Need help getting started with iPhone apps development
I’m trying to get into iPhone apps development but feel stuck on where to begin. I’m unsure which tools, languages, and learning path to focus on first, and I don’t want to waste time on the wrong setup. Can someone guide me on the best way to start building iOS apps, including essential tools, resources, and common pitfalls to avoid?
Short version so you do not waste time:
  1. Hardware and OS
  • Get a Mac with current macOS.
  • Install Xcode from the App Store. That is the main tool you need.
  1. What to focus on first
  • Language: Swift. Ignore Objective C for now.
  • UI framework: Start with SwiftUI. UIKit is older and still used, but SwiftUI is simpler to learn.
  • Avoid random toolchains, cross platform stuff, React Native, Flutter, etc, until you ship at least one small native app.
  1. Learning path that works for most beginners
    Phase 1, basics, 1 to 2 weeks
  • Learn Swift syntax: variables, functions, optionals, structs, classes, protocols.
  • Use: “Swift Programming Language” book from Apple, it is free in Apple Books.
  • Do small playgrounds in Xcode, like:
    • A function that converts Celsius to Fahrenheit.
    • A simple model for a Todo item.
  • Goal here is to feel ok reading Swift code.
Phase 2, SwiftUI intro, 2 to 3 weeks
  • Follow one structured course, not ten tutorials. Options that work:
    • Apple “Develop in Swift” student or fundamentals books.
    • Hacking with Swift, “100 Days of SwiftUI” site, you can skip some days but keep order.
  • Build 2 to 3 tiny apps:
    • Counter app with + and - buttons.
    • List of items with add and delete.
    • Simple settings screen with toggles and sliders.
  • Focus on:
    • @State, @Binding, @ObservedObject.
    • NavigationStack, List, Text, Button, TextField.
  • Do not worry about fancy design or architecture yet.
Phase 3, make one “real” but small app, 3 to 6 weeks
Pick one idea you can finish in under a month. Examples:
  • Habit tracker.
  • Simple expense tracker.
  • Workout logger.
    Scope it hard. For v1, include:
  • 2 to 3 screens only.
  • Local data only, use UserDefaults or a small Core Data store.
  • No account system, no sync.
    During this:
  • Use Git for version control, even if you are solo. GitHub is fine.
  • Run on a real device, not only on the simulator.
  • Fix warnings and errors yourself, search StackOverflow when stuck.
  1. What tools to ignore at start
  • No need for Firebase, backend servers, analytics, CI, test frameworks, Pods, SPM packages, etc.
  • Do not touch Objective C, Combine, Swift Concurrency in depth, design patterns, TDD, until you finish at least one app.
  1. Rough weekly schedule idea
    If you have about 1 to 2 hours per day:
  • Week 1 to 2: Swift basics with playgrounds.
  • Week 3 to 5: Follow a SwiftUI course, build the sample projects.
  • Week 6 to 10: Build your own app from scratch, push it to TestFlight.
    You update this based on how fast you move, but keep the order.
  1. How to know you are on the right setup
    If you have all three, you are fine:
  • Mac with recent macOS.
  • Latest Xcode.
  • You write Swift with SwiftUI.
    Anything else is bonus.
  1. Good resources
  • Apple “Develop in Swift” books.
  • Hacking with Swift, especially SwiftUI projects.
  • Sean Allen and Paul Hudson on YouTube for focused topics.
Common trap I see a lot on the forums
  • People hop between ten courses, never finish any, and never ship.
  • They try to learn Swift, SwiftUI, UIKit, Firebase, MVVM, design patterns and so on all at once.
    Your priority is to ship one ugly, simple, fully working app to your own phone, then to TestFlight, then to the App Store if you feel like it.
Expect to feel stuck and slow at first. If you keep the stack simple and narrow, you get through the stuck phase much faster.
@mike34 covered a super solid “native-first” path. I’ll try to fill in some gaps and give you a slightly different angle, especially around decision-making and mindset.
1. Mac & Xcode… but how “serious” a Mac?
You don’t need a crazy machine to start. If you’re worried about money or commitment:
  • A base M1/M2 MacBook Air is plenty for beginner iOS dev.
  • Don’t obsess about RAM/SSD right now. If Xcode opens and simulator runs, you’re fine.
  • Update to a recent macOS and grab Xcode from the App Store. That’s mandatory.
Skip cloud Mac rentals at the start. They add friction and weird latency that just gets in your way.
2. Swift vs Objective‑C vs Cross‑platform
I half agree with @mike34 on ignoring Objective‑C. You can ship several apps without ever touching it. That said, at some point a tiny bit of Obj‑C reading ability helps when you reach older StackOverflow answers.
For now:
  • Go 100% Swift for code you write.
