I accidentally hit format on my SD card before backing up my photos and videos, and now everything looks erased. I need help figuring out the safest way to recover data from a formatted SD card without making it worse.
I’ve been in this spot before, and the first move is simple. Stop using the SD card now.
If the card was formatted and then mostly left alone, your files still have a fair shot. A lot of devices, cameras, drones, phones, even Windows, do a quick format. That wipes the index, not the full contents. Your photos and video clips often stay put until new data lands on top of them.
So yeah, don’t shoot more video on it. Don’t save photos to it. Don’t drag files onto it from your laptop. Every write raises the odds of old data getting replaced, and once that happens, you’re done.
What I’d do next is run recovery software from your computer, never from the SD card itself. I’d start with Disk Drill. I used it on a formatted card once after a camera wiped a trip’s worth of photos, and it was easier to work through than some of the other tools. The preview helped a lot because I could check which files still opened before saving anything. It also includes an Advanced Camera Recovery mode, which helps with split or fragmented video from stuff like drones, GoPros, and dash cams.
Here’s the plain process:
Take the SD card out of the device.
Plug it into your computer with a card reader.
Install the recovery app on your computer’s internal drive or another drive, not on the SD card.
Scan the SD card.
Look through the results and preview files first.
Save recovered files somewhere else, like your computer or an external drive.
If you want other options, Recuva is fine for easier jobs. I found it okay for deleted files, less so for formatted cards, and it got messy with video. UFS Explorer is stronger when things are uglier, like partial corruption or a card with filesystem damage, but the interface feels built for people who already know what they’re doing.
One thing people skip, and then regret. If the card keeps disconnecting, turns painfully slow, makes odd sounds, or your computer won’t see it at all, stop with software. That starts looking more like hardware failure. At that point, a recovery lab makes more sense, because repeated reads from a failing card sometimes make the situation worse.
Formatted SD card recovery for photos and videos is often possible if you stop writes fast. Your best odds come from reading the card on a computer, making a full image first, then scanning the image with recovery software like Disk Drill. This thread on recovering photos after formatting an SD card covers similar cases.
I agree with @mikeappsreviewer on one big point. Stop using the card.
Where I differ a bit, image the card before you scan it if the data matters. ddrescue on Linux or USB Image Tool on Windows works well for this. You read the card once, save an .img file to your PC, then run recovery on the image. If the card starts glitching mid-scan, you still have a snapshot. Safer move, imo.
A few checks first.
If the format happened in-camera, recovery odds are often decent.
If you recorded new clips after formatting, recovery drops hard.
If the card shows 0 bytes, wrong size, or drops offline, skip DIY and go to a lab.
For software, Disk Drill is a solid pick for formatted SD card recovery, esp for photos and video previews. PhotoRec is free and strong, but filenames and folders usually come back as a mess. TestDisk is more for partition repair, not my first pick here.
One more thing. If this is exFAT and the format was quick, your files are often still there. Full format is worse, but some data still somtimes survives if no overwrite happened.
Save recovered files to another drive. Not back to the SD card.
I’d add one thing to what @mikeappsreviewer and @sternenwanderer said: check the card’s lock switch if it’s a full-size SD card. Slide it to read-only before you do anything. Tiny step, but it helps prevent accidental writes if your reader or OS decides to be “helpful.”
Also, I’m gonna mildly disagree with the “just scan it right away” approach for every case. If these are irreplaceable photos or drone/video clips, I’d first test the card with the least amount of stress possible. If it mounts normally and shows the right capacity, cool. If it hangs File Explorer, disappears, or gets crazy slow, don’t keep poking it. That’s where people make it worse.
My order would be:
- Write-protect the card if possible.
- Plug it in once and see if the PC detects the correct size.
- If yes, recover from it or from an image copy.
- If no, stop DIY stuff and consider a pro lab.
For software, Disk Drill makes sense here because formatted SD card recovery is basically what it’s made for, and the preview is useful for checking whether the files are actually intact before you waste time exporting junk. For videos, that matters a lot more than people think. Sometimes the file “recovers” but won’t play right.
One more practical thing: after recovery, sort files by date taken / codec / file size, not just filename. Formatted-card recoveries often bring back old deleted stuff from months ago too, so the results can look like chaos lol.
If you want a visual walkthrough, this step-by-step SD card data recovery video guide is easier to follow than most text-only instructions.
And yeah, do not format it again, run “repair” tools, or let Windows “fix” the card. That stuff sounds smart until it nukes what was still recoverable. Happens way too ofetn.
