Need help with custom iOS application development
I’m planning a custom iOS application for my small business and I’m stuck on where to start. I’m not sure which tech stack, tools, or best practices I should follow for performance, security, and App Store approval. Can anyone share advice, resources, or step‑by‑step guidance on how to successfully plan and develop a custom iOS app?
Short version so you can move:
  1. Tech stack
    • Language: Swift. Objective‑C only if you have legacy stuff or a niche lib you need.
    • UI: SwiftUI for new apps, unless you need lots of custom low level UI, then UIKit.
    For a small business app, SwiftUI is fine and faster to build.
    • Minimum iOS: 15 or 16 to reduce bugs and edge cases.
  2. Architecture
    • Use MVVM with SwiftUI.
    • Keep networking, storage, and UI separate.
    Example:
    Data layer: APIClient + models
    Domain: “use case” or “service” classes
    UI: View + ViewModel
    This keeps code testable and less messy.
  3. Tools
    • Xcode, obviously. Use the current stable Xcode that matches the latest iOS.
    • Package manager: Swift Package Manager. Avoid mixing Cocoapods unless you must.
    • CI: GitHub Actions, Bitrise, or Xcode Cloud for automatic builds and tests.
    • Analytics: Firebase Analytics or AppCenter.
    • Crash reporting: Sentry or Firebase Crashlytics.
  4. Performance basics
    • Avoid heavy work on the main thread. Use async/await or background queues for network and parsing.
    • Cache images with URLCache or something like Kingfisher.
    • Keep lists lazy, use pagination for long data lists.
    • Test on low end devices in Simulator and on at least one real device.
    If scroll feels laggy, profile with Instruments, mainly Time Profiler and Allocations.
  5. Security and data
    • Never store secrets in the app binary. Anything sensitive lives on your server.
    • Use HTTPS only. Enable ATS in Info.plist.
    • Store tokens in Keychain, not UserDefaults.
    • If you have user accounts, implement proper logout that clears tokens.
    • Use Sign in with Apple if you have authentication. Apple likes that.
    • If you process payments, prefer in‑app purchase for digital goods and Stripe or similar for physical goods.
  6. App Store approval basics
    • Read App Store Review Guidelines once, it saves pain later. Main traps:
  • Avoid private APIs.
  • Do not mention other app stores.
  • If you use subscriptions, be clear about pricing, terms, and auto‑renew in UI.
  • Provide a “Restore purchases” button if you use IAP.
    • Provide full demo access in review account. Apple hates half‑broken reviewer flows.
    • Accurate screenshots and description. No fake features.
  1. For your small business use cases
    Common flows:
    • Customer login or simple guest mode.
    • Product or service list.
    • Booking or order form.
    • Notifications for order status or appointments.
    You should define these screens first on paper, then build from there. Do not start coding without at least rough wireframes.
  2. Basic project plan
    Week 1:
  • Define main features and user roles.
  • Pick Swift + SwiftUI + iOS 16+.
  • Set up Xcode project, Git repo, basic navigation.
    Week 2–3:
  • Implement backend API or pick a backend provider.
  • Add networking, auth, keychain storage.
    Week 4–5:
  • Build core screens and flows.
  • Add analytics and crash reporting.
    Week 6:
  • Polish, tests, App Store assets, TestFlight, submit.
If you share what your business does and what features you want, people here can suggest a more tailored stack and maybe tell you where you are overbuilding.
@viaggiatoresolare covered the “how to build it” side really well, so I’ll hit the “what to build and how not to regret it in 6 months” angle and disagree on a couple of bits.
  1. Start with a brutal feature cut
    Before tech stack, write down everything you think the app should do. Then cut it to:
    • 1 core user
    • 1 primary problem
    • 1 “wow, this actually helps my business” outcome
    If a feature doesn’t clearly drive revenue, save time, or reduce headaches, park it for version 2. Most small business apps die from trying to be a mini‑Shopify, CRM, and booking system on day one.
  2. Decide first: internal tool or public App Store app?
    This changes a lot:
    • Internal app (for staff): You might not even need the App Store. Use:
  • Apple Business Manager or Apple Developer Enterprise if that fits your size
  • Or even a web app / PWA if you control the devices
    • Public app (for customers): Fully follow App Store rules, marketing, screenshots, etc.
    If it’s mostly for staff, I’d seriously question if you need a native app at all. A solid responsive web app can be 10x cheaper to maintain.
  1. Slight disagreement: SwiftUI vs UIKit
    SwiftUI is great, but:
    • If your budget is tight and you plan to hire freelancers, ask them what they are strongest in. A mediocre SwiftUI dev is worse than a strong UIKit dev.
    • If your app is form heavy with weird validation, UIKit is still a bit more battle tested.
    If you are starting from zero and learning yourself, then I actually agree with SwiftUI: simpler mental model.
  2. Backend reality check
    Before you even touch Xcode, decide where data lives:
    • If you need user accounts, syncing, or data across devices, you need a backend.
    Options:
  • Simple: Firebase (fast, pragmatic)
  • More structured: small Node / Rails / Laravel backend on a cheap VPS
    • If your business already has a system (e.g., booking, POS, CRM), check if it has an API. Integrating with existing tools often beats reinventing them.
    Avoid the “we’ll use local storage only and sync later” fantasy. Sync is one of the hardest things to bolt on later.
  1. Admin and content control
    Everyone forgets this:
    • How will you update text, prices, images, promos?
    If every little change needs an app update, you will hate your life.
    Plan at least:
    • Remote config or a simple admin web panel
    • App pulls data from API instead of hardcoding most business content
  2. Performance from a business POV
    Not just FPS and memory:
    • App must open fast enough that a customer at the counter does not stare awkwardly at you
    • If you rely on network, handle “offline but still kind of works” for critical tasks (show last known prices, allow draft orders, etc.)
    Test it in realistic conditions: bad WiFi, 4G in a parking lot, older iPhone.
  3. Security vs friction
    @viaggiatoresolare is right on HTTPS, Keychain, etc. But also:
    • Don’t overcomplicate auth if it’s just customers booking something simple. Sometimes a “magic link” login via email is enough instead of passwords.
    • If this is a staff‑only app, plan how you remove access when someone leaves. That often gets ignored until your ex‑employee still has live data on their phone.
  4. App Store approval, non‑obvious traps
    Beyond the guidelines already mentioned:
    • If your app basically mirrors a website with no extra value, Apple might reject as “too simple.” So:
  • Use native navigation
  • Use push notifications meaningfully
  • Add something the mobile web cannot do easily (camera, offline bits, etc.)
    • If your app requires login, provide:
  • Demo account
  • Clear tester instructions in App Store Connect “Notes for Review”
    Reviewers are grumpy when they hit a wall on first launch.
  1. Budget and hiring reality
    If you are not coding this yourself:
    • Ask potential devs for:
  • One or two shipped apps they personally built significant parts of
  • How they would structure V1 almost like a one‑page proposal
    • Beware anyone who instantly suggests 10 third‑party SDKs you don’t really need. Each SDK is another point of failure and App Store risk.
  1. Minimal roadmap suggestion
    Before writing a line of Swift:
    • 1–2 days:
  • Define 3–5 screens on paper or a tool like Figma
  • Decide: native app is definitely needed vs just a mobile site
    • 3–5 days:
  • Clarify backend: existing system or new one
  • Decide who owns ongoing maintenance
    Only then commit to the tech stack details everyone loves talking about.
If you share what your business actually does (e.g., salon, small shop, home services, training, etc.) and who the primary user is, the stack and features can be trimmed a lot, which is honestly more valuable than choosing between two good Apple frameworks.
