software. Run a SMART check with CrystalDiskInfo or Hard Disk Sentinel. If health is bad, skip random scans on the original drive. Clone it first. If SMART is clean and the drive sounds normal, then try Disk Drill on another disk and recover to a different location.
Also look in Event Viewer, Windows Logs, System. Search for disk or NTFS errors around the time files vanished. If you see I/O errors, bad sign.
If the folder vanished right after plugging in, test for this too:
  1. Hidden files enabled in File Explorer.
  2. Different USB cable or port.
  3. Another PC, read-only if posible.
  4. chkdsk only after you clone or recover what matters. I know people love chkdsk, I don’t. It fixes structure, but it also moves stuff into FOUND.000 and makes a mess.
If you want a step-by-step Windows deleted file recovery guide, this video is decent: watch this Windows deleted file recovery walkthrough
Short version, hidden attrbutes, file system damage, or early drive failure are the main suspects. Don’t keep poking the drive blind.
I’d actually hold off on one thing both @mikeappsreviewer and @himmelsjager kinda circle around: don’t assume “vanished” means classic deletion right away. Sometimes the directory tree gets corrupted while the raw file data is still sitting there fine, which means a file recovery scan may find tons of files but all the names/folders come back scrambled. Annoying as hell, but not the same as total loss.
What I’d do is check the drive’s behavior before doing anything heavy:
  • does it open slowly
  • does it freeze Explorer
  • does capacity look wrong
  • do you get “you need to format this drive” messages
  • are only certain folders missing
If the drive is acting weird but not physically noisy, I’d make an image first, then test one non-destructive scan app. Disk Drill is solid for this because it can show whether the missing files still exist under original names or only as reconstructed files. That tells you a lot about whether this is deletion vs file system damage.
One thing I would not rush into is CHKDSK. People treat it like magic. Sometimes it “fixes” the file system by orphaning your stuff into junk fragments. Great, now your files are techncially back as nonsense.
Also, check whether the missing files were ever moved by Windows indexing/library weirdness. Search the drive by file extension, sort by date modified, and see if they got dumped into some other folder. Sounds dumb, happens more than peolpe admit.
If you want a real-world example, this external hard drive data recovery success story is worth a look.
So yeah, my order would be: verify symptoms, image if possible, scan with Disk Drill from another drive, and only then think about repair tools.
