Need help translating some phrases from English to Hebrew
I’m working on a small project and need accurate English to Hebrew translations for a few short phrases and sentences. Online translators keep giving me awkward or inconsistent results, and I’m worried about making mistakes in meaning, tone, or formality. Could someone experienced with Hebrew help me get natural, context-appropriate translations and maybe explain any nuances I should know?
Post your phrases and people here will help clean them up. For Hebrew, small details matter a lot, so I will give you some quick rules and then you can drop your lines.
  1. Context is everything
    Same English phrase needs different Hebrew versions.
Example
English: “Save”
Hebrew options:
• לשמור – save a file, save progress
• להציל – save a person, save a life
• לחסוך – save money
So when you post, add a short note like: “UI button text”, “dialog line”, “title of section”, etc.
  1. Gender and number
    Hebrew marks gender and singular or plural.
“I am ready”
• אני מוכן – speaker male
• אני מוכנה – speaker female
“Are you sure” in a popup to a user, gender unknown, neutral style:
אתה בטוח? / את בטוחה? is spoken, but for interface text prefer:
האם אתה בטוח? / האם את בטוחה?
For a gender neutral style in apps some use:
האם את/ה בטוח/ה?
Looks a bit ugly but common in tech.
  1. Formal vs casual
    For UI, products and instructions, usually use polite plural אתם/אתן or neutral imperatives.
Examples for buttons or actions:
• “Continue” → המשך / המשיכי, but safer UI text: המשך
• “Continue shopping” → המשך בקניות
• “Log in” → התחברות
• “Sign up” → הרשמה
• “Delete account” → מחיקת חשבון
  1. Short phrases, common options
    Here is a mini cheat sheet you can tweak once you share your exact text.
• “Settings” → הגדרות
• “Profile” → פרופיל
• “Home” (app main screen) → בית or דף הבית
• “Next” → הבא
• “Back” → חזרה
• “Try again” → נסה שוב / נסי שוב, or gender neutral UI: נסה/י שוב
• “Loading…” → טוען… or בטעינה…
• “Error” → שגיאה
• “Success” → הצלחה
• “Thank you” → תודה
• “Thank you for your purchase” → תודה על הרכישה
  1. Sentences structure
    Word order often flips compared to English.
“I need your help”
אני צריך את העזרה שלך (speaker male)
אני צריכה את העזרה שלך (speaker female)
“We value your feedback”
אנחנו מעריכים את המשוב שלך
“Your changes have been saved”
השינויים שלך נשמרו
  1. Avoid machine-translation style
    Machine tools often:
    • pick wrong gender
    • sound too formal or biblical
    • use odd word order
If you plan to generate a lot of text with AI then smooth it for Hebrew readers, you might want something like make AI text sound natural and human. Clever AI Humanizer helps turn robotic AI output into more human, fluent language for blogs, product text and UI copy, while keeping your meaning and keywords intact. That helps SEO and keeps the Hebrew from feeling like it came from a raw translator.
  1. What you should post next
    To get accurate Hebrew, add for each line:
    • English phrase
    • Where it appears (button, tooltip, dialog, email, etc)
    • Target audience (kids, general users, business users)
    • If possible, who speaks (app, company, user)
Example format you can use:
  1. “Start now”
    Context: main button on landing page for an app, neutral tone, general users.
Reply with 5–10 phrases at a time and it will stay clear and consistent.
Post your lines, yeah, but I’d add a few other tricks on top of what @viajantedoceu wrote, because Hebrew in real products can get weird fast if you only think in “rules”.
  1. Think in screens, not sentences
    Don’t just translate phrase-by-phrase. Put stuff in small groups from the same screen so the style stays consistent.
    Example (for a settings screen):
  • “Edit profile”
  • “Change password”
  • “Log out”
All together, you’d normally do:
  • עריכת פרופיל
  • שינוי סיסמה
  • יציאה מהחשבון
If you posted them one by one, you might end up with: “התנתקות” for “Log out” on one screen and “יציאה” on another, which will feel sloppy.
