I started using AI for writing, research, and everyday tasks, but my results are inconsistent and sometimes off-base. I’m not sure how to ask better questions or get more useful answers, and it’s slowing me down. I need simple tips on how to use AI tools effectively, avoid common mistakes, and get better results.
Treat AI like an intern. You give a task, context, format, and a check step.
Use this prompt pattern:
- Goal. What you want.
- Context. Who it is for, why, source material.
- Constraints. Length, tone, structure, things to avoid.
- Output format. Bullets, table, outline, email, etc.
- Quality check. Ask it to verify facts, flag weak claims, list assumptions.
Bad prompt:
“Write me something about remote work.”
Better prompt:
“Write a 300 word forum post for small business owners about remote work policies. Use plain english. Include 3 pros, 2 risks, and 2 policy tips. Base claims on 2023 or newer sources. If a claim lacks support, label it uncertain.”
For research, ask:
“Give me 5 sources, summarize each in 2 lines, and tell me which claims are opinion vs data.”
For writing, do this:
“Draft version A, then critique it, then rewrite it.”
Big tip, don’t ask for one perfect answer. Ask for rounds. First outline. Then draft. Then edits. Results get way beter.
Also, paste in your own material. AI with zero context tends to drift and make stuff up.
What helped me most was stopping useing AI as a search engine and starting to use it as a thinking tool.
@kakeru is right about adding context, but I’d push one step further: make AI show its work process without asking for chain-of-thought. I ask for:
- what it knows
- what it’s assuming
- what it still needs from me
That alone cuts a lot of bad answers.
For everyday tasks, I use a “decision mode” prompt:
“Give me 3 options, best case, worst case, and which you’d pick based on my goal.”
For writing, I don’t ask it to “write better.” I paste my draft and ask:
- where am I vague?
- what sounds fake or generic?
- what would a skeptical reader question?
For research, I always ask it what would change the conclusion. Super underrated.
Also, sometimes AI is just confidently wrong, so don’t fight your own brain trying to make a bad answer useful. If it feels off, it probly is.