  • When you see Obj‑C in solutions, just copy patterns conceptually, not syntax.
Re cross‑platform (React Native, Flutter, etc.):
  • If your only target is iOS and you’re new to programming at all, going native is absolutely simpler.
  • If you already know JavaScript/TypeScript at a high level, you could argue React Native makes sense. But since you specifically said you don’t want to waste time on the wrong setup, stick with Swift + SwiftUI for your first real app. One stack, one mental model.
3. SwiftUI vs UIKit
I slightly disagree with the “ignore UIKit completely” mindset.
My recommendation:
  • Start with SwiftUI as your main UI framework.
  • At some point in your first or second app, deliberately do one small thing with UIKit. Example:
    • Present a UIKit UIImagePickerController from SwiftUI.
    • Use a UIViewControllerRepresentable wrapper.
Not because UIKit is better, but because:
  • Most answers and older code use UIKit.
  • Mixing the two once gives you confidence you’re not in a “SwiftUI bubble” that breaks the minute you need something advanced.
Do not start with a full UIKit app though. That’s a productivity hit in 2026.
4. Tiny real project before “the big app idea”
A trap I see all the time: people want their first app to be “the big one” (social app, marketplace, whatever) and then drown.
Do this instead:
  1. Mini real app (2–3 evenings max)
    • One screen
    • Local persistence with UserDefaults only
    • Example: “Daily Mood” app with 3 buttons (Good / Meh / Bad) that logs the last selected mood.
    • You learn:
      • SwiftUI state
      • Simple data storing
      • Basic layout
  2. Then your slightly larger “Phase 3” app as @mike34 suggested.
This tiny “pre‑app” breaks the mental barrier of “shipping something at all” faster than a multi‑week project.
5. Don’t trust “I’ll just watch videos for a while”
If you want to avoid wasting time, this is more important than which language you pick:
  • For every 10 minutes of tutorial, spend at least 10–20 minutes coding without the video.
  • After finishing a small tutorial app, close it and recreate it from scratch without looking.
  • When you copy code, try changing names, values, and layouts and see what explodes.
Passive watching creates the illusion of progress. Typing and breaking code is where you actually learn.
6. Architecture & patterns: how much to care early on
People get lost in “MVVM, Clean Architecture, TCA, VIPER, etc.” at the beginner stage.
My take:
  • Start with a messy-but-working structure:
    • A couple of simple view models
    • Some logic directly in views if needed
  • When the app starts to feel painful to modify, that pain is your signal to start learning architecture.
Learning advanced patterns before you write more than 500 lines of code is usually a waste. You won’t have intuition for why they exist.
7. What you should absolutely practice early
If you want to move from “stuck” to “I’m actually doing this”:
  1. Breakpoints & debugger
    • Learn to set a breakpoint in Xcode.
    • Step through your code line by line.
    • Inspect variables.
      This removes so much “I have no idea what’s going on.”
  2. Reading compiler error messages
    • Don’t just paste errors into Google.
    • Actually read them and try to interpret, even if you’re wrong at first.
    • Over time you’ll start recognizing common patterns.
  3. Version control basics
    • git init / first commit
    • Commit every time you finish a small feature
    • Use branches only after you’re comfortable
You don’t need fancy workflows, merges, or rebases yet. Just stop living in “final_final_REAL.swift”.
8. Simple decision checklist so you don’t overthink
If you can answer “yes” to these, you are on a non‑wasteful path:
  • Using a Mac with recent macOS and official Xcode
  • Writing Swift, main UI in SwiftUI
  • Working through one main learning resource at a time
  • Actively building a tiny app rather than just watching or reading
  • Pushing code to a git repo semi regularly
Everything else (Firebase, backend, patterns, analytics, test frameworks) is optional frosting you can add later.
9. Rough “sanity milestones”
Instead of time-based goals like “by week X”, think outcome-based:
  1. Milestone 1:
    • You can create a new SwiftUI project
    • Add a couple of views
    • Pass data from one view to another
      If you can do that from memory, you’ve cleared “Hello World learner” level.
  2. Milestone 2:
    • You can persist and read data from disk
    • App displays something you previously saved
      Now you understand state beyond just variables in memory.
  3. Milestone 3:
    • Your own simple app runs on a physical iPhone
    • You can build, archive, and at least run test builds on your device
      This flips a mental switch like “oh, this is real now.”
After Milestone 3, you can decide whether to go deeper into iOS specifically or start learning “real software engineering” topics around it.
If you post what kind of background you have (zero programming, web dev, other languages, etc.) and what type of app idea is stuck in your head, people can help you pick an even tighter path and maybe cut out another 20–30% of unneeded stuff.
