Is Upgrading IPhone Storage Capacity Too Risky?
I’m running out of iPhone storage and saw repair shops offering internal storage upgrades, but I’m worried about data loss, warranty issues, or damaging the phone. Has anyone upgraded iPhone storage capacity safely, and is it worth the risk compared with using iCloud or buying a new iPhone?
I looked into this same thing a while back when my iPhone was completely full. I saw those videos where people swap the storage chip and started thinking maybe it was no different from replacing a screen or battery. I even contacted a repair shop that offered more advanced board-level work.
They were honest about it, which probably saved me from making a dumb expensive choice. Their answer was basically: yes, it can be done, but it’s not something they’d recommend for a normal storage problem. It means removing and replacing the NAND chip, doing micro-soldering, programming the firmware, and accepting the risk that the logic board could be ruined. Even if the job works, you’ve still made warranty and future Apple repair stuff messier.
What helped more was dealing with the storage I already had. Start with Settings > General > iPhone Storage before assuming you need new hardware. I thought I was out of options, but a lot of the space was just being wasted.
  1. Offload apps you barely use. Offload Unused Apps removes the app but keeps your documents and data, so if you install it again later, your stuff comes back.
  2. Check Messages. Old chats can quietly turn into a huge pile of photos, videos, GIFs, and attachments. Mine had grown into several gigabytes. Setting older conversations to auto-delete helped keep it from building back up.
  3. Clean up Photos properly. This was the big one for me. Apple’s Duplicates album barely found anything because my problem wasn’t exact copies. It was ten similar shots, random screenshots, Live Photos, and big videos. I ended up using Clever Cleaner for that. It grouped similar photos, picked out the better shots, sorted videos by size, found old screenshots, and could turn Live Photos into regular still images when I didn’t need the motion part. That cleared way more space than I expected.
After the obvious junk was gone, iCloud Photos helped a lot too. Turning on Optimize iPhone Storage keeps the full-resolution versions in iCloud and leaves smaller versions on the phone until you open them. I barely notice it in normal use, but it cuts down the local space Photos takes up by a lot. If you don’t want iCloud, Google Drive or Dropbox can work for files and videos, though you’ll probably have to manage things more manually.
If you still need more room after that, external storage makes more sense than messing with the phone’s internals. I used a flash drive for older photos and videos I wanted to keep but didn’t need with me every day. USB-C iPhones make this much easier, and some drives can even be used by compatible apps to record video straight to the drive. Just check that the drive is formatted in something the iPhone can read, like exFAT or APFS.
I’m glad I didn’t do the storage chip swap. Cleaning up the phone, moving older stuff to cloud storage, and using an external drive solved the issue without risking the whole device. I’d try all of that before even considering a hardware storage upgrade.
Make an encrypted backup to a computer before you even talk to a repair shop, then check that the backup actually finished without errors. iCloud backup is fine too, but an encrypted Finder/iTunes backup keeps more local data like saved Wi-Fi passwords and health data. If the phone is already almost full, do this before it gets into that annoying boot-loop/failed-update situation where you suddenly have fewer options.
I agree with @mikeappsreviewer that this is not in the same category as a battery or screen swap. The missing caveat is privacy. A shop doing board-level storage work may need to test the phone afterward, and some places will ask for your passcode. Even if they are honest, you are handing over a device that probably has banking apps, photos, messages, email, saved logins, and 2FA apps on it. For me, that alone makes the storage-chip route a last resort, not a normal upgrade.
The boring answer is usually the best one here: clean it up, move media off, or put the money toward a used/refurb iPhone with more storage. If you use a cleaner app like Clever Cleaner, use it for the obvious bulky stuff like similar photos, screenshots, and large videos, but still review what it wants to delete. No app or shop should be treated like a magic “make storage bigger safely” button. Internal storage upgrades can work, but “can work” and “worth risking your main phone” are very different things.
Do not spend board-repair money on a phone you may not be able to trade in or repair normally afterward. That’s the hidden downside people skip. Even if the storage swap works, you now have a modified logic board, and Apple or a refurb buyer may treat it like a problem device. A random future issue could turn into “we won’t touch this” or “replace the whole phone.”
I’m a little more blunt on this than the earlier replies: internal storage upgrades are not really an “upgrade path” for an iPhone. They’re a hacky repair-shop service for people who accept the risk. If it is your daily phone, has your only copy of photos, or you still expect Apple service, I would not do it. The price only makes sense if the phone is otherwise expendable and you’re okay with the job failing.
If you’re trying to buy time, delete or move the heavy stuff first, then decide. Videos, Messages attachments, offline maps, downloaded music/podcasts, and app caches are usually the real storage pigs. If that still doesn’t get you enough room, selling the phone as-is and buying the same model with more storage is boring, but it’s a cleaner bet than paying someone to microsolder your way out of a storage problem.
Whether the shop is offering to preserve your data or wipe the phone first matters a lot. A lot of people hear “storage upgrade” and picture a bigger version of the same phone coming back with everything still there. I would not assume that. Treat it like the phone may come back blank, fail during the job, or need a full restore afterward.
I’m not as absolute as “never do it,” because for an older spare phone or a hobby device, sure, someone with proper board tools can make it work. But for a phone you actually depend on, it is a weird risk/reward trade. You are paying for a delicate logic board modification just to avoid the normal iPhone answer, which is buying the capacity you need upfront. That is annoying, but it is how these phones are designed.
A smaller annoyance people forget: clearing storage is not done when you tap delete. Photos and videos sit in Recently Deleted until you empty it. Some apps also keep their own downloaded files even after you clean the camera roll. Streaming apps, TikTok/Instagram caches, GarageBand projects, old iMovie exports, voice memos, and Files downloads can be stupidly large. Before I’d let anyone touch the NAND, I’d plug the phone into a computer, copy off the DCIM folder if possible, remove big local downloads, empty Recently Deleted, then reboot and check storage again.
I agree with the others on backups, but I’d make it stricter: don’t do the repair unless you have at least one backup you’d be comfortable restoring to a replacement phone tomorrow. Not “I think iCloud backs up.” Actually check the date of the backup and make sure photos/messages are covered in whatever setup you use. If you use an app like Clever Cleaner for photos, that’s fine for finding obvious bulk like similar shots and huge videos, but review before deleting and still have a backup first.
So the safe answer is: yes, it can be done safely by the right shop, but it is not a normal consumer upgrade. It is more like a board-level modification with storage as the reward and the whole phone as the thing you’re gambling. If you need reliability, put the money toward a larger used/refurb iPhone and restore your backup. That is less interesting, but usually much less painful.
