Can anyone help with my Woojer Vest 4?
My Woojer Vest 4 suddenly stopped working the way it should after I updated my setup, and now I’m not getting the haptic feedback I used to. I’ve tried reconnecting it, checking the app, and testing different cables, but nothing has fixed it. I need help figuring out if this is a pairing, software, or hardware issue so I can get it working again.
Sounds like the update changed the audio path, not the vest itself.
Try this in order.
  1. Power cycle everything. Vest, phone or PC, app, DAC, console.
  2. Re-pair the Vest 4 in the Woojer app. Remove the old device entry first.
  3. Check input mode. If you switched from analog 3.5mm to Bluetooth, or USB to analog, the vest might still be listening to the old source.
  4. In the Woojer app, raise haptic sensitivity and volume. Some updates reset profiles.
  5. Test with a known bass-heavy source. A 40 to 80 Hz tone sweep works better than music.
  6. If on PC, check Windows sound settings. Disable audio enhancements, set output to stereo, 48 kHz, and make sure your default device is the one feeding the vest.
  7. If you added a splitter, mixer, DAC, or HDMI extractor, bypass it. Woojer vests often get weak or no haptics from low line-level output.
  8. Swap the 3.5mm cable with a TRS cable, not TRRS. Wrong pinout causes weird stuff.
  9. Check firmware in the app. If the issue started right after firmware update, look for a rollback option or ask Woojer support for one.
  10. Factory reset the vest. On a lot of Woojer gear, this fixes pairing and profile bugs after updates. If you dont know the button combo, check the manual for Vest 4.
Quick test to isolate it:
Phone headphone dongle to vest with a bass test track. If haptics return, your new setup is the problem. If still dead, it’s the vest, app, or firmware.
A lot of ppl run into this after changing from direct analog to USB audio. The app says connected, but the vest gets little or no low-end signal. That part is sneaky.
I’d add one thing to what @codecrafter said: don’t assume “no haptics” always means not enough bass getting in. Sometimes the vest is getting signal, but your new setup is doing surround virtualization, spatial audio, or chat mix weirdness and basically thinning out the low-end transients the Woojer reacts to.
A few diff things to check:
  • If you’re on PC, turn off Dolby Atmos, Windows Sonic, DTS, Nahimic, Sonic Studio, SteelSeries Sonar, Voicemeeter, any of that stuff. Those can absolutely mess with the tactile response.
  • Check balance/LFE settings if you’re feeding it from an AVR, console monitor, or capture setup. If bass management changed, the vest may be missing the channel info it used to “feel”.
  • Try the vest from a totally seperate source while your normal headphones stay on the main setup. That tells you fast whether the issue is source processing vs the vest itself.
  • In some setups, too much gain is actually bad. People crank the chain and the signal gets compressed to death, so the vest feels flatter, not stronger. Kinda counterintuitive but real.
  • Also inspect the jack on the vest with a flashlight. Tiny lint or a slightly loose port can make it act half-dead. Seen dumber things fix it lol.
One thing I slightly disagree on: factory reset is useful, sure, but I’d save that for later. It can turn a simple routing issue into a “now I have to re-do everyhting” issue.
If your setup update included USB interface, console audio menu changes, Discord/chat mixer, or HDMI audio extraction, I’d bet the problem is there, not the vest hardware. The vest is usally the last thing to actually fail.