You already got strong native-first roadmaps from @codecrafter and @mike34, so I’ll focus on how to avoid getting stuck and how to adapt their advice to different backgrounds.
1. Match the path to your background
If you’re totally new to programming:
  • I’d actually insert a 2–3 day “pure logic” detour before diving deep into Swift:
    • Variables, conditionals, loops, functions, arrays, dictionaries.
    • Tiny console programs only, no UI.
  • Reason: jumping straight into SwiftUI can feel like “magic words and attributes” with no idea what’s underneath.
If you’re a web dev (JS / TS / React):
  • You can shorten the “Swift basics” phase:
    • Focus on what’s different from JS: optionals, value vs reference types, strong typing.
  • Then move to SwiftUI quickly and treat it mentally like “React with stricter rules and no hot reload.”
If you already know another compiled language (Java / C# / C++):
  • You can skim most beginner Swift material:
    • Pay special attention to protocols, extensions, and optionals.
  • Spend more time understanding the Apple ecosystem: app lifecycle, entitlements, provisioning profiles.
2. Where I slightly disagree
  1. SwiftUI-only for a long time
    I’d avoid staying in a 100 percent SwiftUI bubble for too long. Not because UIKit is better, but because:
    • Real projects often hit “this thing still works better in UIKit.”
    • Understanding at least how a UIViewController looks and feels saves you confusion when reading docs and answers.
    You do not need to learn UIKit as a full framework early, but I’d:
    • Add a single UIKit-based feature in your second or third app.
    • That one integration will remove the fear of “legacy” APIs.
  2. Ignoring concurrency for too long
    Some say “skip async/await,” but you will hit background work almost immediately (networking, saving files, etc.).
    My take:
    • Do not study concurrency theory.
    • Do one afternoon with async/await:
      • Call a sample JSON API.
      • Parse and show results in a SwiftUI list.
    • This gives you a realistic feel of “how modern iOS code actually looks” without diving into Combine.
3. How to use tutorials without getting trapped
Both @codecrafter and @mike34 are right about sticking to one main course. The missing piece is how to work through it:
  • After each small project in the course:
    1. Close it.
    2. Rebuild the same thing from a blank project, using only your memory and the official docs.
    3. Compare and see what you forgot.
This simple “rebuild from scratch” habit:
  • Forces things into long‑term memory.
  • Quickly exposes what you only “watched” vs what you actually understand.
If a tutorial never asks you to:
  • Write code without copy‑pasting
  • Break things and fix them
    then you need to add that part yourself.
4. Mindset: scope and expectations
Big trap: wanting your first app to look like a top‑10 chart app.
Instead of only thinking “what app do I want to build,” add:
  • “What skill do I want this app to teach me?”
Example sequence:
  1. App A: Focus on state & navigation
    • 2–3 screens.
    • Local data only.
    • SwiftUI state management.
  2. App B: Focus on persistence
    • Maybe only 1–2 screens.
    • Try Core Data or a simple file-based approach.
    • Do not care about design at all.
  3. App C: Focus on networking
    • Pull data from a public API.
    • Show loading / error states.
By the time you are done with ABC, you are already far beyond “stuck beginner,” even if none of those apps ever hit the store.
5. Tools and services: nuanced “yes / no”
They said “ignore Firebase / backend / analytics” and that is mostly right, but if your idea deeply depends on cloud data (for example, shared lists across devices), I’d tweak it:
  • First, build a local-only version of your idea.
  • Once it works and feels good locally:
    • Add an extremely simple backend solution.
    • Here, Firebase can be a good stepping stone, as long as you:
      • Keep the data model small.
      • Avoid complex rules and triggers.
  • Do not start day 1 trying to architect an online platform.
For stuff like CI or test frameworks:
  • I agree fully: skip until you have at least one working app and feel some pain that tests or CI would solve.
6. On the “right setup” anxiety
You are “set up enough” when:
  • Xcode builds your project without weird hacks.
  • You can run the app on:
    • Simulator
    • At least one physical device you own
  • You have:
    • A private Git repo somewhere
    • At least one “from scratch” app folder you created manually
If you spend more time tweaking tools than writing Swift files, you are over-optimizing.
7. Comparing with what @codecrafter and @mike34 said
Very briefly:
  • They push native Swift + SwiftUI as the core stack. I agree, especially to avoid decision fatigue.
  • They suggest clear phases and timelines. Use those as a backbone, but stretch or compress them based on your prior experience.
  • My extra lens is:
    • Add a tiny “logic only” pre‑phase if you are brand new.
    • Add one UIKit and one async/await feature early so you do not build a false mental model.
If you share:
  • Your current programming background
  • One small app idea you are willing to attempt in under 3–4 weeks
people can help you slice it into realistic milestones. That matters more than picking the perfect library or pattern on day one.
