Can someone explain Agentic AI vs Generative AI in real projects?
I keep seeing people talk about Agentic AI and Generative AI like they’re different things, but most articles just give buzzwords without real clarity. I’m working on a small app and I’m not sure when I should think about using an agentic approach instead of just a regular generative AI model. Can someone break down the practical differences, real-world use cases, and what tradeoffs I should consider when choosing between them?
Short version: Generative AI makes stuff. Agentic AI decides what to do next.
Think of it like this:
Generative AI:
  • Input: prompt.
  • Output: text, code, image, SQL, etc.
  • You stay in control.
  • Examples:
    • “Summarize this doc.”
    • “Write a SQL query for this schema.”
    • “Draft email reply.”
  • In a project, this sits inside a single function call.
  • You call the model, then your normal app logic uses the result.
Agentic AI:
  • Has a loop: think → act → observe → repeat.
  • Calls tools or APIs.
  • Plans steps, not only single answers.
  • Tries something, checks result, tries next thing.
  • Examples:
    • “Given this bug report, inspect logs, query the DB, suggest fix, open a ticket.”
    • “Sync leads from CRM to database, then email new ones with a template.”
    • “Research 5 vendors, compare pricing, draft a decision summary.”
So generative is the engine. Agentic is a whole system built around that engine with:
  • Planning
  • Memory
  • Tools
  • Feedback loops
For your small app, ask yourself:
Use plain generative AI if:
  • User asks a question, you return an answer.
  • You need summarization, rewriting, translation.
  • You want code completion, text completion, or form filling.
  • Your backend still does all control flow.
Use agentic patterns if:
  • The task needs multiple steps.
  • It touches multiple services or tools.
  • You want the system to figure out subtasks on its own.
  • Example: user uploads CSV, the agent:
    • Analyzes structure.
    • Suggests schema.
    • Writes migration SQL.
    • Runs it through your DB API.
    • Verifies row counts.
Concrete setups I use:
  1. Pure generative
  • Frontend collects input.
  • Backend:
    • Validates.
    • Calls LLM with strict prompt and maybe JSON schema.
    • Uses output.
  • Good for: chatbot, doc Q&A, email generator, code helper.
  1. “Semi agentic”
  • Still use your normal backend logic.
  • Let LLM choose tool names, but you keep the loop.
  • Example:
    • LLM: “Use tool: search_tickets with arg: ‘payment failed’.”
    • Your code runs search_tickets, gives result back to LLM.
    • LLM drafts reply.
  • You control steps, logs, guardrails.
  1. Full agent style
  • Frameworks: LangGraph, LangChain agents, AutoGen, function calling loops.
  • You define:
    • Tools: get_user, run_sql, call_slack, send_email, etc.
    • Policies: allowed tools, limits, timeouts.
  • The agent:
    • Plans: “First get user. Then fetch orders. Then write refund email.”
    • Calls tools automatically until done.
When not to use agentic stuff:
  • You need strict latency.
  • You care a lot about determinism.
  • Regulatory or safety risk is high.
  • Task is simple one shot.
When agentic helps:
  • Lots of boring glue work.
  • Multi step workflows.
  • You plan to evolve the process without constant recoding.
  • Example I shipped:
    • Support triage agent:
      • Read ticket.
      • Classify issue.
      • Look up customer in CRM.
      • Get last 5 events from event store.
      • Draft reply with suggested internal owner.
    • This cut manual triage time about 60 percent in tests.
If you want a quick rule of thumb for your app:
  • Start with simple “LLM as a function” pattern.
  • Wrap it in a single backend function.
  • Once you feel pain from:
    • Too many small API calls.
    • Manual glue code between services.
    • Repeated multi step flows.
      then add tools and a loop around the model.
Most “Agentic AI” hype is just:
  • LLM
  • Tool calling
  • A loop
  • Some prompts for planning and reflection
You do not need full agent frameworks for MVP.
Start small, add agency only where you see real workflow pain.
Think of “generative vs agentic” less like two different AIs and more like two roles you can put the same model into.
@espritlibre covered the mental model really well, so let me come at it from a more “how it feels when you’re coding” angle and disagree on one thing: I don’t actually think “agentic = big complex system” is always true. You can get agent‑like behavior in pretty small, boring apps.
How it looks in real code
1. Plain generative mode
This is when your LLM call is basically a fancy helper() function.