  1. Sometimes shorter is better Hebrew
    Online translators love long, literal versions like:
    “Your changes have been saved successfully” → השינויים שלך נשמרו בהצלחה
    Hebrew UI often just cuts it to: השינויים נשמרו
    Same meaning, less clutter. For product text, default to shorter unless you really need the nuance.
  2. Don’t overuse האם
    Here I’ll slightly disagree with @viajantedoceu: האם is fine, but in many modern apps it can feel a bit stiff.
  • “Are you sure you want to delete this?”
    UI dialog, general users:
    בטוח שברצונך למחוק? (to a male)
    בטוחה שברצונך למחוק? (to a female)
    Neutral-ish:
    למחוק את הפריט?
    Or:
    למחוק את החשבון?
A lot of real apps just skip the pronoun and go with a short infinitive question.
  1. Decide your gender strategy once
    Three common options:
  • Use masculine as default: standard, but not everyone loves it.
  • Use the ugly-but-common slash: בטוח/ה, התחבר/י. Functional, not pretty.
  • Duplicate text (if your product is serious / educational / gov, etc.): show gender-specific text based on user profile. Nicest UX, more work.
Pick one approach and stick to it across your UI so you don’t look like a Franken-app.
  1. Traps that keep showing up
  • “Apply” in a filter/settings context:
    החל → sounds formal; people still use it
    אישור → more natural sometimes, especially as a button
  • “Submit” (form):
    שליחה (for sending)
    אישור (for confirming)
    Sending a message: שליחה
    Confirming settings: אישור
If you share these with context, we can pick the best one, not just “theoretical Hebrew”.
  1. Let humans fix AI Hebrew
    If you’re generating a bunch of Hebrew content (emails, microcopy, blog posts around your product, etc.) and it comes out stiff or robotic, that’s exactly where something like make AI‑written Hebrew sound natural actually helps. It’s aimed at turning literal, machine-style Hebrew into fluent, human-sounding text while keeping your meaning and keywords. For UI strings it’s still better to post here and get them eyeballed, but for longer marketing or help-center stuff it can save a ton of time.
  2. What to do next
    Drop 5–10 phrases at a time, each with:
  • English phrase
  • Location in app/site (button, title, onboarding screen, email subject, etc.)
  • Who is “talking” (system, brand, user)
  • Tone: playful / neutral / formal
Example of how you might post:
  1. “Start now”
    Context: main CTA on landing page, general audience, friendly but not childish.
And you’ll get much more reliable Hebrew than any auto-translator will give you.
Posting your lines is the right move, but here are some different angles from what was already covered:
1. Decide if you want “product Hebrew” or “textbook Hebrew”
A lot of awkwardness comes from mixing styles:
  • Product / app Hebrew: shorter, more colloquial, often drops pronouns and helpers.
    • Example: “You can change this later” → אפשר לשנות את זה אחר כך
  • Textbook / formal: feels stiff in an interface.
    • “You can change this later” → באפשרותך לשנות זאת מאוחר יותר
Before translating, pick which world you live in. For a casual app, always lean to the first style.
2. Think about who is being addressed before translating
This is where many auto-translations fail, and it is something online tools ignore:
  • “Save your progress”
    • Speaking to a single user, masculine: שמור את ההתקדמות שלך
    • Single user, feminine: שמרי את ההתקדמות שלך
    • Neutral UI: שמירת ההתקדמות
Sometimes I disagree with the suggestion to always drop the user completely. In flows where guidance and empathy matter (onboarding, error states), a direct “you” feels more human:
  • “You’re almost done”
    • Friendly: כמעט סיימת
    • Neutral banner: כמעט סיום
For core buttons and small labels, yeah, drop pronouns. For supportive text, keep them.
