How To Use Ai For Content Creation
I’m trying to use AI for content creation, but my drafts keep sounding generic and off-brand. I’ve tested a few tools for blog posts, social media captions, and website copy, but the results still need heavy editing and take too much time. I need help figuring out the best way to use AI writing tools to create faster, better content without losing quality or my brand voice.
Your drafts sound generic because the AI has no brand context. Most people give it a topic and hope for magic. That fails.
Do this instead.
Build a brand input doc. Keep it short.
  1. Brand voice, 5 traits.
  2. Words you use.
  3. Words you ban.
  4. Sample copy you like, 10 to 20 pieces.
  5. Audience pain points.
  6. Offer and CTA rules.
Then prompt in layers.
  1. Ask for 5 angles first.
  2. Pick one.
  3. Ask for an outline.
  4. Edit the outline.
  5. Ask for a draft in your voice doc.
  6. Ask for 3 rewrites for tone.
Best prompt format:
“Write for [audience]. Goal is [action]. Voice is [traits]. Avoid [list]. Use this sample for style [paste sample].”
Also, train by example. Paste your old high-performing posts. AI copies patterns better than abstract rules. My output got way beter after I fed it 15 real emails and 20 captions.
Last thing, never publish first draft AI copy. Use it for speed, not taste.
Generic output usually means you’re asking AI to do the whole job, when it’s better at doing one narrow job at a time.
I mostly agree with @caminantenocturno, but I think people over-focus on prompting and under-focus on source material. If your raw inputs are bland, the output will be bland too. AI is a pattern remixer, not a brand strategist.
What helped me:
  • Feed it messy notes, customer emails, sales calls, reviews, FAQs
  • Have it extract exact phrases customers use
  • Build content around those phrases, not around polished marketing language
  • Use AI for repurposing, not first-idea generation
Example:
  • turn a webinar transcript into 5 posts
  • turn a customer Q&A into a blog outline
  • turn support tickets into website copy
Also, set a “human-only layer”:
  • opening hook
  • strong opinion
  • real example
  • final CTA
That’s usually where brand actually lives. AI can do structure fast, but voice? ehh, not really unless you force it with real material. If you’re editing heavily every time, the workflow is probs wrong, not just the tool.
I’d add one thing to what @caminantenocturno said: sometimes the problem is not the draft, it’s the review criteria. If you just ask “make this better,” AI defaults to safe mush.
Try scoring drafts against a tiny brand rubric:
  • Would our actual customer say this?
  • Is there a clear point of view?
  • Is the sentence structure too clean and samey?
  • Does this sound like a person with stakes, or a brochure?
Also, don’t use one model pass. Use staged passes:
  1. Draft for clarity
  2. Rewrite for tension or specificity
  3. Cut 30 percent
  4. Swap generic claims for proof
  5. Final pass only for brand voice
That separation helps a lot.
I slightly disagree with the “AI is bad at voice” thing. It’s bad at inventing voice. It’s decent at matching voice if you give it enough contrast. Show it 3 things you would publish and 3 things you’d never publish. That “negative example” trick is weirdly effective.
Pros for ': can improve readability, help standardize formatting, and make content more SEO-friendly.
Cons for ': can flatten tone, over-optimize phrasing, and tempt you into publishing stuff that sounds technically fine but emotionally dead.
Best use case, honestly: let AI produce version two, not version one. That shift fixes a lot.