Examples in a real app:
  • summarizeSupportTicket(text) -> summary
  • rewriteEmail(draft, tone) -> finalEmail
  • extractFields(text) -> {date, amount, vendor} via JSON schema
In code terms:
const result = await llm.chat({
  messages,
  response_format: { type: 'json_object', schema: zodSchema }
// your app decides what to do next
Key thing:
Your backend still holds the brain. The LLM is like a black-box transform. No loops, no tools, no real “deciding what to do next.”
Use this when:
  • One request → one answer
  • You already know the exact sequence of steps
  • Latency and predictability matter more than “smarts”
2. “Lightweight agentic” mode (where most real projects land)
This is where I slightly disagree with the “you either have full agent or nothing” vibe. You can add tiny bits of agency without buying into a whole agent framework.
Patterns that are already agentic, even if you don’t call them that:
  • Letting the LLM:
    • Choose which function / tool to call
    • Decide whether to stop or continue
    • Re-ask itself: “did that work?” and revise
Concrete small-app examples:
a) Routing & decision making
User types a message. Model decides what your backend should do:
  'action': 'CREATE_TASK' | 'ANSWER_QUESTION' | 'ASK_CLARIFICATION',
  'arguments': {...}
Your code then:
  • if CREATE_TASK → hit your task API
  • if ANSWER_QUESTION → just respond
  • if ASK_CLARIFICATION → send follow-up question
This is already “agentic”: the model is deciding the next step in your workflow. But your code still owns the loop and guardrails.
b) Self-checking
Two calls to the same model:
  1. draft = llm('Write SQL for X')
  2. checker = llm('Does this SQL do what was asked? If not, fix.')
That tiny verify‑and‑retry loop is a mini agent. No huge framework, but you’ve given the system a bit of autonomy.
3. Full agentic systems
This is more like what marketing is screaming about:
  • The model can:
    • Plan multiple steps
    • Call tools (APIs, DB, filesystem, email)
    • Look at results and decide what to do next
    • Decide when it is “done”
Typical stuff:
  • Frameworks: LangGraph, LangChain agents, AutoGen, function-calling loops
  • Tools: search_docs, run_sql, send_email, create_jira_ticket
This is where you might say:
“Given a bug report, investigate logs, query DB, find root cause, draft Jira.”
and the agent actually:
  1. Calls search_logs
  2. Calls run_sql
  3. Summarizes findings
  4. Calls create_jira_ticket
Nice when:
  • You have messy, multi-step workflows that change a lot
  • You’re doing “ops glue”: CRM + DB + Slack + email, etc.
  • You want to experiment fast on processes without constant rewrites
Not nice when:
  • You need low latency and high determinism
  • You have strict compliance / safety constraints
  • You don’t have time to debug “why did the agent do 14 tool calls and nothing useful”
How to decide for your small app
Very un-fancy checklist:
You probably only need generative if:
  • One user action → one LLM call
  • The main value is: summarize, rewrite, translate, generate a thing
  • Your backend logic is clean and straightforward
  • You can write the control flow in 20–50 lines without pain
You should start thinking agentic if:
  • The feature you’re building:
    • touches 2 or more external services
    • naturally breaks into several steps
    • would be annoying to hard-code as if/else ladders
  • You find yourself doing:
    • “Call LLM → inspect result → call service A → call LLM again → maybe call service B → maybe loop”
At that moment, instead of building a brittle, hand-crafted flow, you can let the model handle:
  • tool selection
  • step ordering
  • simple error handling or retries
You still own:
  • max steps
  • allowed tools
  • safety checks
Think: LLM as a junior ops person, not as the CEO.
One concrete rule of thumb
If your function definition for the LLM is something like:
async function handleUserRequest(input) {
  const output = await llm.generation(input);
  return output;
you are in generative land.
If it starts looking like:
  let state = { input, history: [] };
  for (let i = 0; i < MAX_STEPS; i++) {
    const action = await llm.decideNextStep(state);
    if (action.type === 'DONE') break;
    const toolResult = await runTool(action.tool, action.args);
    state = updateState(state, action, toolResult);
  return finalize(state);
you’ve crossed into agentic territory.
Last point: you absolutely do not need “agentic AI” to ship a solid small app. Most successful early products use “LLM as a really smart function.” Let your own pain be the trigger: only add agency when your non-agentic code starts feeling like a giant ball of glue logic you don’t want to maintain.
  • Generative AI = what the model does
  • Agentic AI = how you orchestrate it in your system
Same underlying tech, different job description.
1. Mental model in one sentence
If the model only turns input into output, it is in generative mode.
If the model chooses actions over time (with tools, loops, state), it is in agentic mode.
