Why does my iPhone say not enough storage after clearing 5GB?
My iPhone update keeps saying there isn’t enough storage, even after I deleted apps, photos, and other files to clear about 5GB. I still can’t install the iOS update and I’m not sure what else is taking up space or how to fix it. Need help figuring out why my iPhone says not enough storage to update.
Your iPhone falls over before it hits true zero. I learned this the annoying way. Even without an update, iOS keeps chewing on free space for logs, temp files, indexing, app junk, and background cleanup. So when storage looks ‘almost full,’ it often means ‘already a problem.’
Add an iOS update and it gets worse. The phone needs room to pull down the update, unpack it, shuffle files around, then finish setup. I would try to get 15GB to 25GB free before trying again. Less than that, and it starts feeling like a coin flip.
TL;DR
If your iPhone says there is not enough room for an update, check two things first: the size of the update and how much free storage you still have. Then cut the biggest storage hogs first. If space is still too tight, update with a Mac or PC. Last resort, back up the phone, erase it, install iOS fresh, then restore your backup.
  1. Check the update size and your free space
Don’t start deleting random stuff yet. First see what you’re dealing with.
  1. Open Settings > General > Software Update.
  2. Look for the update size, if iOS shows it.
  3. Go back to Settings > General > iPhone Storage.
  4. Wait a few seconds for the chart and app list to load.
  5. Look at your free space.
  6. Check which categories or apps are taking the most room.
One thing people miss, I did too, the listed update size is not the full amount of space needed. If the update says 15GB, having 15GB free often won’t cut it. The phone still needs scratch space for installation.
Clear out photos and videos first
For most people, the camera roll is the main culprit. Mine was. You think it’s a few clips and screenshots, then you find 11GB of duplicate cat videos and 4K footage you forgot existed.
Doing this by hand takes forever. A cleaner app speeds it up. I’ve had the best luck with Clever Cleaner because it moves fast, it’s free, and the basic cleanup stuff isn’t locked away.
Here’s the short version:
  1. Download it and let it scan your library.
  2. Open Heavies and sort through your largest videos and media files.
  3. Delete the stuff you do not need.
  4. Open Similars and remove duplicate or near-duplicate shots. If needed, check the other cleanup sections too.
  5. Then go into Photos > Recently Deleted and tap Delete All.
That last part matters more than people think. If you skip it, the storage usually doesn’t come back right away. iOS keeps those deleted items around for 30 days.
Delete apps you do not use
When I need room for an update, I delete apps instead of offloading them. Offloading leaves behind app data, and a lot of the junk is sitting in Documents & Data anyway.
  1. Open Settings > General > iPhone Storage.
  2. Look through the app list, sorted by size.
  3. Tap the apps you don’t use.
  4. Choose Delete App.
You can reinstall them later. In most cases, it’s faster than trying to micro-manage leftovers.
Check the Files app
This one sneaks up on people. The Files app becomes a closet full of old downloads, PDFs, ZIP files, random videos, and stuff you saved once and forgot.
  1. Open Files.
  2. Check On My iPhone > Downloads.
  3. Delete old files you no longer need.
  4. Look in iCloud Drive too, if you store files there.
I found old installers, scans, and giant PDFs sitting there doing nothing. Easy win.
Remove large message attachments
Messages stores more than texts. Over time it piles up videos, photos, GIFs, voice notes, and PDFs. If you’ve had the same message history for years, this section gets fat.
  1. Go to Settings > General > iPhone Storage.
  2. Tap Messages.
  3. Open the attachment or documents sections.
  4. If Review Large Attachments shows up, use it.
  5. Delete the big files you don’t need.
The good part is you don’t have to wipe whole conversations.
Clear Safari website data
This won’t save a full phone by itself, though it helps.
  1. Open Settings.
  2. Go to Apps > Safari.
  3. Tap Clear History and Website Data.
  4. Confirm.
You’re not going to free 20GB here. Still, if you’re close, a few hundred MB matters. Sometimes more.
If you still don’t have enough room
At this point, stop fighting the phone directly and change the method.
Update with a Mac or PC
This works better than most people expect.
  1. Connect the iPhone to a Mac and use Finder.
  2. Or connect it to a Windows PC and use iTunes.
  3. Run the update from the computer.
  4. Make a full backup first.
The computer handles more of the download and unpacking process, so the iPhone usually needs less temporary free space.
Back up, erase, update, restore
This is the nuclear option. I’ve done it once. It was annoying, though it worked.
