Anyone else having issues with Walkfit app reviews and complaints
I’ve been using the Walkfit app and I’m running into problems that don’t match the positive reviews I saw online. I’ve also noticed a lot of recent complaints about billing, app glitches, and poor support, and now I’m unsure what to believe. Can anyone share honest Walkfit app reviews, recent complaints, and whether it’s still safe and worth using or if I should cancel before I get overcharged
Yeah, you’re not the only one. Here’s what I’ve seen and what I’d do:
  1. Reviews vs reality
    A lot of the positive reviews look old or generic. Recent reviews on the App Store and Google Play mention:
  • Auto renew billing they didn’t notice
  • Free trial rolling into a full subscription
  • Difficulty canceling through the app
    Sort by “Most recent” and you’ll see a different picture than the star average.
  1. Billing issues
    Common pattern:
  • People think they signed up for a free trial.
  • Subscription shows up through Apple/Google a week later.
  • Support replies slow or sends copy paste answers.
What to do:
  • Check your subscription in Apple ID or Google Play. Cancel there, not only inside the app.
  • Screenshot everything, dates and charges.
  • If they ignore you, request a refund through Apple or Google. They handle it better than the app support in most cases.
  1. App glitches
    Reports I’ve seen:
  • Steps not syncing with Apple Health or Google Fit.
  • App freezing or not loading workouts.
  • Progress resetting after an update.
Quick checks:
  • Log out and log back in.
  • Turn phone off and on.
  • Reinstall the app, but only if your account syncs to email or Apple / Google login.
  • Make sure battery optimization is off for the app, or it stops tracking in the background.
  1. Support problems
    People mention:
  • 3 to 7 day reply times.
  • Same “we are sorry” message with no fix.
    If you emailed them already, give it a few days, then:
  • Send one short, clear follow up, list your issue, dates, and what you want, refund or cancel.
  • If no answer, go straight to Apple/Google support for billing.
  1. If you are unsure about keeping it
  • Export or note your current stats.
  • Try a week with Apple Fitness, Google Fit, or free apps like Pacer or MapMyWalk.
  • Compare accuracy and features. Most people who only want steps and simple goals do fine with free options.
  1. Going forward
    For any fitness app:
  • Avoid yearly plans at first. Start monthly.
  • Set a reminder on your phone a few days before the trial ends.
  • Read recent 1 and 2 star reviews, not only the top ones.
Short answer, your experience lines up with what a lot of recent users report. If you feel uneasy already, I’d cancel through the store, push for a refund if needed, then test a few alternatives before paying again.
Yeah, same boat here, the hype vs reality doesn’t really line up.
I actually disagree a bit with @cazadordeestrellas on one thing: I wouldn’t waste too much time going back and forth with their support if you’re already seeing red flags. A lot of folks keep emailing the app’s support hoping for a proper fix or detailed reply and just end up outside the refund window.
Couple of extra angles to look at:
  1. Reviews & “too clean” ratings
    Once the recent reviews turn negative while the overall rating stays high, I assume they’re leaning on old promo pushes, influencer deals, or asking only happy users to rate. Not saying it’s fake, just skewed. I usually:
  • Filter by “critical” or 1–3 star only and read those.
  • Check how they respond publicly to reviews. Vague “we’re sorry, contact support” replies with no specifics are a bad sign.
  1. Billing trail
    If you’re unclear what you actually agreed to, grab:
  • Email confirmation from Apple/Google or your bank
  • The exact subscription line in your phone’s subscriptions section
    Then compare it to what the app currently advertises in its paywall screen. If it looks different from what you remember (price, trial length, “cancel anytime” wording), take screenshots now. That helps a lot if you go for a refund or even a chargeback if it gets that ugly.
  1. Tech issues beyond the basic “reinstall” stuff
    For the glitches:
  • If steps or activity look off, open your phone’s native health app and see if the data itself is wrong or if it’s just Walkfit misreading it. If Apple Health / Google Fit look fine but Walkfit is off, that’s 100% on them.
  • Check if the app is doing big updates very often. Every other-day update that “fixes bugs” and still breaks things is usually a sign they’re shipping too fast and testing too little.
  1. What I’d actually do next
    Instead of trying super hard to “fix” Walkfit:
  • Decide first: is this worth the mental energy or is it just steps and simple programs?
  • If it’s not mission‑critical for you, cut your losses early: cancel at the store level, request refund once, then stop chasing them.
  • Move to another tracker for a couple weeks and see if you actually miss anything unique about Walkfit. Most people don’t.
  1. About the support issues
    If they’re already slow, I wouldn’t expect some big turnaround. I’d treat one non helpful reply as the signal to escalate to Apple/Google or your bank, not a reason to keep sending follow-ups for days.
You’re definitely not the only one seeing the gap between those shiny old reviews and what’s happening right now. If you’re already uncomfortable, that’s usually the sign to step away, not to double down and hope the app “grows into” the rating it claims to have.
Short version: you’re not imagining it, but I wouldn’t treat Walkfit as completely unusable either.
Where I slightly disagree with @viaggiatoresolare and @cazadordeestrellas is on the “cut your losses instantly” idea. If you actually like the layout, the programs, or the daily nudges, it can be worth a short, controlled test period before bailing, instead of uninstalling on the spot.
What I’d focus on now:
1. Treat Walkfit as a 7‑day probation app
Instead of chasing long email threads, decide: “One week to prove itself.” In that week:
  • Track with Walkfit plus a second free app in parallel.
  • Compare daily steps, distance, and calories. If Walkfit is consistently off by >5–10% vs Apple Health / Google Fit, that is a reliability problem, not just a glitch.
  • Watch for crashes around the same time of day or specific screens. Reproducible bugs are a red flag.
2. Don’t only look at billing, look at “time cost”
Even if you secure a refund, you still spend time and energy. So put a cap on it:
  • One billing contact: store or bank, not both.
  • One attempt at support: if the answer is generic or slow, stop there.
    This is where I agree more with @cazadordeestrellas: endless follow‑ups usually just move you outside any refund / dispute window.
3. Pros and cons of sticking with Walkfit right now
  • Simple to use compared to some “all‑in‑one” fitness platforms.
  • Daily walking structure can be motivating if you are new to tracking.
  • When it does sync properly, it is fine for basic step goals.
  • Reputation drift: old glowing reviews vs a growing cluster of recent complaints.
  • Opaque billing expectations for some users, especially around trials.
  • Stability issues on certain phones and OS versions.
  • Support that feels reactive instead of actually resolving things.
If you search for Walkfit app reviews and Walkfit app complaints, you will see exactly that pattern: strong early reputation, messy present.
4. Compare it to competitors without overthinking
You do not need a complex lab test. For 3 to 7 days, try:
  • A free tracker like Google Fit or Apple’s built‑in Fitness app.
  • A program‑style app such as Pacer, MapMyWalk, or Sweatcoin if you like gamification.
Check three things:
  1. Does it track your movement at least as accurately as Walkfit?
  2. Does the subscription / upgrade page clearly show price and trial terms?
  3. Do they respond to negative reviews with specific fixes, not just “contact support”?
If any of those do as much as Walkfit for lower risk, the decision is easy.
5. When Walkfit might still be worth it
Keep it only if, after your mini‑trial:
  • Tracking is accurate compared to your phone’s health app.
  • It stays stable for several days in a row.
  • You feel that its structure or coaching actually gets you walking more than cheaper options.
If two of those three are “no,” then the gap between the Walkfit app reviews and your reality is not just bad luck, it is a trend. At that point, cancel, request the refund once, and move on, instead of trying to nurse the app into what the old marketing promised.