This is close to what @espritlibre laid out, but I disagree with one common take: “agentic” is not just “more steps.” You can have a long, boring multistep pipeline that is still purely generative if you script every step and the model never decides anything structural.
Example:
  1. Call LLM to extract fields.
  2. Call LLM to rewrite a summary.
  3. Call LLM to translate.
If the order, conditions, and routing are all hard coded by you, that is still generative usage, just chained.
2. What actually changes in real projects
Focus on who owns these three things:
  1. Control flow
    • Generative: your code decides if, for, switch.
    • Agentic: model decides which “branch” to take or whether to continue.
  2. Tool choice
    • Generative: you call tools, then give outputs to the model.
    • Agentic: model picks which tool to call and when, within constraints you set.
  3. Stopping condition
    • Generative: exactly one shot or a fixed, known number of calls.
    • Agentic: the model can declare “I’m done” or “I need another step.”
If all three are under your control, you are solidly in generative territory, regardless of complexity.
3. When you probably should not go agentic in a small app
Where I diverge a bit from @espritlibre: I think most small apps are better off staying strictly generative unless you hit very specific pain points.
Skip agentic for now if:
  • Your core feature is:
    “User gives text → model gives final answer or artifact”
    (chatbot, summarizer, email writer, doc Q&A, etc.)
  • Rough edges from manual logic are acceptable.
    A couple of if/else blocks is easier to debug than an opaque planning loop.
  • You do not have solid logging, tracing, and metrics yet.
    Agentic systems need observability or they feel like black magic.
Going agentic before you have good instrumentation is asking for “why did it do that?” with no way to answer.
4. How to decide for your small app
Use this quick fork:
  1. List your feature in 1 sentence.
    If you can phrase it as “Transform X into Y” you are probably generative.
  2. Now try to phrase it as “Given goal G, figure out which of A/B/C to do, possibly several times.”
    If that sounds natural, you might benefit from agentic behavior.
Concretely, ask:
  • Do I expect different users or different inputs to trigger different sequences of actions that I do not want to encode manually?
  • Will those sequences change often as I learn more?
    If yes, agentic starts to pay off because you are letting the model adapt instead of constantly rewriting glue logic.
If the answer is “no, the flow is basically fixed,” stay generative.
5. Practical tradeoffs that bite later
Even in a small app:
Agentic pros
  • Can reduce if/else explosion when integrating many tools.
  • Lets you iterate on workflows through prompt changes instead of code changes.
  • Handles “messy” tasks where planning is more important than raw generation quality.
Agentic cons
  • Harder to test. You test behaviors over traces, not single responses.
  • Latency balloons, because you have multiple tool calls and model turns.
  • Difficult to guarantee worst case behavior for compliance, billing, or UX.
  • Debugging feels like debugging a junior engineer’s thought process instead of a function.
On a tiny project, those cons often dominate unless your feature is inherently like “mini-automation engineer in a box.”
6. About the product title ‘’
You mentioned the product title ‘’. Let me treat it as if it were your agent layer or orchestration tool.
Pros of using ‘’ in this context
  • Can give you a single place to represent agent “state” and decision logic, which helps keep the rest of your app simple.
  • If it has built-in traces or step visualization, that offsets some of the observability pain from agentic designs.
  • Good for experimenting: you can start with it acting as a plain generative wrapper, then gradually introduce tool calls and multi-step flows without rewriting your app structure.
Cons of using ‘’ too early
  • Adds conceptual overhead to a small project when you might be fine with a single callLLM() helper.
  • If it pushes you toward “let the agent figure it out” patterns, you can overcomplicate something that should have been a simple pipeline.
  • Debugging indirect behavior through an abstraction can be even harder than debugging your own minimal agent loop.
My bias: start by using ‘’ as a clean generative wrapper. Only enable its more agentic features once you see your own code turning into a brittle service-orchestration mess.
7. Where I agree and slightly disagree with @espritlibre
  • Agree:
    • Same model, different role.
    • Lightweight “agentic sprinkles” (routing, self-checking, simple decisions) are often the sweet spot.
  • Slight disagreement:
    • I would draw a sharper line:
      “If you let the model control the loop or structure of actions, you are in agent land. Period.”
      Long or complex pipelines you fully script do not make it agentic, just more advanced generative usage.
If you want a simple rule of thumb for your app:
Until you can point to a concrete place where you are sick of adding new if branches every week, stick with generative patterns. The moment your control flow starts to look like spaghetti and you are rewriting it constantly, that is when an agentic layer like ‘’ can pay off.