  1. Back up your iPhone.
  2. Erase the device.
  3. Set it up again.
  4. Install the newest iOS version.
  5. Restore your backup.
If the phone is packed so tight nothing else works, this tends to get it over the line.
If your iPhone still refuses to update, be ruthless. Remove anything you won’t miss. Old videos, unused apps, giant attachments, stale downloads. When you’re this close to the limit, every gig counts.
5GB freed sounds like a lot, but for iOS updates it often isn’t. The annoying part is iPhone Storage is not a live meter. It lags. iOS also keeps “System Data” and temp update files around, so you delete stuff and the free space number does not settle right away.
I agree with part of what @mikeappsreviewer said, but 15GB to 25GB free is more than you need in every case. For smaller point updates, I’ve seen them install with less. The bigger issue is hidden storage, not only total free space.
What I’d check next:
  1. Restart the iPhone.
    A simple reboot clears some temp files and forces storage recalc. Sounds dumb, helps a lot.
  2. Delete the failed update file.
    Look for an iOS update file in the app list.
    Delete it if it’s there, then try again.
  3. Check System Data.
    If System Data is huge, sometimes 10GB+, your phone is holding caches, logs, and leftover junk. You can’t clean all of it directly, which is why the storage message feels broken.
  4. Turn off and on Sync items.
    Photos, Messages, Voice Memos, iCloud Drive. Sometimes local copies hang around longer than they should.
  5. Wait a bit.
    After deleting 5GB, iOS often takes hours, sometimes overnight, to reclaim it fully. Annoying, yep.
  6. Update from a computer.
    This is still one of the best fixes if the phone is cramped.
If photos are the main problem, Clever Cleaner is worth a look for finding large videos, duplicates, and similar shots faster. Also, if you want a full, easy to read Clever Cleaner features review, this helps: see how Clever Cleaner handles duplicate photos and heavy files
Short version, your missing space is usually failed update files, System Data, or storage not refreshed yet. Reboot first. Then delete the old update package. That combo fixes it more often than pepole think.
5GB sounds like a lot, but for iOS updates it honestly sometimes isn’t. I partly agree with @mikeappsreviewer and @mike34, but I think the bigger gotcha is that iPhone storage reporting is flaky when the phone has been near full for a while.
A few things I’d check that they didn’t really dig into:
  • Mail app downloads and attachments. If you use Apple Mail, old synced attachments can eat space.
  • Music and podcast downloads. These are easy to forget because they don’t feel like “files.”
  • Offline content in streaming apps like Netflix, Spotify, YouTube.
  • Voice Memos. I found a bunch of old recordings once and got back almost 3GB. Kinda absurd.
Also check if the update is trying to install while Low Power Mode is on and the phone is charging weirdly. I’ve had updates act buggy until after a normal restart + charging for a bit. iOS can be dumb like that.
One thing I slightly disagree on: I would not jump straight to erasing the phone unless storage is completely jammed and a computer update fails too. That’s a huge pain in the ass for most poeple.
If photos are still the main problem, Clever Cleaner is useful for finding giant videos and duplicate pics faster than doing it by hand. And if you want more ideas on other smart ways to free iPhone storage for updates, that’s worth a read too.
My order would be:
  1. Restart
  2. Delete any downloaded iOS update file
  3. Check offline downloads in media apps
  4. Remove old Mail attachments / Voice Memos
  5. Try updating from a computer
That usually does it.
I’d add one thing @mike34, @shizuka, and @mikeappsreviewer only touched indirectly: sometimes the blocker is not storage alone, it’s the update path.
If you’re jumping several iOS versions, the delta package can fail and keep retrying. In that case, go to Settings > General > Transfer or Reset > Reset > Reset Network Settings. Weird fix, but it can clear stuck update handshake issues without deleting your data. Also check device analytics in Privacy & Security if you’ve had repeated failed installs. Constant crash logs can bloat space silently.
Another angle: app caches from third-party apps do not always show honestly in the storage list. Social apps are notorious for this. Deleting and reinstalling one giant offender can free more than “Offload” ever will.
For photos, Clever Cleaner is decent if your library is the main mess.
Pros: fast scan, good at spotting duplicate/similar shots, helpful for huge videos.
Cons: similar-photo suggestions still need manual review, and cleaner apps won’t touch a lot of true System Data.
I slightly disagree with the idea that you always need 15GB to 25GB free. Sometimes the phone just needs the right junk removed, not a massive purge. If local update keeps failing, computer update is still the smarter route.
