How Do I Clear Media On IPhone Storage After Switching From ITunes Sync To ICloud?
I switched from syncing my iPhone with iTunes to using iCloud, but photos, music, and other media from the old iTunes sync still seem to be taking up storage. I’m not sure what’s safe to delete or how to remove it without losing anything important. I need help clearing this leftover media so I can free up space on my iPhone.
I ran into this after iOS 17 too, right after I changed how I back up my phone. Storage said Media was huge. Tapping around Settings gave me almost nothing useful. Big number, no clear source. It felt broken.
What sits inside “Media”
On iPhone, Media covers more than people expect. It is not your normal Photos library stuff. It pulls in downloaded music, saved movies, offline TV episodes, voice memos, ringtones, and a pile of cached files from apps. Stuff like album art, preview images, and other local junk apps keep around so pages load faster.
Podcasts were the sneaky one for me. They hide well. One episode can be 100MB or more, sometimes a lot more. If you follow a few shows and left the defaults alone, your phone might be pulling new episodes in the background for weeks or months. Check Settings > Podcasts and turn off Download When Saving. If you do not, it keeps feeding the pile.
Why you see 30GB with no obvious files
This part seems tied to iOS 17 storage reporting. Apple split some data into a separate area called Synced Media. If you ever moved music, audiobooks, or videos from a Mac or PC through iTunes or Finder, those files might be sitting in there.
The annoying part is simple. You see the total size, but iPhone Storage does not give you a clean list of what is inside. No file view. No sorting. No real clue.
I saw this after moving away from old iTunes syncing and leaning on iCloud more. Some old synced files looked gone, but storage still counted them. What helped me once was removing Apple Music and Apple Books, clearing anything I still saw inside first, then deleting those apps and reinstalling later if needed. I would not call it a proper fix. Still, it did knock out ghost storage for me one time, so it is worth trying if the number makes no sense.
Why Apple’s own cleanup tools feel half done
Settings shows app totals. Fine. It does not show your biggest files across the whole phone in one useful list.
Photos is worse for cleanup than people think. You cannot sort your library by file size there. So if some forgotten 5GB video is chewing through storage, you sort of have to stumble into it. The Duplicates folder helps only with exact copies. Near-matches do not count. Ten nearly identical shots from the same moment still sit there untouched.
I tried doing it by hand once. Took forever. I still missed stuff.
What I used instead
After trying a few apps and getting tired of the free scan, paid delete nonsense, I stuck with Clever Cleaner. For me, the big reason was simple. No ads. No subscription wall. No charge when you press delete.
What worked for the Media mess
  1. Open the Heavies section
This was the first place I checked. It sorted my library from biggest file to smallest and showed the exact size on each item. I found an old 4K clip and a screen recording I forgot existed. Those two files alone explained a chunk of the mystery.
  1. Check the Similars section
This helped more than Apple’s duplicate finder. It grouped photos which were close, not only exact copies. Burst shots, same subject from a slightly different angle, three tries at the same pic because one person blinked. I kept one and dumped the rest fast.
  1. Look at Screenshots
Mine were a mess. Shipping confirmations, random settings pages, meme saves, parking info, error messages I did not need anymore. The useful bit here was seeing size info before deleting. Screenshots stack up quietly.
  1. It stayed on the phone
This mattered to me more than I expected. I did not want personal videos or voice notes sent off somewhere else for processing. The app runs on-device, which made me a lot less twitchy about using it.
The part people miss after deleting stuff
Deleting files is not the last step. iPhone moves them into Recently Deleted, and they still count against storage until you empty it or wait 30 days.
So after cleanup, go to Photos > Albums > Recently Deleted > Delete All.
That is the step that changed my storage bar. Before I did this, it looked like nothing had happened.
What is usually behind the mystery number
If Media is still absurdly high after cleanup, I would look at two things first:
Old Synced Media left behind from a past iTunes or Finder setup
Podcast downloads piling up in the background over time
The settings change stops the future buildup. The cleanup app helps with the pile already sitting on the device. That combo got me closer to normal than anything inside Apple’s own menus.
Old iTunes synced media often stays stuck until you remove the sync relationship, not the files one by one. That part matters.
Try this first.
  1. Connect your iPhone to the same Mac or PC you used before.
  2. Open Finder, or iTunes on older Windows.
  3. Select the iPhone.
  4. Go through Music, Movies, TV Shows, Photos, Books.
  5. Uncheck sync for each media type, or choose Remove from iPhone.
  6. Apply and let it finish.
This is the cleanest way to purge old synced stuff. If you skip this, storage sometimes keeps reporting ghost data.
