Why does my phone’s hotspot WiFi keep dropping connections?
My phone’s hotspot WiFi keeps disconnecting my laptop and tablet every few minutes, even when I have strong mobile data signal and plenty of battery. I’ve checked basic settings and restarted everything, but the problem keeps coming back. What could be causing these random hotspot dropouts, and how can I fix it so the connection stays stable for work and streaming?
Hotspots drop for a few common reasons, even when signal looks fine. Here is what I would check step by step.
  1. Turn off any hotspot timeout or sleep options
    • On many phones there is an “Auto turn off hotspot when no devices connected” or “Timeout” option.
    • Some phones mis-detect activity and drop it while your laptop still uses it.
    • Set it to “Never” or the longest time.
  2. Disable battery and data saving on the phone
    • Turn off battery saver / power saving mode.
    • Remove restrictions for the hotspot app or “Tethering & portable hotspot” under battery optimization.
    • If your OS has “Data saver”, turn it off while you test.
    • Some Android skins are agressive and kill hotspot to save power even at high battery.
  3. Change hotspot band and channel
    • Try 2.4 GHz instead of 5 GHz, or the other way around. Some laptops drop 5 GHz often.
    • Change the WiFi channel from “Auto” to a fixed one, like channel 1, 6, or 11 for 2.4 GHz.
    • If you are in an apartment or hotel, interference is common.
    • On Windows or macOS you can check other networks around you. A WiFi analyzer helps a lot.
  4. Check your data mode and carrier side limits
    • Some carriers throttle or interrupt hotspot sessions on certain plans.
    • Try a different SIM or another phone on the same plan.
    • If both phones drop, the plan or carrier settings might be the issue.
  5. Update everything
    • Update phone OS and carrier settings.
    • Update WiFi and network drivers on your laptop.
    • On Windows, in Device Manager, open your WiFi adapter, Power Management tab, uncheck “Allow the computer to turn off this device to save power”.
  6. Change hotspot security and name
    • Use WPA2 or WPA3, avoid “Open network”.
    • Change the SSID to something new and set a new password. Corrupt or cached settings in your laptop or tablet sometimes cause repeat drops.
  7. Laptop and tablet power settings
    • On laptops, set WiFi to “Maximum performance” under advanced power settings.
    • Disable any “WiFi power saving” features in the adapter settings.
    • On tablets, turn off any WiFi sleep settings such as “Keep WiFi on during sleep” set to “Always”.
  8. Use a WiFi analysis tool
    • To see if this is interference or coverage related, use a simple analyzer.
    • Tools like advanced WiFi troubleshooting with NetSpot help you see signal strength, noisy channels, and drops over time.
    • That makes it easier to decide if you need a different band, channel, or even a dedicated travel router.
  9. Test with one device at a time
    • Connect only your laptop. See if it still drops.
    • Then only your tablet.
    • If drops start only when both are on, your phone hotspot might struggle with multiple clients or a specific protocol, like VPN or heavy video calls.
  10. Narrow it down by scenario
    • Try a different location, like outside or at a friend’s place.
    • Try a different phone as hotspot with the same laptop.
    • Try your phone as hotspot for a different laptop.
    • If only your laptop drops across devices, it is almost always driver or power settings on the laptop.
If you tweak these one by one and note what changes the behavior, you will find the root cause faster. A lot of the time, it ends up being a mix of power saving on the phone and a noisy channel that makes the hotspot look fine but drop clients every few minutes.
Your hotspot dropping like that is usually a combo of phone quirks, OS bugs, and random interference rather than just “bad signal.” @sternenwanderer already covered most of the obvious and semi‑advanced stuff, so I’ll skip repeating their checklist and poke at some other angles.
1. Check if the hotspot is actually losing WAN vs just WiFi
A lot of people blame WiFi, but the cellular side is what’s flaking out.
  • Next time it drops, stay connected to the hotspot and try:
    • Ping the phone’s gateway (on Windows/macOS: ping 192.168.43.1 or whatever your hotspot’s IP is).
    • If that works but websites fail, your WiFi is fine and your mobile data tunnel is cutting out.
  • If that’s the case:
    • Try setting your phone’s network mode to LTE only (no 5G / no 3G) or vice versa.