3. Reorder, don’t just replace words
Hebrew does not like to follow English order. Concrete example:
  • “Edit your profile picture”
    Literal but clunky: ערוך את תמונת הפרופיל שלך
    Cleaner: עריכת תמונת הפרופיל שלך
    In a button under the image: עריכת תמונה
Try rewriting the sentence in your head to something a Hebrew speaker would actually say, then translate that. This is where your “awkward translator output” usually comes from: correct words in English order.
4. Microcopy: soften or sharpen on purpose
Not everything should be neutral. A few patterns:
  • Confirmation dialogs
    • Softer, for risky actions:
      • “Delete account” → למחוק את החשבון?
      • Helper line: כל הנתונים יימחקו לצמיתות
    • Sharper / more direct is ok for non-destructive:
      • “Clear history” → ניקוי היסטוריה
Sometimes I’d avoid the very short infinitive question that others like if the context is scary. “למחוק את החשבון?” alone can feel abrupt. Adding one softening line often helps.
5. Consistency rules I actually enforce in projects
When you post your strings, decide:
  • Suffix strategy:
    • Buttons for user actions: use infinitive nouns or infinitive verbs, not a mix.
      • Good: שמירה / ביטול / מחיקה
      • Or: לשמור / לבטל / למחוק
  • Past-tense system messages:
    • Use either “X נשמר” style or “השינויים נשמרו” style, not both.
So instead of translating each string fresh, define 3 or 4 “patterns” and stick to them across the app.
6. Specific traps you probably will hit
Use these as a quick reference when you post lines:
  • “Skip” (onboarding):
    • דלג / דלגי is very “instructional.”
    • Producty alternative: לדלג / דילוג or even פשוט “פסיחה” if it is a label, not a button.
    • I often use: דילוג for labels, דלג for buttons.
  • “Next” / “Back”:
    • Next: הבא / המשך
      • If it is a wizard, I usually prefer המשך.
    • Back: חזרה
  • “Done” vs “Save”:
    • Done: סיום when you are finishing a flow.
    • Save: שמירה when something is stored.
      Do not translate both to the same word or users get confused.
  • “Close” (dialog): סגירה is better on buttons than לסגור or סגור in many products, because it matches other noun-style labels.
7. How to ask for translations so you get better answers
To complement what @viajantedoceu wrote, I’d add two details when you post:
  1. Is this text permanent UI or can it change often?
    • Permanent: micro-optimize; we can polish the tone.
    • Temporary (e.g. experiment): go for clear & short, less poetic.
  2. Any existing Hebrew in the product?
    • If yes, copy a couple of typical strings so we match that tone.
    • If no, say what language you imagine: “like a Fintech app” / “like a game” / “like a government service.”
Example of a really helpful post:
  1. “Save & continue”
    Context: last step in a 3-step signup. Button text. Friendly but serious (fintech). System talking.
Then I’d probably propose:
שמור והמשך
or if you want noun-style:
שמירה והמשך
And explain which fits better with your other strings.
8. About tools like Clever AI Humanizer
If you are also generating longer Hebrew text (emails, help pages, marketing copy), translation is only half the story. That is where something like Clever AI Humanizer can actually be useful:
  • Pros
    • Can “smooth” stiff or literal Hebrew into something more natural sounding.
    • Good for bulk content where you do not want to hand-edit every sentence.
    • Helps keep the original meaning while cleaning up the style.
  • Cons
    • Still not a substitute for human eyes on short critical UI strings.
    • Can sometimes over-simplify nuances or lose tiny product-specific terms.
    • If your source English is vague, it may produce equally vague Hebrew, just more fluent.
So:
  • For core UI: post here in small batches; we tune phrase by phrase.
  • For long-form stuff: translate + run through Clever AI Humanizer, then lightly review.
Whenever you are ready, drop 5–10 phrases with context like above and mention if you want:
  • casual app tone
  • corporate SaaS tone
  • official / gov-like tone
Then we can give you targeted Hebrew instead of “generic translation Hebrew.”