I disagree a bit with @mikeappsreviewer on deleting Apple Music or Books first. I’d do that last. It is more of a workaround than a fix.
Then check these:
Settings > General > iPhone Storage > Music. Delete downloaded songs.
TV app > Library > Downloaded. Remove offline video.
Files app > On My iPhone. Look for old media folders.
Voice Memos. Delete large recordings.
Messages > Review Large Attachments.
For photos, if you moved to iCloud Photos, turn it on and choose Optimize iPhone Storage. Then wait. It is not instant, annoyngly.
If your Photos app is messy, Clever Cleaner is decent for sorting big videos and duplicate junk faster. Also, this review breaks down how the app works in plain english, see why Fossbytes tested Clever Cleaner for iPhone cleanup.
Last step. Restart the phone after all deletions. iOS storage totals lag a bit and look wrong for a while.
Big thing I’d add to what @mikeappsreviewer and @viajeroceleste said: check whether the space is actually System Data reindexing and not real media anymore.
When you switch from iTunes/Finder sync to iCloud, iOS sometimes keeps the storage category looking bloated for a while. Annoying, yes. But not always “stuck files.” I’ve seen it settle after these:
  • finish an iCloud backup
  • connect to Wi-Fi + power overnight
  • restart once or twice
  • update iOS if you’re behind
Also, if you had Sync Photos from iTunes/Finder in the past, those photos are separate from iCloud Photos. You cannot always delete them on the phone itself. If that old synced photo library is still there, the fastest test is:
  • turn iCloud Photos OFF temporarily? Nope, I actually would not start there
  • instead check Settings > Photos for anything indicating synced albums or limited behavior
  • then connect to computer and see if photo sync is still enabled on that device profile
One place people forget: Books app. Downloaded PDFs, audiobooks, and old epub files can sit there forever. Same with GarageBand, iMovie, and even WhatsApp/Telegram media inside app storage. Those don’t always show up clearly as “media” in a way that makes sense. Apple’s storage screen is kinda half baked tbh.
If your actual problem is just sorting huge photo/video junk faster, Clever Cleaner is useful for that side of it. It’s also featured in top AI cleaner apps for iPhone storage cleanup. I wouldn’t treat it as a fix for old iTunes ghost sync data though. That’s where I slightly disagree with @mikeappsreviewer. Cleaner apps help with library clutter, but not every storage bug is deletable from inside iOS.
My “nuclear but clean” option if the number still looks fake:
  1. Confirm everything is in iCloud.
  2. Make a fresh backup.
  3. Erase iPhone.
  4. Restore from iCloud backup, not old computer backup.
That usually kills leftover synced cruft if nothing else does. Pain in the butt, but it works more often than Apple admits.
I’d add one check nobody’s really stressing: Accounted vs usable storage.
Sometimes the old synced media is gone, but the storage database has not reconciled yet. Before doing anything drastic, compare:
  • Settings > General > iPhone Storage
  • then connect to a Mac and check the device storage bar there
If the numbers are wildly different, you may be chasing a reporting issue, not actual files.
I slightly disagree with the “delete Apple Music/Books app” workaround unless you already confirmed downloads inside those apps. Too random for my taste.
What I’d do beyond what @viajeroceleste, @espritlibre, and @mikeappsreviewer covered:
  • Check Settings > [your name] > iCloud > Manage Account Storage and confirm what is truly in iCloud versus only local
  • In Books, tap your profile and remove downloads, especially PDFs
  • In GarageBand/iMovie, open each app and look for project media. Those can be huge
  • In Messages, search has:attachments if you use iMessage a lot
  • For third-party apps like WhatsApp or Telegram, clear media from inside the app, not from iPhone Storage alone
If the issue is really photo/video clutter and not ghost sync data, Clever Cleaner can help surface large files fast.
Pros of Clever Cleaner
  • good for finding heavy videos and duplicate-like photos
  • easier than Apple Photos for bulk cleanup
  • useful when storage is real, not bugged
  • won’t truly remove old Finder/iTunes sync relationships
  • less helpful for app caches, Books, Music, or system-level storage weirdness
  • cleanup apps can make people delete first and verify later
My rule: if storage still looks fake after 48 hours on Wi-Fi + charging, stop poking at apps and go to either computer resync removal or full erase/restore. That is usually where the phantom chunk finally dies.