    • Disable “Smart network switch” / “Switch to mobile data automatically” / “Adaptive connectivity” on the phone. Those features sometimes reset hotspot sessions.
2. Watch out for VPNs and “extra security” apps
Hotspots and VPNs together can be a mess:
  • If your phone is running a VPN, try turning it off and see if the drops stop.
  • If your laptop is on a VPN, especially corporate ones that force weird keepalive traffic, disconnect it for a test.
  • Same goes for firewall / antivirus “web protection” and “network shield” type stuff; they can freak out on tethered connections and cause repeated re‑auth / drops.
3. Check if it is a known bug on your phone model
Some phones simply have broken hotspot firmware in certain versions:
  • Look up “<your phone model> hotspot disconnecting” and see if people are complaining on XDA, Reddit, or the manufacturer forums.
  • Sometimes only certain bands are affected or only when more than one device is connected.
  • If there is a known bug:
    • Try an older firmware if possible, or a newer beta / patch if the vendor released one.
    • On some Androids, enabling “Max performance” or “Game mode” keeps the radios alive longer than normal hotspot mode. Sounds dumb, sometimes works.
4. DHCP lease & IP conflict weirdness
This is less common, but it does happen:
  • If your laptop/tablet ever used the same IP range on a home router (e.g., 192.168.43.x or 192.168.0.x) and you had static IPs set at some point, your device can fight the hotspot’s DHCP.
  • On the laptop:
    • Ensure the WiFi adapter is set to “Obtain IP address automatically.”
    • Clear any manually configured DNS servers for that interface while testing.
  • Forget the network on both laptop & tablet and reconnect with the new credentials / SSID (you can combine this with what @sternenwanderer suggested about renaming SSID, but the key is forcing a clean network profile).
5. Application‑level causes: heavy traffic patterns
Some traffic just kills flaky hotspot implementations:
  • Constant torrenting, large OneDrive/Dropbox sync, or background Steam / game downloads can trip rate limits or buggy QoS in the phone’s hotspot stack.
  • Try:
    • Pausing cloud sync or download clients.
    • Browsing and light streaming only for 15–20 minutes. If it stays stable under light use but dies under heavy load, that strongly points to QoS / firmware limitations on the phone.
6. Thermal throttling: phone gets hot, WiFi dies
You said battery is fine, but temperature is a separate beast:
  • When the phone overheats, it can silently throttle or reset WiFi / modem.
  • Things to try:
    • Take the phone out of its case while using hotspot.
    • Keep it on a cool surface, not under a pillow or in a bag.
    • Lower screen brightness or turn the screen off completely.
  • If you notice drops happening after 10–15 minutes of use but not right at the start, this is a real suspect.
7. Use proper WiFi diagnostics instead of guessing
This is where a tool like NetSpot is actually useful:
  • Install NetSpot on your laptop and watch what happens to:
    • Signal strength from the hotspot over time.
    • Channel congestion in your area.
  • If the RSSI graph shows sharp drops to nothing, that points to the phone’s radio cutting out or heavy interference on that channel.
  • If signal stays stable but you still get disconnects, the problem is more likely:
    • DHCP issues
    • Mobile data flapping
    • VPN / firewall
    • Firmware bugs
You can grab it from here and use it to visualize the noise and signal more clearly:
analyzing and improving your WiFi hotspot stability
8. Try a different “role” setup
To isolate the problem:
  • Turn your laptop into a hotspot and connect the phone to it over WiFi, then share that internet via phone data. Ridiculous, but:
    • If the laptop hotspot is stable and the phone stays connected, your laptop/tablet WiFi hardware is probably fine and the phone’s hotspot side is the real issue.
  • Alternatively, use a second phone as hotspot for your laptop/tablet:
    • If both devices stay online with the other phone, that nails it down to your current phone’s implementation or carrier config.
SEO‑friendly description version you asked for
Why does my phone’s mobile hotspot keep disconnecting even when I have a strong cellular signal and enough battery? My laptop and tablet drop off the WiFi hotspot every few minutes, and basic troubleshooting like restarting devices and checking hotspot settings has not fixed the issue. I want to know the real causes of unstable hotspot WiFi and how to keep my phone’s hotspot connection from cutting out repeatedly on multiple devices.
