How To Delete Photos From IPhone After Import When Storage Is Almost Full?
I imported photos from my iPhone, but my storage is almost full and I’m not sure how to safely delete the imported pictures from the device without losing anything. I need help figuring out the right steps to free up iPhone storage after photo import.
If you want imported photos off the phone in bulk, and you want the space back for real, there are a couple steps people tend to miss.
Videos go with them
Yep. The same bulk delete methods remove videos too. I noticed this mattered more than the photos, since videos were eating most of my storage. If your phone still feels packed after an import, check those first.
Why the delete box vanishes after import
On Mac Photos and the Apple Devices app on Windows, the option to delete items after import disappears once iCloud Photos is turned on. I ran into this and thought the app was bugged. It was not. Apple hides the manual delete option when iCloud is managing the library.
What fixed it for me:
  1. Open Settings
  2. Go to Photos
  3. Turn off iCloud Photos for a bit
  4. Reconnect the iPhone to the computer
After I did this, the delete checkbox showed up again.
Bulk delete imported photos from iPhone on a Mac
If Photos keeps throwing errors or refuses to cooperate, Image Capture is the easier route. It felt old-school, but it worked first try.
  1. Plug the iPhone in with USB
  2. Open Image Capture from Applications
  3. Pick your iPhone from the sidebar
  4. Press Command + A
  5. Click the delete icon, the circle with the slash
Image Capture handles the phone more like a camera. Because of that, it skips some of the read-only weirdness I kept seeing in Photos when iCloud sync was on.
Delete imported photos in bulk right on the iPhone
If you do it on the phone, the Imports album is the fastest place to start.
  1. Open Photos
  2. Tap Albums
  3. Scroll down to Utilities
  4. Open Imports
  5. Tap Select
  6. Drag across thumbnails to grab a large batch fast
  7. Delete them
Small catch, and this is the part people skip. Those files are not gone yet. They move into Recently Deleted and still take up storage for 30 days.
  1. Go back to Albums
  2. Open Recently Deleted
  3. Tap Delete All
Until you clear that folder, your storage number often stays almost the same. I learned this the annoying way.
How to make sure the storage was freed
Check here after emptying Recently Deleted:
  1. Open Settings
  2. Tap General
  3. Tap iPhone Storage
  4. Look at the Photos category
If the number dropped, the cleanup worked. If it still looks off, restart the phone once. I had to do this because iOS did not refresh the storage total right away.
Why the phone still feels slow after you cleared imports
When storage is close to full, iOS starts acting rough. I saw camera delay, app freezing, and random sluggishness. Deleting imported photos helped, but it did not solve everything because I still had duplicate shots, bursts, and old large videos sitting around.
One thing I used after the import cleanup was Clever Cleaner. What stood out to me was the file sorting. The Heavies section put the biggest files at the top with exact sizes, so screen recordings and large videos were easy to spot. The Similars section grouped near-matching photos and marked a best shot, which made burst cleanup faster. It also showed file sizes before removal, and the scan stayed on-device.
After I cleared about 20GB with Clever Cleaner, plus the imported stuff I had missed, the lag on my phone stopped.
First, verify the import on your computer. Open a few random photos and videos from the imported folder. Check file count too. If you moved 3,200 items off the iPhone, make sure you see about 3,200 on the computer. People skip this step and regret it. I slightly disagree with @mikeappsreviewer on one point. Turning off iCloud Photos to force old import-delete options back is a bit messy if your library sync is active. I’d avoid touching sync settings unless you have no other path. Safer route: 1. Back up the imported folder to an external drive or cloud first. 2. On iPhone, open Settings, General, iPhone Storage. 3. Tap Photos. 4. Review “Review Personal Videos” and large attachments if shown. 5. Then delete from the Library or Search by month, like “March” or “April,” so you remove the same batches you imported. 6. Empty Recently Deleted. If storage is critically low, restart after deletion. iOS sometmes updates free space late. If your library is messy, Clever Cleaner helps sort large videos, duplicates, and similar shots faster. That matters because videos often eat 5GB to 20GB by themselves. For more Apple-user discussion on Clever Cleaner and photo cleanup, see best ways to free up iPhone storage after deleting photos.
I’d do one extra safety check before deleting anything, because “imported” does not always mean “fully copied.” Open the imported folder on your computer and make sure a few LIVE photos and videos actually play. Sometimes still images copy over but the motion/video part gets weird. Also, slight disagreement with @mikeappsreviewer: I would not rush to disable iCloud Photos unless you absolutely have to. That can create its own mess if sync is mid-process. Best low-stress way: 1. Confirm the import is complete. 2. Copy that imported folder to a second place, external drive or cloud. 3. On iPhone, check Settings > [your name] > iCloud > Photos first. If “Optimize iPhone Storage” is on, deleting from the phone also deletes from iCloud and other Apple devices. People miss that. 4. If you want to keep everything in iCloud, don’t delete from Photos blindly. 5. If you only need local cleanup, use Files/Image Capture/computer-based deletion after confirming backup. One more thing. If your storage is still trashed after deleting pics, it’s usually videos, duplicates, or giant screen recordings. @kakeru was right on that part. Clever Cleaner is actually useful for that kind of cleanup since it surfaces heavy files and similar shots faster. If you want a readable breakdown, check this Clever Cleaner review for freeing up iPhone storage faster. And yeah, always empty Recently Deleted or the space won’t come back right away. iOS loves playing dumb about that stuff.
